Visitors: 131
Total: 131
07: Event Calendar
15: My Account
16: Event Calendar
37: Pictures
42: Home
44: Home
57: My Account
69: Pictures
98: Home
128: My Account
My 69 project
1 2 3 ... 6 7 8 ... 78 79 80
Posted: Tue Jun 11, 2013 01:33 AM
It is looking good. Coming along real nice. Take your time it your will get there
vwboat
vwboat
Posted: Tue Jun 11, 2013 03:19 AM
Dalton,
Lookin GREAT. No cut into the firewall, that's great also. Is the oil pan on yet,can't really tell from the pic. Nice install all around....
VWBOAT(john)
Posted: Tue Jun 11, 2013 03:49 AM
Posted: Tue Jun 11, 2013 06:14 AM
Getting there!
Posted: Sat Jun 15, 2013 09:14 PM
Last week I didn't make much progress... Everything I touched I either wasn't happy with or needed to finish something else before I could start.. I think I can do better with repositioning the throttle body if I go with the mandrel doughnut.. I ordered one last week. I decided that I wasn't happy with my original wiring harness that I was going to use to wire in the computer so I've decided to redo the auxiliary harness that I had built previously I think that will look cleaner and last longer. I built this car with four separate wiring harnesses.. The original stock harness, a auxiliary harness for running my aftermarket devices. A radio harness that runs on the opposite side of the car to prevent cross talk from my radios into the harness in the last harness was to be used to grafted in the OEM computer which I have decided not to use. And before you ask yes I know what each one of those wires does.
Posted: Sat Jun 15, 2013 09:26 PM
I've tilted the car 10° to allow the motor to come in and out easily.
Posted: Sat Jun 15, 2013 09:29 PM
Posted: Sat Jun 15, 2013 09:31 PM
Posted: Mon Jun 17, 2013 06:23 PM
Things went really well this weekend there were no major issues. I successfully grafted in eight additional wires into the auxiliary harness and just about completed the wiring. I finished rerouting the AC hoses, power steering hoses and built the duck work for the heater I ordered a bunch of stuff online that should be here this week. I started my work on the air intake system, exhaust system, and the modifications to rear cage. I'm going to use the stock radiator to check for placement so you will have to excuse me for doing such a poor job of mounting the radiator once I determine the best spot for the radiator I'll order a custom replacement.
Posted: Mon Jun 17, 2013 06:34 PM
vwboat
vwboat
Posted: Tue Jun 18, 2013 04:52 PM
Great pictures of you work, keep it up.
VWBOAT
Posted: Wed Jun 19, 2013 01:40 AM
Posted: Wed Jun 19, 2013 01:41 AM
Eventually all replace the starter it looks awful
Posted: Wed Jun 19, 2013 01:47 AM
I've mentioned to a few of you about the way that I a bend.. It is much different than the way that hossfeld tells you you need to bend. When I tried to tell experienced bender's they say the way I bend will not work.. I was taught by the best race frame builder in the Valley back in the day the bender I own is the bender that I was taught on. I nowhere near possess the skill of my teacher but with simple tools I can get really close. My bender is considered a reproduction bender in that regard all is I need to do is build something once in market down in my book the settings and pin positions. then I can create as many copies as I want at a high rate of speed. I hope that the photo illustration will help some of you understand what I been talking about...
Posted: Wed Jun 19, 2013 01:49 AM
Draw on the ground what you are trying to create subtract the width of the tube from your drawing so that you can be measuring from the center of the pipe.
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 2428 Project Purple People ...
88 Dirtjunkie 58496 Project II
65 PaDan 53876 Re: My project
 Thu Feb 11, 2016 07:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 7671 Re: new project
38 NoKnowledgeCollegKid 19903 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
