Visitors: 438
Total: 438
08: Event Calendar
15: Event Calendar
72: Event Calendar
73: Event Calendar
94: Event Calendar
107: Event Calendar
110: Event Calendar
125: Event Calendar
140: Event Calendar
150: Baja Forums
153: Event Calendar
155: Event Calendar
157: Baja Forums
158: Baja Forums
162: Baja Forums
163: Event Calendar
166: Baja Forums
168: Baja Forums
170: Baja Forums
171: Baja Forums
172: Baja Forums
173: Event Calendar
176: Baja Forums
177: Baja Forums
178: Baja Forums
179: Baja Forums
180: Event Calendar
181: Baja Forums
183: Event Calendar
184: Event Calendar
185: Event Calendar
186: Baja Forums
187: Baja Forums
188: Event Calendar
189: Baja Forums
191: Baja Forums
192: Event Calendar
193: Baja Forums
194: Baja Forums
195: Event Calendar
196: Baja Forums
197: Baja Forums
198: Baja Forums
199: Baja Forums
200: Baja Forums
201: Baja Forums
202: Baja Forums
203: Baja Forums
204: AMAZON.com
205: Baja Forums
207: Baja Forums
208: Event Calendar
209: Baja Forums
210: Baja Forums
212: Baja Forums
213: Baja Forums
214: Baja Forums
215: Baja Forums
216: Baja Forums
217: Event Calendar
218: Baja Forums
219: Baja Forums
220: Event Calendar
221: Baja Forums
223: Baja Forums
224: Baja Forums
225: Baja Forums
226: Baja Forums
227: Baja Forums
228: Baja Forums
229: Baja Forums
230: Baja Forums
231: AMAZON.com
232: Baja Forums
233: Baja Forums
234: Baja Forums
235: Baja Forums
236: Baja Forums
237: Baja Forums
238: Event Calendar
239: Event Calendar
240: AMAZON.com
241: Baja Forums
242: Event Calendar
243: Baja Forums
244: Baja Forums
245: Baja Forums
246: Event Calendar
247: Baja Forums
248: Baja Forums
249: Baja Forums
250: Baja Forums
251: Baja Forums
252: Baja Forums
253: Baja Forums
254: Event Calendar
255: AMAZON.com
256: AMAZON.com
257: Baja Forums
258: Baja Forums
259: Baja Forums
260: Baja Forums
261: Baja Forums
262: Baja Forums
263: Baja Forums
264: Baja Forums
265: Event Calendar
266: Baja Forums
267: Event Calendar
268: Baja Forums
269: Baja Forums
270: Baja Forums
271: Baja Forums
272: Baja Forums
273: Baja Forums
274: Baja Forums
275: Baja Forums
276: AMAZON.com
277: Baja Forums
278: Baja Forums
279: Baja Forums
280: Baja Forums
281: Baja Forums
282: Baja Forums
283: AMAZON.com
284: AMAZON.com
285: Baja Forums
286: Baja Forums
287: Baja Forums
288: Baja Forums
289: Baja Forums
290: Baja Forums
291: Baja Forums
292: Baja Forums
293: Baja Forums
294: Baja Forums
295: AMAZON.com
296: AMAZON.com
297: Event Calendar
298: AMAZON.com
299: Baja Forums
300: Baja Forums
301: Baja Forums
302: Baja Forums
303: AMAZON.com
304: Baja Forums
305: Baja Forums
306: Baja Forums
307: Baja Forums
308: AMAZON.com
309: Baja Forums
310: Baja Forums
311: Baja Forums
312: Baja Forums
313: AMAZON.com
314: AMAZON.com
315: Baja Forums
316: Baja Forums
317: Baja Forums
318: Baja Forums
319: Event Calendar
320: Event Calendar
321: Event Calendar
322: Baja Forums
323: Baja Forums
324: Baja Forums
325: Baja Forums
326: AMAZON.com
327: Baja Forums
328: Baja Forums
329: Event Calendar
330: AMAZON.com
331: Baja Forums
332: Baja Forums
333: Baja Forums
334: AMAZON.com
335: Baja Forums
336: Baja Forums
337: Event Calendar
338: Baja Forums
339: Baja Forums
340: Baja Forums
341: Event Calendar
342: Baja Forums
343: Baja Forums
344: Baja Forums
345: Baja Forums
346: Baja Forums
347: Baja Forums
348: Baja Forums
349: Baja Forums
350: Event Calendar
351: Baja Forums
352: Baja Forums
353: Baja Forums
354: Baja Forums
355: Baja Forums
356: Baja Forums
357: AMAZON.com
358: Baja Forums
359: Baja Forums
360: Baja Forums
361: Baja Forums
362: Baja Forums
363: Baja Forums
364: Baja Forums
365: Event Calendar
366: Baja Forums
367: Baja Forums
368: AMAZON.com
369: Baja Forums
370: Baja Forums
371: Pictures
372: Baja Forums
373: Baja Forums
374: Baja Forums
375: Event Calendar
376: Baja Forums
377: Baja Forums
378: Baja Forums
379: Baja Forums
380: Baja Forums
381: Baja Forums
382: Baja Forums
383: Baja Forums
384: AMAZON.com
385: Baja Forums
386: Event Calendar
387: Baja Forums
388: Baja Forums
389: AMAZON.com
390: Baja Forums
391: Baja Forums
392: Baja Forums
393: Event Calendar
394: Pictures
395: Baja Forums
396: AMAZON.com
397: Baja Forums
398: Baja Forums
399: Baja Forums
400: AMAZON.com
401: Baja Forums
402: Baja Forums
403: Baja Forums
404: Baja Forums
405: Baja Forums
406: Baja Forums
407: Baja Forums
408: AMAZON.com
409: Baja Forums
410: Baja Forums
411: Baja Forums
412: Baja Forums
413: AMAZON.com
414: AMAZON.com
415: Baja Forums
416: AMAZON.com
417: Baja Forums
418: Baja Forums
419: AMAZON.com
420: AMAZON.com
421: Baja Forums
422: Baja Forums
423: Baja Forums
424: Event Calendar
425: AMAZON.com
426: Baja Forums
427: Baja Forums
428: Baja Forums
429: Baja Forums
430: AMAZON.com
431: AMAZON.com
432: AMAZON.com
433: Event Calendar
434: Baja Forums
435: Event Calendar
436: Baja Forums
437: Baja Forums
438: Baja Forums
My 69 project
1 2 3 ... 10 11 12 ... 77 78 79
Posted: Mon Jun 24, 2013 04:32 AM
Hope the toe feels better soon, so where's the radiator going?
