Latest: kevinbaja68
Overall: 3591
Visitors: 106
Total: 106
05: Contact Admin
24: Pictures
39: Event Calendar
45: My Account
84: Event Calendar
87: Pictures
89: Home
98: My Account
My 69 project
1 2 3 ... 10 11 12 ... 78 79 80
Posted: Mon Jun 24, 2013 04:32 AM
Hope the toe feels better soon, so where's the radiator going?
Posted: Mon Jun 24, 2013 03:00 PM
My toe feels better today still purple.. I'm a put the radiator where it looks the best first and see if it works out.. Probably right underneath the rear window.. The problem with radiators they need to be in the airflow to work properly.
Posted: Mon Jun 24, 2013 06:23 PM
Airflow is a big deal or it'll overheat for sure. It also has to be somewhat level with the block too from what I've seen or you'll have coolant flow issues. Have you considered in front? Where's the condenser for your A/C?
Posted: Tue Jun 25, 2013 01:00 AM
there is no coolant flow issues with radiator height it only comes into play if the radiator is low on coolant is long as you keep your radiator topped off it's not an issue that I know.. Thought about putting the radiator up front briefly anyway I cut it, have airflow issues.. All three of my condensers are located in the front of the vehicle. One of my condensers is located in the airflow and two of them are by forced air only.. I'm hoping that the radiator I plan the use has enough surface area to keep the motor cool at highway speeds.... This is my first Baja that I've ever put a water pumper it.. So I have no idea what to expect when I plan on doing is placing the radiator and getting a bunch of pieces of yarn and taping them all over the back of the vehicle taking my go Pro and pointing them out the pieces of yarn and driving at highway speeds and see what the airflow does this will help determine my final radiators position.
Posted: Tue Jun 25, 2013 02:34 AM
good job on the exhaust I would say put the radiator out back and push the air with fans when it gets hot for them to run. By the way did I say it is looking good.
Posted: Tue Jun 25, 2013 02:37 AM
must of hit that return button
Posted: Tue Jun 25, 2013 03:10 AM
Thank you my friend... I am not supper happy with the way the exhaust came out .... but most of the ugly is hidden by the skid plate.
I really love the looks of this motor in this car... I must have researched 7 to 10 other motors before I chose this one.. I really hesitated going with this legacy technology.. The fuel economy is not what I would get with a more current technology but at least the horse power is there.. it just fit the bill.. This isn't going to be my daily driver so the loss in fuel economy was not a factor. When I looked at the application of how I was can use this vehicle the Subaru motor kept Rising to the top.. I was kind of looking forward to getting in the minds of the Honda engineers... If I was building a full-blown Baja and wasn't concerned about cutting the firewall I believe that the Honda motor would've been my best option..
I it even sat down in engineered a method to utilize the drive by wire system in my Baja,,,.. I think that would've been kind of cool... I've yet to see someone that is successfully grafted in a drive by wire system into an off-road vehicle..
Posted: Tue Jun 25, 2013 04:17 PM
I can't wait to see how it turns out.! If you wanted economy put a 1300cc on there. Smile
Is this engine lighter than a comparable Honda?
I'm sure there are pictures of Airflow tests on the VW somewhere on this doohicky called Google. LOL
I hope you find a way of keeping the cool factor of that engine, the radiator might hide it too much.
Posted: Fri Jun 28, 2013 02:46 AM
I dropped by Dalton's and hopefully I wasn't in the way too much or a distraction, but we got his exhaust welded up.
Here's a little Video. Smile
youtu.be/NjUM7jRybV0
Posted: Fri Jun 28, 2013 03:46 AM
not too much of a distraction.... I got the exhaust done... that's what I wanted to get done today.. it came out good... it will last ..
think I am going to work on the air intake and power steering next. I got a friend that wants to copy the wireing harness before I seal it up... so I am kinda holding off on working on it.
RicFab
RicFab
Posted: Fri Jun 28, 2013 07:31 AM
Hey Dalton....thanks for the link to this site. Will be keeping an eye on you. Look forward to hooking up this weekend to see what you are up to. Your bender looks like the one I have had for 25 years. Mine is a HOSSFELD and I have a ton of dyes for it...if you ever need a specific size...let me know.
Get out there and build something!
dave46
dave46
Posted: Fri Jun 28, 2013 10:58 AM
welding in a tee shirt shorts and without gloves .........
Posted: Fri Jun 28, 2013 02:48 PM
Those aren't tan lines...... They are flash burns. Cool
Posted: Sat Jun 29, 2013 02:46 AM
Thanks Rick.... I am really looking forward to seeing some of your work on this site.
Your work is Inspirational...
RicFab
RicFab
Posted: Sat Jun 29, 2013 06:07 AM
Dalton....Still interested in having me come by tomorrow? I have to run to Hyder in the morning but we plan to be back around 9-10am. I will call you on the way back to town.
Rick Mortensen
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3604 Project Purple People ...
88 Dirtjunkie 63768 Project II
65 PaDan 57962 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 8530 Re: new project
38 NoKnowledgeCollegKid 22201 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
