Author |
Message |
The following users give thanks for this topic |
texasmetal - Wed Mar 03, 2010 07:27 AM, perrib - Mon Apr 19, 2010 04:37 AM |
+13
Post subject: what did you do to your buggy/baja/Thing/Sandrail today?
Posted: Sat Oct 06, 2012 01:40 AM
Filled the trans and motor on the kids car with the proper fluids and amounts, replaced the axle seals in the rail and installed the fuse block and toggle switches.
_________________ Current AZBaja"El Presidente"
Ejbbal21
+2
+13
Posted: Tue Oct 09, 2012 04:02 AM
Finished wiring up the motor & generator for the kids car now just gotta fix the fuel line that is broke at the pan in back. Still need to get a battery too to start it.
+5
Posted: Tue Oct 09, 2012 10:23 PM
I am going to Prescott tomorrow to "acquire" another 1600 DP in trade for some ammo. Supposed to have a lightened flywheel, and spin freely- "but needs rebuilt". With Dirtjunkie's help, we plan on taking the best of everything and making a solid engine for my son's "TR-AJA".
I'm becoming a horder- I feel so dirty...
_________________ If you blame others when you fail, give them credit when you succeed!
Ejbbal21
+2
Posted: Thu Oct 11, 2012 06:28 AM
_________________ 69 Baja; Turbo charged 2332, 091 trans, 4x5 rear arms with race prepped 930 CV's, L/P front widened about 10" to match the rear. 2.5" coilovers up front and 2.0" shocks in the rear. Let's just say its a ton of fun.
Ejbbal21
+2
Ejbbal21
+2
+13
Posted: Thu Oct 18, 2012 09:23 PM
Pulled the motor & old trans, hope to get the new(used)trans in tomorrow.
+5
+13
Posted: Fri Oct 19, 2012 03:35 PM
Trans is in,took it for a short test drive and all is good so far, gotta go do some shopping with the better half, then an extended test drive later tonight.
Got a battery for the other kids car so we Just gotta finish up some wiring and bleed the brakes and we will attemt to fire it up for the first time(probably some time sunday)
+5
TINMAN
+6
Post subject: Re: what did you do to your buggy/baja/Thing/Sandrail today?
Posted: Sun Oct 21, 2012 02:53 AM
took my 66 bug to the Las Vegas BOR. and lost the trophy class final in a double breakout. Lots of fun cant wait to do it again
_________________ TRUMP 2020
+5
+13
Posted: Mon Oct 22, 2012 04:42 AM
Fired up the other car today, sounds good, gotta make some adjustments and fix a pushrod seal leak. and it should be good.
+5
Posted: Mon Oct 22, 2012 04:53 AM
I used a powerwasher to blast 20 years of nasty out of the baja project. I also moved it from one side of the garage to the other. Does that count?