Posted: Mon Jun 24, 2013 03:00 PM
My toe feels better today still purple.. I'm a put the radiator where it looks the best first and see if it works out.. Probably right underneath the rear window.. The problem with radiators they need to be in the airflow to work properly.
Posted: Mon Jun 24, 2013 06:23 PM
Airflow is a big deal or it'll overheat for sure. It also has to be somewhat level with the block too from what I've seen or you'll have coolant flow issues. Have you considered in front? Where's the condenser for your A/C?
Posted: Tue Jun 25, 2013 01:00 AM
there is no coolant flow issues with radiator height it only comes into play if the radiator is low on coolant is long as you keep your radiator topped off it's not an issue that I know.. Thought about putting the radiator up front briefly anyway I cut it, have airflow issues.. All three of my condensers are located in the front of the vehicle. One of my condensers is located in the airflow and two of them are by forced air only.. I'm hoping that the radiator I plan the use has enough surface area to keep the motor cool at highway speeds.... This is my first Baja that I've ever put a water pumper it.. So I have no idea what to expect when I plan on doing is placing the radiator and getting a bunch of pieces of yarn and taping them all over the back of the vehicle taking my go Pro and pointing them out the pieces of yarn and driving at highway speeds and see what the airflow does this will help determine my final radiators position.
Posted: Tue Jun 25, 2013 02:34 AM
good job on the exhaust I would say put the radiator out back and push the air with fans when it gets hot for them to run. By the way did I say it is looking good.
Posted: Tue Jun 25, 2013 02:37 AM
must of hit that return button
Posted: Tue Jun 25, 2013 03:10 AM
Thank you my friend... I am not supper happy with the way the exhaust came out .... but most of the ugly is hidden by the skid plate.
I really love the looks of this motor in this car... I must have researched 7 to 10 other motors before I chose this one.. I really hesitated going with this legacy technology.. The fuel economy is not what I would get with a more current technology but at least the horse power is there.. it just fit the bill.. This isn't going to be my daily driver so the loss in fuel economy was not a factor. When I looked at the application of how I was can use this vehicle the Subaru motor kept Rising to the top.. I was kind of looking forward to getting in the minds of the Honda engineers... If I was building a full-blown Baja and wasn't concerned about cutting the firewall I believe that the Honda motor would've been my best option..
I it even sat down in engineered a method to utilize the drive by wire system in my Baja,,,.. I think that would've been kind of cool... I've yet to see someone that is successfully grafted in a drive by wire system into an off-road vehicle..
Posted: Tue Jun 25, 2013 04:17 PM
I can't wait to see how it turns out.! If you wanted economy put a 1300cc on there. Smile
Is this engine lighter than a comparable Honda?
I'm sure there are pictures of Airflow tests on the VW somewhere on this doohicky called Google. LOL
I hope you find a way of keeping the cool factor of that engine, the radiator might hide it too much.
Posted: Fri Jun 28, 2013 02:46 AM
I dropped by Dalton's and hopefully I wasn't in the way too much or a distraction, but we got his exhaust welded up.
Here's a little Video. Smile
youtu.be/NjUM7jRybV0
Posted: Fri Jun 28, 2013 03:46 AM
not too much of a distraction.... I got the exhaust done... that's what I wanted to get done today.. it came out good... it will last ..
think I am going to work on the air intake and power steering next. I got a friend that wants to copy the wireing harness before I seal it up... so I am kinda holding off on working on it.
RicFab
RicFab
Posted: Fri Jun 28, 2013 07:31 AM
Hey Dalton....thanks for the link to this site. Will be keeping an eye on you. Look forward to hooking up this weekend to see what you are up to. Your bender looks like the one I have had for 25 years. Mine is a HOSSFELD and I have a ton of dyes for it...if you ever need a specific size...let me know.
Get out there and build something!
dave46
dave46
Posted: Fri Jun 28, 2013 10:58 AM
welding in a tee shirt shorts and without gloves .........
Posted: Fri Jun 28, 2013 02:48 PM
Those aren't tan lines...... They are flash burns. Cool
Posted: Sat Jun 29, 2013 02:46 AM
Thanks Rick.... I am really looking forward to seeing some of your work on this site.
Your work is Inspirational...
RicFab
RicFab
Posted: Sat Jun 29, 2013 06:07 AM
Dalton....Still interested in having me come by tomorrow? I have to run to Hyder in the morning but we plan to be back around 9-10am. I will call you on the way back to town.
Rick Mortensen
No new posts Projects and Builds Project Purple People Eater 3 Yasha7fold 1524 Project Purple People ...
 Wed Jul 12, 2017 08:03 PM
Yasha7fold View latest post
88 Dirtjunkie 52355 Project II
65 PaDan 49611 Re: My project
 Thu Feb 11, 2016 07:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 6863 Re: new project
38 NoKnowledgeCollegKid 17481 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
