Visitors: 259
Total: 259
22: Pictures
23: Pictures
25: Pictures
64: Event Calendar
65: Event Calendar
132: Event Calendar
134: My Account
138: My Account
139: My Account
140: My Account
141: My Account
142: My Account
143: My Account
144: My Account
145: My Account
146: My Account
154: Baja Forums
180: Pictures
181: Pictures
188: My Account
189: My Account
190: My Account
191: My Account
197: AMAZON.com
198: AMAZON.com
201: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: Baja Forums
210: AMAZON.com
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
218: AMAZON.com
219: Baja Forums
220: AMAZON.com
221: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: Baja Forums
245: Baja Forums
246: AMAZON.com
247: Baja Forums
248: Baja Forums
249: Baja Forums
250: Baja Forums
251: AMAZON.com
252: AMAZON.com
253: AMAZON.com
254: AMAZON.com
255: AMAZON.com
256: AMAZON.com
257: AMAZON.com
258: Baja Forums
259: AMAZON.com
1 2 3 ... 94 95 96 ... 103 104 105
Posted: Fri Dec 14, 2012 02:40 PM
I bought "Clyde", our new 1973 bug-eye baja. Turns out Perri built it years ago.
Yummi
Yummi
Posted: Fri Dec 14, 2012 03:26 PM
Ordered up some new seats and belts. Work continues on new tranny install. Which is good cause I done blowed up the 002 last time out.
Will have some fair condition blue PRPs and a fresh 002 from AZTransaxle for sale soon enough. Well, depending on if it is cost effective to fix prior to selling. Bill's call on that.
Posted: Sat Dec 15, 2012 01:38 AM
Installed rear drum and speedo cable.
Posted: Wed Dec 19, 2012 05:14 AM
I picked Clyde up from Perri's. He's been a great help. I picked up a new cap and rotor, fuel line, fuel filter, Mann Oil filters (mine takes 2), Bosch plug wires and sent my Kadrons to the Kaddyshack today.
73square
73square
Posted: Fri Dec 21, 2012 05:43 PM
Replaced the flexible aluminum fresh air heater tubes and the oil tube gasket. Nice to be warm in the mornings...
That's done - Next!
Posted: Sun Dec 23, 2012 05:21 AM
I degreased the engine and skidplates. Man! There must have been YEARS worth of grime on it! Power purple and a powerwasher did the trick!
Yummi
Yummi
Posted: Sun Dec 23, 2012 02:47 PM
Well, got the car back. Long process. Wish I had the skill set to tackle this project – I do not. Jason at AZP Concepts does though and I can’t say enough good things about him.
Now have the a 4E with 2D upgrade, etc. Guess I am one of the cool kids with a Mendeola? Gearing is not 100% but Bill @ AZTransaxle suggested we run it as is, figure what I like, what I don't and then we will rebuild / regear in summer.
In the course of swapping tranny it was discovered that the axles were too long for the 002. They needed 27 1/2" for the new narrower tranny and come to find out they had 27 1/2" on the old wide one. Course because they were too long they were mushroomed, etc. New 300 M axles. The car on hard impacts would "splay" too wide. That is most likely what caused the crack on the frame. The reason it was cracked on the right and not the left is that the tranny / motor was not 100% centered. Both of those issues have been resolved. Will still be reworking torsion tube area in summer and possibly address any triangulation, etc at that time.
To install tranny it required that motor and tranny be raised. That resulted in cross members being cut to allow for height and engine cage being cut in a likewise fashion. New motor mounts, etc. Because some area was lost under the rear deck lid of the body, power steering pump has been relocated. Because tranny went taller, fuel pump has been relocated. Oh yea, this also required new starter and limit straps. Big thanks to AZ Transaxle for the deal on the 300m alxes and having everything that was needed in stock. Pretty much the whole back end is reworked excluding the motor.
There are new seats ordered from TripleXXX / Herbie. Really tough getting seats for this given the space constraints. Hope to have them in for the next dune trip after new years / February. For the time being I also swapped out the old three points and put in five points. With the current Beard super seats they have no choice but to be over the shoulder seat area. Held onto the Y belts just in case it is an issue over this coming dune trip. Had some additional bars put into the cage area. So right now we are just at seats pending and some new lights...... Always something no?
Bigger project coming in summer to include re-install rack for spare at cage area, etc etc.
Really like they way it turned out. Mendi looks so much better sitting there than does the 002.
Good thing I bought this car with the full expectation of getting it sorted out.
We are one step closer to having it sorted.
Posted: Mon Dec 24, 2012 03:33 AM
I started the fiberglass repairs on the nose and driver's side front fender. I hate the mess!
Posted: Thu Dec 27, 2012 04:01 AM
Put the oil drain plate on the rail motor and cleaned up some other stuff to continue putting it together, pulled the ecm from my truck so I can get a new one to get it running again.
Posted: Thu Dec 27, 2012 08:11 AM
installed my new 5 point, 3 inch harnesses today. also got my new axles cut to the right length, so those will be installed friday
Posted: Fri Dec 28, 2012 06:20 PM
oil pump in, flywheel on, next is pistons, liners & heads. Should have this motor complete by Friday of next week.
Posted: Mon Jan 07, 2013 03:09 AM
This week, I tightened the oil sending unit and oil filter, both which were leaking. I have great friends in the VW community! I Dirtjunkie, Wideopenmotorsports and 64VWBug helped me a bunch this week.
I removed the spare tire mount, and got a rear seat in great condition for $30! I also picked up a set of KYB shocks for the front. The brake pedal now remains in the forward position, rather than falling towards the driver. I also swapped steering wheels.
These accomplishments may seem small, but make the baja much more driver friendly. Friends are awesome!
Posted: Mon Jan 07, 2013 05:38 AM
I got some parts from the Above ^^^ Smile Thanks! Also scored some good deals from Karls and Dougs at the swap meet.
Repaired my brake lights and headlight not working. Both caused by loose contact at the original fuse box fuses. On the wishlist is to completely rewire someday. For now I just bent the tab carefully so it'll have more pretension on the fuse. Drove it tonight to get the rockers from Eric and the lights stayed on. Smile
Yummi
Yummi
Posted: Mon Jan 07, 2013 01:46 PM
Drove it! Does that count? Had a good dune trip.
Have an intermittent electrical issue so brought it home a few hours early and started the rewire. Not a pretty sight up under the dash currently. But that will change. I hate cleaning up wiring messes. Guess on the bright side I will be able to sort them in the future?
Current condition and soon to be reworked parts...
Posted: Mon Jan 07, 2013 05:20 PM
Yes it counts at least in my book!
Looks like a chore, but the rewards will be plentiful when you're not stuck somewhere due to a short, etc.
That last picture reminds me of the XXX movie where Vin Diesil says to the kid when he asks what do you want installed? He replied "Everything!" LOL
5 Admin_AzBaja 6774 Baja Bugs on Wiki need...
285 MusicManiac 241201 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 9 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1276 Re: Had to go play in ...
0 Northmountainauto 1520 Shop Baja
