Latest: xbluegto
Overall: 3573
Visitors: 201
Total: 201
16: Home
29: Event Calendar
36: My Account
39: My Account
65: Event Calendar
105: Pictures
140: Event Calendar
157: Baja Forums
158: Baja Forums
189: Event Calendar
190: AMAZON.com
193: Event Calendar
197: AMAZON.com
198: AMAZON.com
201: Baja Forums
Baja Forums -:- Off-Road & VW Based Clubs (4x4, ATV, Jeep, Motorcycle) -:- Events and Get Togethers World Wide -:- The AVC 400miler.. May 11, 12th
Post Post subject: The AVC 400miler.. May 11, 12th
Posted: Tue Jul 30, 2013 02:29 AM
I have a few more video's if you like me to post them...
this is the AVC 400 miler part 4.
youtu.be/fPWDfH94XGY
Posted: Tue Jul 30, 2013 03:02 AM
The AVC 400 miler part 5
youtu.be/PX4MkwFKA7Y
TINMAN
TINMAN
Post Post subject: Re: The AVC 400miler.. May 11, 12th
Posted: Wed Jul 31, 2013 03:54 AM
that road looks smooth and fast i would love to run that i,d have dennise screaming in no time
TRUMP 2020
Posted: Fri Aug 02, 2013 12:01 AM
I must admit the 4 peaks road is one of my most favorite... The gravel on the road is always loose and slippery which means you don't have to have a whole Lotta speed to pitch the car sideways.. I'll see if I can find some footage of me going up for peaks my speed is almost doubled because I can use the rear tires for thrust to keep me on the road when I pitched my car sideways.. The two videos that I've posted part 4 and part 5 shows me going downhill. this road does not have a guards rail so if you listen to the video you will see me backing off the throttle when there's a cliff that I could fling myself off of and you'll see me punching it when my "out" is a wall or a ditch.. You're not going to believe me... But in the past I've driven off of few cliffs.. Not like what you'd see in the movies it was usually because my front tires have fallen off the cliff and there's no means for me to back out of it so you tighten your belt's you say a short little prayer to the "VW God" and take your foot off the brake.. One thing that I've learned is that you can actually kind of control the car in a freefall, the steering works to appoint to be able to avoid a Bush or tree by inches.. This only works if you have your front tires turning.. Some of us have valves that disengage the front brakes so that you can lock up the rear axle and still be able to turn.. We didn't put this valve in place for freefalling it was more for the cinders and dunes where having front brakes only impedes you.
Tinman.... Pick a weekend when it's cooler and come on down I'd be happy to take you over the for peaks road...
No new posts Events and Get Togethers World Wide Sat 12th - Off roading at ??
19 pepeazul 7155 Sat 12th - Off roading...
 Tue Jan 15, 2013 05:20 PM
