Visitors: 92
Total: 92
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- lifted spindles and disc brake update
vwboat
vwboat
Post Post subject: Re: lifted spindles and disc brake update
Posted: Sat Mar 16, 2013 04:21 AM
Hi Dalton thanks for the reply and info
On the studs. I have found longer lug bolts that will allow me to install the spacers I want. Napa had some longer lug bolts.l think I will be ok.
vwboat
vwboat
Posted: Sat Mar 16, 2013 11:44 PM
Ok, so I am in better mood today. Spacers drilled to match 4 lug pattern and new longer lug bolts work good. A little of a pain getting everything aligned up when mouting wheel but I will eventually go with at least 2 press in wheel studs to help with that issue.
Now to the alignment shop and hopefully all will be well.(I have said that before). Hope tlo see all at the bug a rama,..............
VWBOAT(John)
Post Post subject: lifted spindles and disc brake update
Posted: Mon Mar 18, 2013 05:01 PM
Pictures!
vwboat
vwboat
Posted: Mon Mar 18, 2013 11:46 PM
As soon as I figure out how.
Posted: Wed Mar 20, 2013 03:22 AM
www.photobucket.com
copy the link to the "message" box
vwboat
vwboat
Posted: Wed Mar 20, 2013 11:27 PM
Thanks Dalton for the info on the pictures. I will try and see if I can do this. Baja is finnally done adding the lifted Kustom1 spindles and the disc brakes. Had the front and rear alighment done today and all is well. Thanks for everyones help..
VWBOAT (John)
Posted: Thu Mar 21, 2013 05:39 AM
So.... when are we going rideing somewhere?
vwboat
vwboat
Posted: Thu Mar 21, 2013 03:08 PM
Hi Dalton,
Although the car is done and ready, I have a 7 month old granddaughter in the hospital, been in for the last three months. I am babysitting her 3 year old sister 24/7 right now but that should change in the next couple of weeks.
Hope to make the Bugarama on this Sat for awhile, and will be ready for some fun in the dirt soon.
VWBOAT(JOHN)
thing
thing
Posted: Fri Mar 22, 2013 05:22 AM
VWBOAT(JOHN)
Bugorama is Sunday. If you go Sat, no one will be there. Very Happy
vwboat
vwboat
Posted: Fri Mar 22, 2013 08:58 PM
I WILL BE THERE........JUST KIDDING, JUST FOUND OUT THE THING IS SUNDAY NOT Sat.
THANKS ANYWAY THING. See you Sunday.
VWBOAT(JOHN)
1 LittleBaja 2195 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 2034 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 3027 Re: Brake light switch...
 Sun Nov 17, 2013 07:21 PM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3327 Re: bj front disk brak...
 Thu Dec 13, 2012 02:03 PM
what are yall's set'ups
7 vindeta 14167 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
