Latest: xbluegto
Overall: 3573
Visitors: 184
Total: 184
24: Pictures
30: Home
106: Event Calendar
147: Event Calendar
150: Baja Forums
152: Event Calendar
165: Event Calendar
166: Baja Forums
178: Baja Forums
180: Pictures
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Our new baja- Biblethumpncop
Post Post subject: Our new baja- Biblethumpncop
Posted: Fri Mar 08, 2013 08:34 AM
What the heck llok like an AzBaja night at sonic. But only is all the cars show up Smile
Still rocking the Red Van in 2013 Smile
Posted: Fri Mar 22, 2013 06:01 AM
Sadly, the engine won't pass emissions with the rebuilt Kadrons, and I'm not putting anymore money or time into it. Perri and Dirtjunkie have been great and tried to help. The car really runs awesome, but it just won't pass the 1973 standards. It would be fine if I still lived in Flagstaff. I'll be listing the car for sale or will sell the engine seperately while my son and I still work on the body. Oh well, it would be an awesome engine in a pre-67.
Thanks again Perri.
Posted: Fri Mar 22, 2013 06:30 AM
why not just borrow another engine to smog it or bolt on a cat?
Posted: Fri Mar 22, 2013 08:08 AM
what dirtjunkie said!
when my grandpa used to have his emissions required baja we would take the stinger off, bolt a cat on with a stinger welded on the end of it and take it through emissions. little adjusting of the carb and it would pass no problem.
Posted: Fri Mar 22, 2013 01:24 PM
It isn't close enough for a cat to work. I will be taking a long break from the VW scene.
vwboat
vwboat
Post Post subject: Re: Our new baja- Biblethumpncop
Posted: Fri Mar 22, 2013 03:12 PM
Sorry about your car John, hope something works out for you whatever you decide to do.
VWBOAT(john)
Posted: Wed Mar 27, 2013 11:04 PM
I got something in the works... Perhaps this project isn't dead yet after all....
Posted: Wed Mar 27, 2013 11:27 PM
The project lives!!!! Keep us in the loop.
vwboat
vwboat
Posted: Wed Mar 27, 2013 11:41 PM
Sounds good John, Keep on trying and don't give up..
John
Posted: Thu Mar 28, 2013 05:04 PM
It is a cool car. By next fall it should look really nice. Keep on plugging along.
Posted: Thu Mar 28, 2013 06:46 PM
PM sent
Posted: Thu Apr 11, 2013 11:56 PM
Here's the latest- although the 1955cc engine was awesome, it didn't pass emissions. I traded it for a rebuilt 1641cc to a fellow named Marty that rebuilds engines. I'll put the fresh 1641 cc in this weekend and try emissions again.
I focused on the K.I.S.S. principal. Dual Port, dual relief, doghouse internal cooler, rebuilt 34pict, alternator, petronix on 009, heater boxes with header and glasspack. I'll hook up the heat, and paint and interior on the way.
It is no longer the high performance car sitting in the garage because it won't pass smog. Now its the mild driver...
Last edited by biblethumpncop on Fri Apr 12, 2013 12:01 AM; edited 1 times in total
Posted: Fri Apr 12, 2013 01:38 AM
So you passed???
Posted: Sat Apr 13, 2013 09:10 PM
It may not have the screaming 1955 any more, but your baja has a stock suspension. The 1641 will get good mileage, have enough get up and go to run down the freeway, but not overpower the car off-road and put it on it's lid.
Suspension is the key to going fast off-road. Without it, a big motor is a waste of power and gas. I think you are going the right direction.
Posted: Thu Apr 18, 2013 01:11 AM
I had today off, so I worked on the baja. I changed the reverse switch on the trans because it was leaking. Then I installed the rebuilt 1641cc engine. Then off to emissions. Passed everything with flying colors- except hydrocarbons at idle. 1038 and 400 is allowable. Time to tweek the carb and try again!
4 Admin_AzBaja 5699 Baja Bugs on Wiki need...
1568 mufasavnvmc 902776 Re: what did you do to...
285 MusicManiac 218778 Re: Baja sightings
0 Northmountainauto 245 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1476 Baja hiding in Chandle...
