Visitors: 129
Total: 129
07: Event Calendar
21: Event Calendar
29: Event Calendar
62: Event Calendar
114: Event Calendar
126: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Our new baja- Biblethumpncop
Post Post subject: Re: Our new baja- Biblethumpncop
Posted: Tue Jan 29, 2013 06:06 PM
You probably already know this but grease the filter base plate, wing nut and filter flat edges. Lots of KN filter oil and foam outer wears. a couple of bolt on shields to keeep them away from direct tire dust would help.
Post Post subject: Our new baja- Biblethumpncop
Posted: Wed Jan 30, 2013 03:08 PM
Thanks for the tip Perri.
Posted: Thu Jan 31, 2013 04:16 AM
Is it all together yet?
Posted: Thu Jan 31, 2013 05:04 AM
I will get with Dirtjunkie at the beginning of next week to work on it.
Posted: Tue Feb 05, 2013 10:53 PM
Tomorrow's the big day! Transaxle swap, dual Kads installed, alternator replaced and try emissions.
73square
73square
Posted: Wed Feb 06, 2013 02:55 AM
Good luck dude. You been workin on this a while.
That's done - Next!
Posted: Wed Feb 06, 2013 02:11 PM
Looks like you might make the Florence event.
Posted: Fri Feb 08, 2013 02:31 AM
if it wont pass emissions..... I have an idea,,..
Posted: Fri Feb 08, 2013 02:42 AM
Emissions with an air cooled motor "socks" to say the least. The easiest way is to replace the motor with a water pumper you'll pass every time. But not a lot of us have that desire so there's a couple things you can try
1)borrow someone else's motor and take it through missions and then put your old motor back in your car
2) find a place in your exhaust system to temporarily bolt on a catalytic converter and take it through emissions
3) play with fuel additives-- I've never had much luck with this.
4) register your vehicle outside of Phoenix so you don't have to do emissions..
If I can think of anything else...i will let you know.
or maybe I am jumping the gun... maybe you passed..
Posted: Fri Feb 08, 2013 03:18 AM
Car isnt back togther yet, gotta clean up the PO's wiring flaws in the engine compartment as well as clean up years of dirt, grease and oil. Should be back togther Sunday.
Posted: Mon Feb 11, 2013 06:35 AM
95% back together today, took a lot to get everything back together and to fit with the dual carbs. Including having to re shape the wheel well area on the right rear just to get the carb to fit (it was hit there before probably why its a baja now) Had to hammer it out over an inch! Just need to hook up a couple more wires, change the gear oil, fill up the engine with oil, and tighten a couple thing and I should be able to fire it up tomorrow night.
Posted: Mon Feb 11, 2013 03:49 PM
I think you maybe getting a little excited to turn the key? Laughing
Posted: Fri Feb 15, 2013 03:02 AM
Dirtjunkie told me it's ALIVE!!!! I'll pick it up tomorrow. He's a great friend to help me get my car going when I couldn't.
vwboat
vwboat
Posted: Fri Feb 15, 2013 02:47 PM
Great news about your car. Mine is still up on jackstands waiting on resoloution of bad EMPI spindles.
Posted: Sat Feb 16, 2013 06:19 AM
I picked up my baja today. Dirtjunkie was a great help. I tried to time the 009 distributor tonight and found something really odd. My degree pulley appears to be off by 50 degrees!
I used the timing light on #1, and even popped the distributor cap and rotated the engine until the rotor pointed to the 4 o'clock position. It read 50*. I tried adjusting it while running, and it liked it best at 60*. I can only guess that my pulley was mismarked. I didn't try emissions yet.
4 Admin_AzBaja 5225 Baja Bugs on Wiki need...
1567 mufasavnvmc 856246 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 209516 Re: Baja sightings
Off-road event
1 wideopenmotorsports 381 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3317 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
