AzBaja Site info
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Class 11 and wide-eye mix
Users browsing this topic:
None
Author |
Message |
phulc
Post subject: Class 11 and wide-eye mix
Posted: Wed Jan 09, 2013 10:37 PM
Hi folks,
I am experienced with things(181) and bugs and am planning to build a car for intensive offroad-driving.
I am thinking about a baja-bug but:
as we cannot register new bajas legally in Germany anymore, I wonder, what a bug with stock hoods, just having the wide-eye-fenders front and back would look like. Means a mixture between class 11 and wide-eye, based on a standard bug.
It will have 181-axles,
185/80 R14 (stock 181 rims & tires) front or 195/70 R15 (rims 356-style) and
235/70 R15 back tires (on welded 8x15 rims).
These parts are "left overs" from previous projekts.
Do you know a car that ist styled similar? Would be great if you could provide me a link or a pic to get a first impression.
Thanks.
Phulc
_________________ www.181-berlin.de
+51
Post subject: Re: Class 11 and wide-eye mix
Posted: Thu Jan 10, 2013 04:22 AM
It should look good. It would be different. Some tubing and thin cardboard miht be good for seeing what looks best.
phulc
Posted: Thu Jun 27, 2013 03:15 PM
@mods: pls delete, was a douple post. thx
phulc
Hi guys,
I still am trying to configure a legally drivable offroad-bug. The front will remain almost stock - just with a 181-axle, but in the back I want to use the fat 235/75R15 tires. So a wide fender with enough clearance is needed.
Just two questions:
1. How about using front-fenders in the back? I recently saw that in a video ( http://www.youtube.com/watch?v=CwPcl-BgVkk), but they cut away a lot from the fender.
Does a front-fender completely fit in the back or only the round section of it?
How much wider does such a front-fender in the back come out?
2. What would you prefer driving in the rear: a 181-swing-axle or a bug irs? I have both options.
Thanks 4 reading ...
Phulc
+12
Posted: Thu Jun 27, 2013 03:29 PM
phulc
Posted: Thu Jun 27, 2013 03:57 PM
In Germany the fenders have to be that way, that the wheel is completely covered in the section A.
In the front, this won´t be a problem as the 185/80 R14 aren´t much wider than stock.
In the back things are more difficult.
We can buy wide fenders in Germany as well ( 8cm widened fenders), but they don´t look very robust to me - so I´d prefer sheet ones. That´s why I consider the idea using part of front fenders in the back ...
+5
phulc
phulc
+5
phulc
Posted: Thu Jun 27, 2013 07:15 PM
phulc
+5
phulc
Posted: Thu Jun 27, 2013 07:55 PM
+5
Topics |
Replies |
Author |
Views |
Last Post |
Projects and Builds
3" Body Lift, Class 11 cage, Warrior Beam w/ 10" towers, 3x3
Go to page:
1, 2 ]
25 |
Kreed |
26742 |
3" Body Lift, Class 11... Tue Apr 10, 2018 02:26 PM Kreed  |
Projects and Builds
New Class 11 Build - PepeBlanco
4 |
pepeazul |
5370 |
New Class 11 Build - P... Tue Mar 22, 2016 01:19 AM MojaveRacer208  |
Projects and Builds
CLASS 5 Resurrection!
Go to page:
1 ... 3, 4, 5 ]
60 |
wideopenmotorsports |
48049 |
CLASS 5 Resurrection! Mon Feb 22, 2016 05:23 PM wideopenmotorsports  |
5-1600 vs Class 11 Version 3
2 |
3470 |
5-1600 vs Class 11 Ver... Thu Oct 08, 2015 08:12 PM AzBaja  |
Projects and Builds
Class 11 PepeAzul
3 |
pepeazul |
5625 |
Class 11 PepeAzul Fri Jul 17, 2015 02:29 PM AzBaja  |
Picture Box
Great things to Buy
Other Sites
Parts - For your Car
