Latest: strike77
Overall: 3575
Visitors: 108
Total: 108
12: Pictures
17: My Account
25: My Account
39: Event Calendar
54: My Account
74: Pictures
101: Pictures
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Our new baja- Biblethumpncop
Post Post subject: Our new baja- Biblethumpncop
Posted: Wed Jan 02, 2013 04:38 PM
Cool Progress!
Posted: Thu Jan 03, 2013 07:31 PM
I like the yellow and white too. Looks like classic race car
LT_Spenny
LT_Spenny
Posted: Fri Jan 04, 2013 07:57 AM
Funny my bug has the same sun roof as yours. It's after market right because at the time I got my baja I hadn't seen any sun roofs like that.
Build: "Lucky 13"
Posted: Mon Jan 07, 2013 04:06 AM
This week, I tightened the oil sending unit and oil filter, both which were leaking. I have great friends in the VW community! I Dirtjunkie, Wideopenmotorsports and 64VWBug helped me a bunch this week.
I removed the spare tire mount, and got a rear seat in great condition for $30! I also picked up a set of KYB shocks for the front. The brake pedal now remains in the forward position, rather than falling towards the driver. I also swapped steering wheels.
These accomplishments may seem small, but make the baja much more driver friendly. Friends are awesome!
Post Post subject: Re: Our new baja- Biblethumpncop
Posted: Mon Jan 07, 2013 07:51 AM
Amazing how small details make big changes. Good to see more forward motion. you get your carbs back yet?
Posted: Mon Jan 07, 2013 04:57 PM
Kaddyshack called on Friday, and charged my card. I hope to get them back this week, but next week is more realistic.
Posted: Tue Jan 08, 2013 03:03 AM
Does one side of your wallet feel a lot lighter? Smile
Posted: Tue Jan 08, 2013 04:01 AM
Yup! And as low as my 4th gear is, all that power is wasted! Time to re-gear!
Posted: Fri Jan 11, 2013 06:19 AM
I should be bringing a type 1 transaxle home this weekend that was said to be rebuilt. Unknown specifics at this time. I'll install it when Dirtjunkie and I pull my engine, install the Kads, and change my alternator.
I will try driving it for a while at speeds above 50mph... Then save up to regear my current trans, or install a superdiff in the new one and sell my current trans.
Fun stuff!
Posted: Sun Jan 13, 2013 05:52 AM
Using parts from our other project, I am trading for another Type 1 trans. It is reported to have been rebuilt, with only 1 season on it. Thanks Matt! I will install it, with Dirtjunkie's help, when I install the Kadrons- hopefully this week. My alternator is only producing 12.4 volts, so I'll replace it as well and put the original style dog house tins on because I miss having heat! The 1955cc enging has a large Tri-mill exhaust with J-tubes. Since I need performance exhaust, stock heater boxes are out. But- that gave me an idea.
I may have my friend weld exhaust pipe to run along side the exhaust pipe/J-tube. The heat from the exhaust should warm the new pipe. I will hook fresh air hoses from the dog house tin to the new pipe.
I hope to take the valve off of a heater box and weld it to the other end of the new pipe. Then run a dryer vent from the new pipe's valve to the body. This would allow me to use a heater. I would need to lengthen the heater cables, but I need to do that anyway since my car has a 3" body lift.
The car is coming together- and I like it!
Posted: Sun Jan 13, 2013 06:06 AM
I believe on The Samba there is a detailed build of custom heater boxes he used stock out covers and something that looked like steel wool but stainless stainless that looked like 1/4 strands woven together. Make sure your J tubes are 1 and 1/2 inch tubing or the engine will overheat due to the exhaust not getting out fast enough.
Posted: Tue Jan 22, 2013 06:10 AM
I wired in a Ford Solenoid tonight. I was having issues starting from the starter button, but it would work if I reached under to the starter and jumpered it. I hope it works. It did on a bus I had 10 years ago.
I also exchanged an alternator that was junk at my local auto parts store. They warrantied it for me, and they didn't have to. Awesome customer service! That's probably why they keep seeing my ugly mug...
Posted: Fri Jan 25, 2013 06:24 AM
My Dual Kads were shipped today by the Kaddyshack. Delivery date is expected on Monday, the 28th. That's 2 days before my temp registation expires. Hmmmm, the car may get benched for a few days until I can swap the carbs and emissions test the car. I'll change the alternator and transaxle at the same time.
Posted: Tue Jan 29, 2013 03:07 AM
They're here.....
Posted: Tue Jan 29, 2013 04:59 AM
Looks like its time to dig in. Let us know how they work
4 Admin_AzBaja 5902 Baja Bugs on Wiki need...
1568 mufasavnvmc 925753 Re: what did you do to...
285 MusicManiac 223599 Re: Baja sightings
0 Northmountainauto 664 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2308 Baja hiding in Chandle...
