Visitors: 81
Total: 81
13: Pictures
23: Event Calendar
64: Event Calendar
75: Event Calendar
76: Event Calendar
77: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- move air filter inside of car?
randode
randode
Post Post subject: move air filter inside of car?
Posted: Sat Dec 09, 2006 02:09 AM
So its pretty dusty in the desert out here in Surprise. Its so bad that after a couple of hours, my K&N is totally plugged, and my motor doesnt run very well. I was going to put one of those outer wear things over the filter, but thought it would be even better to mount the filter inside the car. Has anyone done this? How did you do it? I want it to be trick, but low buck at the same time. Maybe some Home depot dryer vent hose, a new K&N, and a sheetmetal adapter for the top of the carb.
azhunter
azhunter
Post Post subject: Re: move air filter inside of car?
Posted: Sat Dec 09, 2006 03:47 AM
Alot of the racers use a UMP filter system. This is a cyclonic filter. Meaning it spins all tha med to large debris out of the air flow then has a two stage filter. Usually foam over paper. They work very well. This is the same system John Deere, IH, ect. use. Well worth the money if you do alot of dirt driving.
Posted: Sat Dec 09, 2006 05:05 AM
Your truck semi truck filter looks like a small 5 gal can with a mushroom vent on the side or top
Posted: Sat Dec 09, 2006 05:07 AM
If you put it inside the car it will suck all the dirt from the out side to the inside of your car, The filter will still get dirty and now the inside of the car will get dirtyer.
bajasam96
bajasam96
Posted: Sat Dec 09, 2006 07:41 AM
You may try a more of a snorkel style, mounted up high on the roof. Alot of 4x4's do this to travel through streams, but you would probably have less dust up there too.
Any yes I have heard of a filter mounted remote inside and I was about to do the same, but I met a guy who said he had done it and he complained that it was crazy noisey. But what real baja isnt?
6Rage
6Rage
Posted: Sat Dec 09, 2006 09:25 PM
baja bugs & buggies by Hibbard has all the info on it including what you shouldnt use. for the most part,
My other cars a UDLX
Need to know the method to my madness? email me I'll tell ya bajarage @ hotmail.com.
azhunter
azhunter
Posted: Thu Dec 14, 2006 02:30 AM
I guess my point was the UMP system is so efficient you don't need to mount it inside.
www.uniquemetalproduct.../index.htm
They have filter lits to fit the solex,zenith,weber carbs ect.
azhunter
azhunter
Posted: Thu Dec 14, 2006 02:34 AM
Try this site too.....
www.off-road.com/vw/ump/umppr.html
Posted: Thu Dec 14, 2006 03:29 AM
I went out exploring a little today and had to go thru a couple small silt beds. Man what fun I may just go again tomorrow. I see no reason or real difficulty in putting the air filter inside, just drill a hole thru your firewall, attach a couple of pieces of pvc tubing to a rubber grommet hooked to the carb, and attach the filter to the other end.
azhunter
azhunter
Posted: Thu Dec 14, 2006 06:20 AM
Was that your honey do? Laughing
Posted: Fri Dec 15, 2006 02:48 AM
No monday was the honey do day. yesterday I went to the store and made a right instead of a left on the way home.
No new posts VW Volkswagen & Baja Bug General Discussion Remote Oil Filter
Where is the best location?
4 Adub 3279 Remote Oil Filter
 Wed Feb 15, 2017 10:31 PM
Adub View latest post
No new posts New Members Air filter issues
Can't keep the Dust out
11 DerekT 5451 Re: Air filter issues
 Mon Oct 03, 2016 01:59 PM
No new posts VW Volkswagen & Baja Bug General Discussion [ Poll ] Oil Filter or Not to Oil Filter 4 ghs215 3048 Oil Filter or Not to O...
 Fri Nov 13, 2015 03:46 AM
No new posts VW Volkswagen & Baja Bug General Discussion Replacing air filter
Breather tube?
3 pschneider 3924 Re: Replacing air filt...
 Sun Jun 13, 2010 04:03 PM
Rickman View latest post
No new posts New Members Looking to move to AZ
34 Grunt-0341 15020 Re: Looking to move to...
 Sun Feb 08, 2009 04:06 PM
