Visitors: 275
Total: 275
08: My Account
40: Event Calendar
47: Pictures
79: Pictures
95: My Account
108: My Account
150: My Account
154: Baja Forums
157: Event Calendar
158: Baja Forums
160: My Account
170: Baja Forums
171: Baja Forums
172: Pictures
173: Baja Forums
174: Links
176: Event Calendar
192: Baja Forums
197: AMAZON.com
198: Baja Forums
199: Baja Forums
202: AMAZON.com
203: Baja Forums
204: AMAZON.com
205: AMAZON.com
207: Pictures
208: AMAZON.com
209: Baja Forums
210: AMAZON.com
212: Baja Forums
213: Baja Forums
214: Baja Forums
215: Baja Forums
216: Baja Forums
217: Baja Forums
218: Baja Forums
219: Baja Forums
220: Baja Forums
221: Event Calendar
222: Baja Forums
223: My Account
225: AMAZON.com
226: AMAZON.com
227: Baja Forums
229: Pictures
230: Event Calendar
231: Baja Forums
232: Baja Forums
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: Baja Forums
238: AMAZON.com
239: AMAZON.com
240: Baja Forums
241: Baja Forums
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: AMAZON.com
247: My Account
248: Baja Forums
249: Baja Forums
250: AMAZON.com
251: AMAZON.com
252: Baja Forums
253: AMAZON.com
254: AMAZON.com
255: AMAZON.com
256: AMAZON.com
257: Pictures
258: AMAZON.com
259: AMAZON.com
260: Pictures
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: AMAZON.com
266: AMAZON.com
267: AMAZON.com
268: My Account
269: AMAZON.com
270: AMAZON.com
271: Baja Forums
272: My Account
273: Baja Forums
274: Pictures
275: AMAZON.com
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Biblethumpncop's barter, beater, bargain Baja!
Post Post subject: Biblethumpncop's barter, beater, bargain Baja!
Posted: Tue Nov 06, 2012 03:09 AM
Cool! I am thinking of something along those lines. Good idea Tony.
Posted: Tue Nov 06, 2012 05:19 AM
I like the body lift idea as well.
Posted: Fri Nov 09, 2012 05:17 AM
I traded a 30/31 carb for a set of 90.5 pistons and cylinders. Going 1776 baby!!!
Post Post subject: Re: Biblethumpncop's barter, beater, bargain Baja!
Posted: Wed Nov 14, 2012 06:13 PM
biblethumpncop wrote:
I picked up another dual relief 1600 shortblock Wed that also had DP heads, tin, alternator, etc from Prescott- in exchange for ammo. It spins freely and should prove to be another piece in working towards putting a solid DP together.
Pulled this motor apart last night. Great Score!!! Standard crank and case in great shape. Will be a good base for the 1776.
Posted: Wed Nov 14, 2012 08:13 PM
Eric, I'm stoked!
Posted: Sun Nov 25, 2012 12:51 AM
I was searching for additional pictures of bug trucks and ran across this one:
I think I may use the bulkhead from the Dumas kit, but not the flatback. I like how the above picture keeps a greater portion of the body for rigidity and the flatbed/box is steel- not fiberglass. This looks very do-able. Perhaps I will still incorporate a cage as funding becomes available.
Posted: Sun Nov 25, 2012 01:57 AM
I like it, I think it would look great with baja front and rear fenders, bumpers, and a cage that ties in through the bulkhead too the rear bumper.
Posted: Sun Nov 25, 2012 05:12 AM
I agree. The fiberglass kit was designed for street use. I would design a good cage first to support the car once the top is cut off and add the rear deck later. If you drive it without any support it will sag and be useless.
Posted: Mon Nov 26, 2012 08:17 PM
That was on my list of things to build but I'm running out of time. Sad
I think a donor section of the back few inches of an early T-2 55 up to 67 would supply one with enough curves to make it in steel and use the Bus rear window.
Posted: Mon Dec 03, 2012 03:54 AM
I traded some parts that were of no use to me (single port tins, 3 junk/cracked heads-he knows they are junk, headlights, stock bent bumpers and an original air cleaner for this roll cage:
It is stout and should be a good skeleton for the truck!
Posted: Mon Dec 03, 2012 04:40 AM
Nice trade.
Posted: Wed Dec 05, 2012 02:05 AM
My son and I removed the body bolts. Unfortunately, I snapped the two front passenger side 17mm bolts. Crap!
The body is like swiss cheese in the rear parcel tray. The passenger side floor pan needs help too. I can see this will be a long project...
Posted: Wed Dec 12, 2012 02:55 PM
I sold my Ram 1500, and will be picking up a daily driver bug to work on with my son. I will do the conversion on a running vw and get rid of this one. It would take more time than I want, so we'll find a running car and continue the project.
5 Admin_AzBaja 6845 Baja Bugs on Wiki need...
1568 mufasavnvmc 1001142 Re: what did you do to...
285 MusicManiac 241797 Re: Baja sightings
0 Northmountainauto 1557 Shop Baja
