Visitors: 78
Total: 78
11: Pictures
17: Pictures
19: Event Calendar
23: Home
24: Event Calendar
37: Home
39: Home
42: Pictures
50: Event Calendar
60: Home
64: Home
76: Home
77: Home
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- New project: ECOTEC!
1 2 3 4 5 6
cycleguy1979
cycleguy1979
Post Post subject: New project: ECOTEC!
Posted: Tue Dec 18, 2012 04:30 AM
I'll take a look at that tomorrow. I am turning wrenches again all day tomorrow on it, and hope to be actually shifting gears tomorrow.
Ecotec 2.2 out of a 2008 cobalt. 4 seat sand cars unlimited. Swing axle trans.
cycleguy1979
cycleguy1979
Posted: Wed Dec 19, 2012 04:59 AM
Well, got a lot more done today, but still won't run under it's own power. The injectors just will not fire, period. I can keep it running by dripping fuel into the throttle body, but no injectors. Everything else seems to be in good working order. Got every single thing done except mounting the seats and belts. I guess i'm gonna have another conversation with phil tomorrow, and if he can't help me I will be looking for a good auto electric place to diagnose this thing, as i'm just about out of my league with all these electronics.
pepeazul
pepeazul
Post Post subject: Re: New project: ECOTEC!
Posted: Wed Dec 19, 2012 06:54 PM
Sure you got the fuel pump wired right and output on the right side? There is a fuel pressure gauge connector on the fuel rail. I think Orielly's will loan you a pressure gauge to verify you have enough pressure at the rail. Are you using the vette filter/regulator?
pepeazul
pepeazul
Posted: Wed Dec 19, 2012 06:56 PM
Here's a couple notes about that
pepeazul.com/2012/09/2...l-or-swap/
cycleguy1979
cycleguy1979
Posted: Wed Dec 19, 2012 07:23 PM
Yup, got the fuel system working to perfection. Talked to phil again this morning. He says that my wire harness and computer was his guinea pig, and that neither one had actually been tested to be in working condition before it left his place. I am pulling my damn hair out at this point. I'm either gonna pull the computer and harness off today and put it in the mail, or i'm gonna need to find a good auto-electric place that can figure out what the hell is going on. Who knows, there may be a bad sensor on the junkyard engine I got, who knows. It really could be anything at this point, and for now i'm washing my hands of it because I don't have the tools or skills necessary to deal with all these electronics.
pepeazul
pepeazul
Posted: Wed Dec 19, 2012 08:37 PM
Damn, that sucks.
I have not dealt with these guys beyond a phone conversation, but one of the guys at loper's referred me to them before I went with Phil.
www.umstuning.com/
They do have hptuners and have experience with the ecotecs in rails. The shop next door to them was building a 500HP ecotec powered drag car that ums was doing the tuning on...
Posted: Wed Dec 19, 2012 08:47 PM
Sorry to hear that and I hope Phil stands by his work and makes it right for you. Doesn't help diagnosing an issue if you don't know if the ECM is even right.
OBDII Still showing Fuel issues or has that changed after replacing the Pump?
I should be out on your side of town (Sun City Area) tomorrow afternoon sometime, I could drop by with my PC and OBDII Reader if need be.
PM Me your address and # if you want me to see if I can stop by.
cycleguy1979
cycleguy1979
Posted: Wed Dec 19, 2012 09:15 PM
I just got done removing the complete wire harness and computer off of the car. I'm sending it back to Phil. First, he is gonna plug my computer into a known good working car, and see if it causes problems. Then, if that works, he is gonna install my wire harness on the same car. Should have everything back in a few weeks. Really sucks, because I was planning on driving this thing over christmas, but that's not gonna happen now. I will keep you all posted on what happens in the next few weeks. Never knew building something could just be this difficult and confusing. On the other hand, my transmission is also screwed up and will not shift into 3rd gear, so I may just take the engine and trans out again so AZ transaxle can rebuild it for me. One thing after another. Just can't win no matter how hard I try.
Posted: Wed Dec 19, 2012 09:38 PM
We've all been there so don't get too discouraged. Smile
Keep us posted.
cycleguy1979
cycleguy1979
Posted: Sun Jan 13, 2013 04:00 AM
Time for an update. Exactly 3 weeks after I sent my wire harness and computer back to phil in the mail, I got it back yesterday. Turns out the computer was no good, the harness had nothing to do with it. So he send me another computer. I put the harness and computer back on lastnight, crossed my fingers and hit the start switch. Good news!! I barely touched the switch and it fired right off. Seems to run great. The oil pressure gauge was reading about 85psi, and the water temp. got up to about 185 before my fans cut on. Everything seems to be working exactly the way it should. The idle is hanging though, If I fire it up, it will sit and idle perfectly. But, if I give it any throttle, it has a hard time coming back down to a regular idle. It is hanging about 2500RPM's, not sure why yet. The only way I could get it to come back down is to cut the fuel pump off for a few seconds. The brakes need to be bled a little better, I have to pump them 3-4 times before they work. And, I need to adjust the clutch, not big deal. I wasn't able to shift gears yet because the clutch is out of adjustment, but let me tell you this thing has some POWER. The power to weight ratio is amazing. I must say, I wasn't expecting it to have quite this much snort! I'm a happy camper! A few more days of fooling with it and i'll probably be done with it.
cycleguy1979
cycleguy1979
Posted: Sun Jan 13, 2013 04:01 AM
Posted: Sun Jan 13, 2013 04:45 AM
Now you can get ready for the Feb 2 run. Chris and I ran Sycamore today for several hours and his eco tec also scoots.
Posted: Sun Jan 13, 2013 05:15 AM
Congrats!
pepeazul
pepeazul
Posted: Sun Jan 13, 2013 05:08 PM
That's great news!
Check for that vacuum hose for the brake booster. Before I plugged mine off, it caused the motor to idle a bit erratically.
Chris
cycleguy1979
cycleguy1979
Posted: Mon Jan 14, 2013 03:22 AM
Which vacuum hose are you talking about? Where is it at on the engine?
1170 Dalton 260845 My 69 project
 Wed Dec 06, 2017 01:38 AM
No new posts Projects and Builds Project Purple People Eater 3 Yasha7fold 1260 Project Purple People ...
 Wed Jul 12, 2017 08:03 PM
Yasha7fold View latest post
88 Dirtjunkie 49685 Project II
65 PaDan 47493 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 6542 Re: new project
