Latest: Curtis
Overall: 3613
Visitors: 99
Total: 99
07: Event Calendar
38: Event Calendar
50: Event Calendar
62: Event Calendar
64: Event Calendar
65: Event Calendar
67: Pictures
83: Home
84: Home
90: Pictures
93: Home
97: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Our new baja- Biblethumpncop
Post Post subject: Our new baja- Biblethumpncop
Posted: Sat Feb 16, 2013 09:29 PM
I checked TDC by pulling the #1 plug. 22-25* is the marking on the pulley where TDC should be. Forget the 50* I wrote above. My distributor is fully advanced around 45*. I need a new pulley and maybe a distributor.
vwboat
vwboat
Post Post subject: Re: Our new baja- Biblethumpncop
Posted: Sun Feb 17, 2013 12:54 AM
Sounds like your getting close. New raised spindle/disc brake from Kustom1warehouse on the way to replace the EMPI kit that was bad.
Posted: Sun Feb 17, 2013 04:22 PM
I think your destributor is 180 degrees off... commom when you bild a motor you index the destrbutor 180 degrees off... I am surpise it started... put it to TDC mark where the rotor is .... pull the distributor out a little rotate the rotor 180 put it back in .. redo wires and try again...
look forward to rideing with you.
Posted: Sun Feb 17, 2013 04:34 PM
I am useing Kustom1warehouse spindles.... I have a problem with them when I went to put the calipers on it was off a little??!! I was in a hurry so I machine the calipers to fit .... I will need to replace my calipers someday I dont like the way it came out but calipers are cheap... I think a better way to fix this problem is to use machine washers on the spindles to move the rotor to the correct poition... hopefully you wont have this problem.
let me know if you need help.. I done some R&D on this problem.
vwboat
vwboat
Posted: Sun Feb 17, 2013 04:45 PM
Thanks Dalton for your info. I just hope I get them, been trying since Dec 2012 to get the front of my car finished. Hope to make your 400 miler this year.
Vwboat(john)
Posted: Mon Feb 18, 2013 03:30 AM
Sweet.... I will be takeing the baja again this year ... I will lead the slower cars up ... the kids are still tooo small to be tent camping so we will be staying at strawberry in a hotel. kenny will will take the campers to the camp site.
Posted: Mon Feb 18, 2013 03:51 AM
I'm taking the car to Perri in the morning. I have a second Bosch 009 I'll bring along as well. I am anxious to drive my baja!
Posted: Tue Feb 19, 2013 12:30 AM
Perri to the rescue from my ignorance. I was wrong on the TDC. It was properly labeled at 0*. Also, I didn't put a fuel pressure regulator on the engine when I switched to the Kadrons. 3 out of 4 plugs were fuel fouled and the baja was missing. It's a good thing I had it towed to Perri.
I love this baja community! I've gotten help on this car by Perri, Bugzylla, Dirtjunkie, Wideopenmotorsports, VWboat and 64VWBug. Thanks to each of you for your help!
Last edited by biblethumpncop on Tue Feb 19, 2013 04:04 AM; edited 1 times in total
64vwbug
64vwbug
Posted: Tue Feb 19, 2013 03:17 AM
Your welcome John. Glad to help when I can. I think everyone is waiting to see it run. Hope he gets it all worked out
vwboat
vwboat
Posted: Wed Feb 20, 2013 12:11 AM
Glad you got it sorted out. Should be a great ride. Still waiting for my new Kustom1 spindles.
John
Posted: Mon Feb 25, 2013 07:50 PM
Your welcome. Wait to you see it go off road you'll idle over, up and through stuff where before you had to floor it.
Posted: Mon Feb 25, 2013 09:37 PM
Emissions still need work. The car runs awesome and has sooooo much power! Jeff at the Kaddie Shack is going to look at his formula and see what needs adjusted before I take it back through. I'll be bringing out to Perri shortly!
Posted: Mon Mar 04, 2013 11:52 PM
The baja is back at Perri's, getting the dual carbs tinkered with. Maybe he'll chime in here and give a progress report.
Posted: Thu Mar 07, 2013 03:26 PM
Sadly it is just hanging out waiting its turn.
At least it has a couple of good buddies for company.
73square
73square
Posted: Thu Mar 07, 2013 08:48 PM
It does look like a full house! What is that a type 3 in the background? What the heck? Wink
That's done - Next!
5 Admin_AzBaja 11119 Baja Bugs on Wiki need...
1569 mufasavnvmc 1175110 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 283383 Re: Baja sightings
103 SuburbanLegend 165066 Carbon Footprint...aka...
 Tue Sep 03, 2019 03:15 AM
Mykul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 3261 FREE VW BAJA'S
