Visitors: 168
Total: 168
42: Pictures
50: Event Calendar
59: Event Calendar
68: Event Calendar
71: Event Calendar
75: Event Calendar
76: Event Calendar
89: Event Calendar
95: Event Calendar
96: Event Calendar
97: Event Calendar
107: Event Calendar
136: Event Calendar
146: Event Calendar
150: Baja Forums
154: Baja Forums
155: Event Calendar
162: Baja Forums
166: Pictures
167: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Super beetle vs standard baja kit
Voiden
Voiden
Post Post subject: Super beetle vs standard baja kit
Posted: Wed Sep 12, 2012 06:05 AM
I want to build a baja of my rusty 1302.
I have found cheap baja kit, but it is a standard beetle kit.
What is the difference, and it is possible to modify?
I have searched but can not find what the difference is.
1971 ___
Super /___\
Beetle (O\!/O)
Posted: Wed Sep 12, 2012 03:42 PM
You might be running into something I just discovered (the hard way) that all fiberglass kits aren't for baja's.
I didn't think when I went to get a Craigslist deal to look close enough at the Front fenders I was buying. What I got are for a Beetle without a cut front end.
Was a little dissapointing when I went to put them on and discovered that I'd have to hack most of the front off to make them work, but would in the process lose the headlight buckets. Just not worth the effort and hopefully I'll run into someone that needs them.
I don't believe, other than suspension, that there was much difference in the fenders between Super and non-super beetle.
Good luck in Sweden!
Post Post subject: Re: Super beetle vs standard baja kit
Posted: Wed Sep 12, 2012 05:24 PM
Drive over there without your hood put the baja hood on and see if it is wide enough.
Posted: Thu Sep 13, 2012 07:35 AM
The shape of Super Beetle front fenders is substantially different from Standard or Deluxe Beetle fenders (All US delivery Beetles that Americans call "Standard" are actually "Deluxe". Thus the lack of bright trim on many German and other market Bugs.)
5 Admin_AzBaja 8335 Baja Bugs on Wiki need...
1569 mufasavnvmc 1058736 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 255262 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1208 FREE VW BAJA'S
0 Northmountainauto 2176 Shop Baja
