Visitors: 157
Total: 157
01: Home Page
12: Event Calendar
17: My Account
47: Event Calendar
71: Event Calendar
82: Event Calendar
99: Event Calendar
118: Event Calendar
136: Event Calendar
157: Event Calendar
My 69 project
1 2 3 ... 7 8 9 ... 78 79 80
Posted: Wed Jun 19, 2013 01:51 AM
Then late that die down lining it up with your drawing
Posted: Wed Jun 19, 2013 01:53 AM
The first band doesn't matter it only needs to be a 90
then mark on the ground where the die begins.. And then work your way around the project marking each bend where the die begins.
Posted: Wed Jun 19, 2013 01:55 AM
If you really need to be precise you will need the lock the two in place to keep it from being pulled through the Bender as you bend a simple clamp will do the trick.
Continue to mark each bend in the direction that you will be bending it until you complete each mark.
Posted: Wed Jun 19, 2013 01:57 AM
Posted: Wed Jun 19, 2013 01:59 AM
After each bend lathe the project back down on the drawing and mark where the die begins on the tubing so that you can line it up while it's in the Bender.
Posted: Wed Jun 19, 2013 02:01 AM
Repeat until done.
Posted: Wed Jun 19, 2013 02:06 AM
Cut the tube halfway
Posted: Wed Jun 19, 2013 02:07 AM
Done..
Posted: Wed Jun 19, 2013 02:14 AM
sorry
Done.
pepeazul
pepeazul
Posted: Wed Jun 19, 2013 04:22 AM
Slick and straightforward.
The guy I worked for back in high school used this technique. I adopted a center-out method later on and still use that because it just makes more sense to me and I prefer to do the layout in my head... You know what they say, measure once, cut twice Confused
pepeazul
pepeazul
Posted: Wed Jun 19, 2013 04:26 AM
BTW, I like the work boots! Are those OSHIT approved?
pepeazul
pepeazul
Posted: Wed Jun 19, 2013 04:31 AM
Dalton, You'll appreciate this.
www.pirate4x4.com/foru...ender.html
Posted: Wed Jun 19, 2013 06:37 AM
Wow, great info!
I like that homemade bender!
Posted: Thu Jun 20, 2013 01:46 AM
This is not a homemade Bender it is a very old hossfield Bender. It has been extensively modified so that it will make a bend over 180°.... On that note anything over 180° I have to pound off the die... The hydraulics were added the way that they are is because the previous owner did not like the way Hossfield hydraulics worked.
Posted: Thu Jun 20, 2013 01:48 AM
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 4260 Project Purple People ...
88 Dirtjunkie 67390 Project II
65 PaDan 60760 Re: My project
 Thu Feb 11, 2016 07:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 9120 Re: new project
38 NoKnowledgeCollegKid 23961 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
