Visitors: 116
Total: 116
54: Event Calendar
63: Event Calendar
65: Event Calendar
113: Pictures
1450Bug Build
Posted: Tue Jun 11, 2013 01:37 AM
Looking good Looking real good
1450bug
1450bug
Posted: Tue Jun 11, 2013 04:20 AM
Thanks
Posted: Wed Jun 12, 2013 03:27 AM
where do you get your dipling done?
1450bug
1450bug
Posted: Wed Jun 12, 2013 05:32 AM
I do it myself. I have a full set up to 2 inches
Posted: Wed Jun 12, 2013 01:39 PM
where did you get them?
1450bug
1450bug
Posted: Wed Jun 12, 2013 06:59 PM
I have this set.
www.ebay.com/itm/5pc-B...257d226e6d
1450bug
1450bug
Posted: Thu Jun 13, 2013 06:00 PM
Look what just showed up.
Posted: Fri Jun 14, 2013 01:58 AM
WOW!
Posted: Mon Jun 17, 2013 12:38 AM
That is cool that looks like $$$.$$
1450bug
1450bug
Posted: Mon Jun 24, 2013 06:48 PM
Moved the motor back 3 inches and stubbed out the back for the rear bumper.
1450bug
1450bug
Posted: Mon Jan 19, 2015 05:13 PM
Well life and work have finally slowed down for me. Going to be back at this project again. Unhappy with the rear section of my chassis I decided to cut it off and raise it up. I also kicked the angle of the motor up a little more.
Tucked into the frame horns.
How it sits right now.
Posted: Thu Jan 22, 2015 02:58 AM
you will need to go with a bus box... or you will be breaking transmissions..
if you are going to stay air cooled go with an .002 if you think you will ever go with something over 2L you might need to go with an .091 bus box..
if you want to use a .002 until you need to upgrade to an .091 use a 3/8" spacer on the noise cone of your .002 so a .091 will slip right in without changing any of your mounts.
1450bug
1450bug
Posted: Thu Jan 22, 2015 07:09 AM
That has been on my mind for a while. Going to give dons bus box a call tomorrow to get some guidance on what I need. Going to run the 1776 for a while. I am more worried about the 33 inch tires and 18 inches of travel on the type 1
Posted: Thu Jan 22, 2015 03:17 PM
Do yourself a favor and call Bill at Arizona Transaxle. Or depending on how much you want to spend I might know where there is a perfectly good, stock 002 out of a bay window bus
Posted: Thu Jan 22, 2015 03:25 PM
call Bill at AZTRANSAXLE.. 602-269-1444 ... I have kind of heard some not so good things about Dons bus box and his work. read about it on www.thesumba.com(I think this is right). there has been some posts on Craig's list also. I just spoken to a few fokes that have had him work on there trans.
26 1963BAJA 7730 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
Cheapskate special
26 Azdrtdog 11853 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5371 New Class 11 Build - P...
101 SuburbanLegend 136395 Carbon Footprint...aka...
 Thu Oct 08, 2015 08:28 PM
No new posts VW Volkswagen & Baja Bug General Discussion Beginner Baja build help? 3 prorcguy 3362 Beginner Baja build he...
 Thu Oct 16, 2014 04:32 PM
