Visitors: 131
Total: 131
03: Event Calendar
18: My Account
22: Event Calendar
26: Event Calendar
32: Event Calendar
53: Pictures
58: Event Calendar
113: Event Calendar
120: Event Calendar
121: My Account
126: Home
Baja Forums -:- Off-Road & VW Based Clubs (4x4, ATV, Jeep, Motorcycle) -:- Events and Get Togethers World Wide -:- 3rd Annual AZBaja PlayDay at the river.
1 2 3 ... 7 8 9 10 11
Ejbbal21
Ejbbal21
Post Post subject: 3rd Annual AZBaja PlayDay at the river.
Posted: Fri Nov 02, 2012 08:04 PM
Never mind my dad is comming to my house. Azbaja can we meet a littler earlier? I have a truck and trailer so where ever we meet make sure there is enough room.
Ejbbal21
Ejbbal21
Posted: Fri Nov 02, 2012 10:18 PM
It's official I'm ready to go all I have to do it put the beast on the trailer and grab ice on the way out. Btw there is no way I'm goin to sleep tonight. I did end up dropping the rear. It was about 3" taller then the front. I ended up raising the rear the first time about 7". So now the rear is about 1" taller then the front. I have sway away torsion springs so they don't settle much. I believe I have 16" clearance under the entire car.
Post Post subject: Re: 3rd Annual AZBaja PlayDay at the river.
Posted: Fri Nov 02, 2012 11:31 PM
I had been planning to leave Mesa between 6 and 7 pm. I want to get a full day Saturday of riding. I'm replacing broken torsion leaves. If anybody needs to put thiers on a rack I'll be here until 6 pm.
Ejbbal21
Ejbbal21
Posted: Fri Nov 02, 2012 11:52 PM
I'm with you I want a full day of riding do you want to meet up?
azdesertrat87
azdesertrat87
Posted: Sat Nov 03, 2012 12:07 AM
you guys coming out tonight? I think me,Dalton and JWH will bee out there tonight
Posted: Sat Nov 03, 2012 12:08 AM
i'll be out there after the cruise-in at Lunde's tonight. Probably sometime between 9 and 10.
Ejbbal21
Ejbbal21
Posted: Sat Nov 03, 2012 12:10 AM
No sorry not tonight but it in the morning yes.
azdesertrat87
azdesertrat87
Posted: Sat Nov 03, 2012 12:18 AM
we'll keep the fire lit see everybody on sat later
Posted: Sat Nov 03, 2012 12:50 AM
sounds good kenny! i've got the roof rack loaded with a pile of firewood to help contribute
Posted: Sat Nov 03, 2012 03:08 AM
I'll be at my shop 2221 W. Broadway Rd Mesa at 6 pm and plan on leaving around 6:30. 480-709-8097
Posted: Sat Nov 03, 2012 06:04 AM
I will be loading up some hot dogs and buns. I hope to be head out some time before 10am at the latest. Once I get the decals etc. I'm gone. my goal is to be on the road at 9:30 if anyone wants to head on out about the same time I will be a Duckin Donuts. Cell phone is 6 0 2 @ 7 7 O @ O 825.
There is more the enuff room for a trailer, or a Semi or a Plane in the parking lot.
Ejbbal21
Ejbbal21
Posted: Sat Nov 03, 2012 06:29 AM
I will not be going tomorrow. I did a good shake down and sheared all the dowel pins clean off. So I'm out. Does any one have a 84mm crank laying around or any tricks to getting broken dowel pins out? Have fun tomarrow. Save a shirt of something for me it's my birthday tomorrow after all. Smile
Posted: Sat Nov 03, 2012 06:43 AM
That sucks. Good luck. I've had some success with grab-it bits. Since yours are sheared, the threads are probably ok. You can also try using a dremel to cut a line across the top and see if you can get it with a large blade standard screwdriver. Use an adjustable wrench on the shaft if you need more power, but you may destroy the screwdriver.
Honestly I can't picture where you're talking about.
I had purchased a solid mount for my Xterra a while back and today decided to put it on before towing the Baja. Good thing, the old was broken. Towed the Baja around the streets near by and it seems to do fine.
Posted: Sat Nov 03, 2012 07:50 AM
I am heading out early Sat. Hope to meet up with Dirtjunkie around 8:30am. See ya at the river.
Posted: Sat Nov 03, 2012 01:38 PM
Happy birtday. Not to ruin it but that crank and flywheel even if you change the pins will never spin the flywheel true. Its time to get a wedgemated crank and flywheel. Demello and DPR build them, they might be able to save yours.
29 AzBaja 29886 Re: "AzBaja Supporting...
 Mon Mar 09, 2009 07:32 PM
cyberjaw4 View latest post
32 AzBaja 32482 Get the www.AzBaja.com...
 Fri Feb 03, 2012 11:36 PM
1966baja View latest post
No new posts Events and Get Togethers World Wide 2018 AZBaja 9th Annual Play Day, Date.... 0 Dirtjunkie 620 2018 AZBaja 9th Annual...
 Wed May 23, 2018 03:59 PM
No new posts Events and Get Togethers World Wide Annual 400 mile camp out may 21-22 2016. SAT-SUN
Overnight run
91 Azdrtdog 25483 Annual 400 mile camp o...
 Mon May 21, 2018 02:50 PM
No new posts Events and Get Togethers World Wide Hassayampa at I-10 Closed! (Old Playday area) 2 Dirtjunkie 1262 Hassayampa at I-10 Cl...
 Fri Oct 27, 2017 02:13 PM
