Visitors: 141
Total: 141
20: Event Calendar
60: Pictures
101: Event Calendar
116: Event Calendar
126: Event Calendar
Baja Forums -:- AzBaja.com Members -:- New Members -:- New to bajas from Vt.
vtbaja
vtbaja
Post Post subject: New to bajas from Vt.
Posted: Tue Aug 13, 2013 04:48 AM
Hi everyone, my name is John, im 42 and live it vermont. I had just recenly picked up a 72 super beetle in pretty good shape and now I want to build a baja bug. Now, I know that everyone says they dont make a good baja bug at all because of the strut front end and it wont take the jumps but here in vermont, there are no dunes to jump in, just alot of mud and hill climbing so that is all,im going to be doing with it and also driveing it on the road as well. Right now its lowered, has a recent top end rebuilt 1600DP motor, all new brakes and hardlines. My plans are to cut the original metal fenders into baja fenders, raise the rear by cutting the extra notch in the torsion bar, raise the front by installing rear vw rabbit springs inside a new set of bug springs with a 2 in spacer and try to run a set of 31in tires, narrow ones in front and semi wide on the rear. If anybody has any ideas, and not he typical get rid of it and just get a standard, or cut the framehead and install a standard front end, not doing it, im also installing the heavey duty strut brace for the front struts as well, feel free to chime in with any ideas. Thanks
vtbaja
vtbaja
Posted: Wed Aug 14, 2013 02:23 AM
Wow, 22 views and not even a welcome aboard, hmmmmmm. Nice.
smiles993
smiles993
Posted: Wed Aug 14, 2013 03:22 AM
Well for what it is worth welcome aboard. Sounds like you have got your work cut out for you. There are plenty of forums with a bunch of answers fi you just look around. I am not all that great at advise at VW's as I am rather new to them my self.
Good luck with you project.
Posted: Wed Aug 14, 2013 03:37 AM
Welcome to the site vtbaja. remember we like pictures
Posted: Wed Aug 14, 2013 03:42 AM
You posted in two places. Also views are Bots crawling the site.
Best of luck, unfortunately we have rougher terrain here and we opt for stronger builds, however I run a stock 66 Ball Joint beam which will most likely only last so much longer. It'll be a reason to upgrade, improve upon it when it begins to fail.
It has gotten me through many narly areas that I wouldn't even try alone. That's why I go with someone and have been towing it there so I can not only recover it with the 4x4 if absolutely needed but get to drive it home in nice Air Conditioning. Smile
Best of luck to you.
vtbaja
vtbaja
Post Post subject: Re: New to bajas from Vt.
Posted: Wed Aug 14, 2013 03:46 AM
Thanks, I would ad pics but cant find where to download like on other websites or I woukd, can I get a little help but let me tell you, im only useing a tablet to do this so maybe its not showing everything.
Posted: Wed Aug 14, 2013 04:41 AM
Just make sure to run a strut bar up front to support the strut towers.
Not the best choice for baja, but if it was cheap, go with it.
Strut bar: www.pacificcustoms.com...12010.html
Front fenders: www.jcwhitney.com/1971...979j1.jcwx
Posted: Wed Aug 14, 2013 06:01 AM
You have to use an external image hosting site. I use photobucket. Copy the Url and enclose it in img tags. Photobucket gives you a place to click on for BBCode and it copies it to the clipboard. Then right click and paste in a reply here. Hit Preview if you want to see it first. This site's a little slow so don't doubleclick submit or it'll double post.
vtbaja
vtbaja
Posted: Wed Aug 14, 2013 06:35 AM
Hope this works. Here is a link to my pics of my 72 super, let me know what you think, its the yellow ones at the top page. s216.photobucket.com/u...7171792984
Posted: Wed Aug 14, 2013 03:01 PM
Here you go. It's actually the code that says IMG on the right side...
If you Quote this message you can see the Code that produces it. Smile
vtbaja
vtbaja
Posted: Wed Aug 14, 2013 04:34 PM
Im on a tablet, not sure if that makes a difference but I just soent 10 min. Looking for it and I cant seem to find it, maybe its just different on here, not sure but thanks.
vtbaja
vtbaja
Posted: Wed Aug 14, 2013 04:47 PM
Ohhhh, I see it now, its on my photobucket page, thanks for pointing that out. Smile
Posted: Wed Aug 14, 2013 06:08 PM
It still looks pretty nice to cut up. You can't trade it for a Baja'd version locally? Putting wider tires on in the rear might contact the fenders. There's an awesome selection of tires available if you have deep pockets.
I'm not sure on your gearing, but you don't want to tall of a tire or you'll bog down really bad when taking off and you'll lose torque for going up steep hills, etc. Don't get Firestone Destination's. Mine are chunking out hard core. My other ones are dry rotting real bad.
vtbaja
vtbaja
Posted: Wed Aug 14, 2013 06:29 PM
Thats the thing here in vermont, I dont think I have ever seen a baja bug or I would see if I could make a trade. I really dont want to cut it but......... Its all I have unless someone on here would want to save it from being cut and trade me a baja, even if it needs a little work, I would do that. Im in a huge hesitation from even starting to cut the fenders right now just because of the shape it is in. PLEASE SAVE HER AND MAKE ME A TRADE????? Smile
Posted: Wed Aug 14, 2013 08:18 PM
Haha, yeah they're all over out here. Never considered your location and how many may be available.
I like the look of cut fender Baja's especially if you have the money for the right tires. If all you cut are fenders, replacements are easy enough to get so potentially if someone wanted to change it back they could.
My Grandpa went into a lot of places with his Baja, which was just a cut fender Bug and no fiberglass.
No new posts VW Volkswagen & Baja Bug General Discussion New to Bajas?
133 Mykul 135489 New to Bajas?
 Thu Mar 15, 2012 10:26 PM
project69baja View latest post
55 GHOSTRIDER 36258 hello from ghostrider ...
 Sat Apr 29, 2017 06:16 AM
GHOSTRIDER View latest post
[ Go to pageGo to page: 1 ... 10, 11, 12 ]
175 BugZyla.com 78749 BAJAS at SONIC Eastsid...
 Sun Jun 22, 2014 11:36 AM
No new posts Events and Get Togethers World Wide Bajas, Bugs, and Buggies at Sycamore Creek-March 2nd
55 JWHracing 30614 Bajas, Bugs, and Buggi...
 Sat Mar 09, 2013 07:55 PM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Full bodied bajas 2 desertbaja 3478 Full bodied bajas
 Sun Aug 19, 2012 05:29 AM
sandfreaks View latest post
