Visitors: 92
Total: 92
57: Links
60: Event Calendar
67: Event Calendar
87: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- ghostrider starting a new baja project
GHOSTRIDER
GHOSTRIDER
Post Post subject: ghostrider starting a new baja project
Posted: Sun Dec 30, 2012 04:36 AM
i bought this baja bug.... it was just a cage and a body shell added some boxed in trailing arms bus trans and some wheels working on the front end now to get some wheels on it so i at least make it a roller so i can move it around .....the first day getting it home and looking it over real good ........the second day started adding some of the parts like the trans 3 rib bus ..... rear trailing arms irs
day three ordering parts on line.. front trans mount and the beam adjusters and the heavy duty leaf packs
GHOSTRIDER / BAJAJUNKIE /AKA JEFF CLARK
ANTELOPE VALLEY BAJAS
ANTELOPE VALLEY MOJAVE DESERT CALIF.
GHOSTRIDER
GHOSTRIDER
Post Post subject: Re: ghostrider starting a new baja project
Posted: Sun Jan 13, 2013 05:52 AM
Posted: Sun Jan 13, 2013 08:42 AM
Was your Baja pink too at one point in it's life? Mine was a hot pink. Every time it chips you see a pink spot.
Posted: Sun Jan 13, 2013 05:32 PM
Nice find. Looks like it has been outside as long as some of mine.
GHOSTRIDER
GHOSTRIDER
Posted: Mon Jan 14, 2013 03:29 AM
the front end looks like it.... the front end under the black primer spots is red paint light red primer and the the rest of the body looks like it used to be a medium blue and they started to paint the roll cage black metallic and the rear cage was painted by mother nature rust brown I was thinking of painting the body a medium blue and the roll cage a metallic gray
4 Admin_AzBaja 5559 Baja Bugs on Wiki need...
1568 mufasavnvmc 887000 Re: what did you do to...
285 MusicManiac 215398 Re: Baja sightings
0 Northmountainauto 18 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1056 Baja hiding in Chandle...
