Visitors: 111
Total: 111
33: My Account
71: My Account
73: My Account
102: Event Calendar
FABINC 5-1600 Build
1 2 3 4 5 6 7 8 9
Pritts
Pritts
Posted: Mon Jul 30, 2012 04:48 AM
What a fun build project. Great job!
1970 VW Baja
Work in Progress
Gilbert, AZ
bkennedy96
bkennedy96
Posted: Thu Aug 02, 2012 10:09 PM
Awesome build that thing looks great! Is that stock trailing arms and link pin beam in the front suspension, or are they extended at all??
bkennedy96
bkennedy96
Posted: Thu Aug 02, 2012 10:10 PM
Posted: Mon Sep 03, 2012 06:04 PM
STICK A FORK IN IT CAUSE IT IS DONE!!!!
Time to move onto the class 5 resurrection project.
I'm selling it or trading it! Whichever comes first!
5-1600 MOVIE
Posted: Mon Sep 03, 2012 10:55 PM
I posted this on the video:
Quote::
Nice video and a pretty neat car. I've liked a number of things you've done in this build. As an offroad race Tech Inspector...There are a few things I have issues with. But it's a cool car. Anybody wants to know my Tech issues can email me @ Dustymojave at Hot Mail {Dot} Com
I like the car and the video. To point out some rules violations in the build of the car:
- Seats set back in the cab: Video 2:43-46 - Class rule does not allow
- Aftermarket pedals and master cylinders: Video 1:45-47 - Class rule requires stock pedal assembly and master cylinder in stock location.
- Holes in Firewall around bumper to cage tubes are too big: Video 1:31-35 / 2:11-17 - Safety rule
- Heater Ducts should be closed up as "firewall" openings: Video 0:59-1:05 - Safety rule
- If there is a fuel cell inside the cabin, there should be a firewall between it and the seats. It should cover from floor to shoulder height and body side to body side. If this firewall is built like that, the holes and heater ducts mentioned above can be ignored. - Safety rule
- Fuel filler needs a splash plate so refueling can't splash the co-driver. Video 2:01-10 - Safety rule
- At 1:27 + 1:45 in the video...lower beam brace dead ends against the A pillar. Could collapse the A pillar in a front hit. Upper braces not so much of a problem in this regard due to the vertical section above the beam which would allow this tube to bend there without endangering the A pillar. But push from the bumper to the horizontal part of the upper beam brace WOULD transfer loads to the A pillar. Speaking as a fabricator, that vertical section of the upper beam brace should be angled at 45* or lower, but then at the A pillar there should be an 'X' in the door opening backing up the upper brace. That upper beam brace tube does very little structural strength wise as it is. The lower brace should meet the A pillar at the door sill bar. - These are basic fabrication and roll cage structural design issues.
These issues will probably get past some Tech Inspectors and some organizations... In fact I KNOW they will. But they violate the SCORE, BITD, SNORE, and MORE rules for a 5/1600 race car. Some of the violations could get the car protested by competitors and disqualified.
I've not seen the rest of the car well enough to verify that the rest of it would pass Tech Inspection. These are the issues I can see from the video and this thread. I'm NOT trying to be a mean bad guy. Just pointing things out which you and others may not know. Like I said above. I LIKE the car and a lot of things done in building it.
Posted: Mon Sep 03, 2012 11:16 PM
Not too concerned about anything that will not pass tech. I have no plans to race it now or in the future. Car would have no problem running any CODE or RECORD sanctioned race along with ADRA and SADR races here in Az.
At worst it is a really fun play car for someone. I have no need for it any longer, so I hope someone can use it.
Thanks for the feedback though. I now have an old class 5 car I need to get on the road.
Posted: Tue Sep 04, 2012 12:56 AM
That was what I had figured through most of your build. But the thread IS called "5-1600 Build"...And it does have race numbers on the sides in the video and the left photo below. Lot of calling it a racer for one which is not intended to be raced. It lead me to think you had intentions of using it or selling it for racing in 5/1600.
I don't recommend gambling on that as Art Savedra of A.R.T.S. does Tech there as well as in the US races and has been advising the Tech Inspection for the new HDRA organization as well. This past week we were working alongside a bunch of the ADRA people at the HDRA Dusk-Til-Dawn race.
As a "Class 5 car" is it to be like this 5/16, a looks-like non-racer? or do you have other plans for it?
Posted: Tue Sep 04, 2012 01:55 AM
The class 5 car was a former MDR/SNORE car we raced 2006-2009. That one will be rebuilt as a prerunner. I currently have an ecotech 10 car we race.
I have raced CODE and Record in the past. Believe me, they would rather let someone slide a little on tech then lose and entry fee. They won't overlook obvious safety infractions, but they have a little wiggle room.
I know that here in the states the safety concerns are very high and would expect them to be adhered to strictly.
Posted: Sat Sep 08, 2012 06:14 PM
I messed up my video library somehow and was told the video did not work.
I have since fixed it.
Click to see Fab_Inc. movie
Posted: Sun Feb 17, 2013 09:33 PM
Two guys from Texas with a pocket full of cash and a trailer showed up today and took it away. 5-1600 is gone. Time to put a little coin towards resurrecting the class 5 car.
yee haw!
Time to spend a little cash on this one.
73square
73square
Posted: Sun Feb 17, 2013 10:03 PM
Congratulations! Can't wait to see what you do on the next project.
That's done - Next!
64vwbug
64vwbug
Posted: Sun Feb 17, 2013 10:52 PM
That's awesome tony. Can't wait to see what the next one turns out like.
DirkBiggler
DirkBiggler
Posted: Mon Feb 18, 2013 01:46 AM
I'm happy for you that it's gone, but I'm sad to see it go. This car has been a big inspiration for me & what I eventually hope to do with my build.
Posted: Mon Feb 18, 2013 03:56 AM
Yeeehaawww! Congratulations!
Posted: Thu Feb 21, 2013 01:25 AM
Good! and Bad! Happy folks all over the place I'm sure.
1 2 3 4 5 6 7 8 9
26 1963BAJA 5993 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
Cheapskate special
26 Azdrtdog 10004 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 4746 New Class 11 Build - P...
101 SuburbanLegend 128167 Carbon Footprint...aka...
 Thu Oct 08, 2015 08:28 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 3118 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
