Visitors: 107
Total: 107
11: Pictures
42: Event Calendar
51: Event Calendar
54: Pictures
61: Event Calendar
64: Event Calendar
76: Home
84: Event Calendar
101: Event Calendar
1 2 3 ... 88 89 90 ... 103 104 105
Ejbbal21
Ejbbal21
Posted: Sat Aug 18, 2012 06:31 PM
yep a cage is next just after I get some springs for my coil over shocks up front. The trick is to cage it while still keeping my back seat. Just about every time I get in it one or more of my kid are in the back seat.
Posted: Mon Aug 20, 2012 11:20 AM
Greased up a wheel bearing, Greased up the front end. Dropped my shocks off at www.raceshock.com/ to get them rebuilt.
Will start the full tear out of the front end this week and next week.
Now that Bad news Sad
When I had the car built the front end had stock front arms and stock front beam. After the years things have changed. I have a wider front beam and 1x1 front arms...Sounds cool...?
Well I now have a problem. The tie rod hits the cage about half way up the wheel travel on the passange side of the car. Looks like I need a Tube/Brace on the cage clearnaced so I can get full wheel travel. I will move a spacer around and hope to gain that little bit of space I need. If it does not work it will go back to Bug Zs place and have a brace moved and rewelded in place. the driver side is fine. Looks like that brace was welded a little further forward on the right side, about an 1/4" or so. If I had the old arms on the baja I would not have a problem.
Posted: Mon Aug 20, 2012 09:50 PM
My old race Hi Jumper had a similar problem, although it never got long arms on the front. After some race damage to the frame in the area of the tie rod openings, I had San Fernando Buggy add some vertical bars behind the tie rods. They got the right side too far forward and I destroyed a chrome moly tie rod and the upright tube the 1st time out from interference.
Posted: Tue Aug 21, 2012 04:43 AM
Getting closer to picking up a 73 Thing. I spoke to him tonight, and go see it tomorrow. The pictures look good. The hood, windshield, doors, fenders, lights, dash are disassembled. The seats are not original, and probably are from a conversion van. It will need better seats. Suppose to have 2 engines and good electrical and transaxle. I may finally be getting my Thing I've wanted for a long time.
Posted: Wed Aug 22, 2012 02:59 AM
Completed the cooling lines today, they are ready to install. Got most of the bumper and rear frame tacked together. Next to weld it all up and I hope to install for the last time before test drive. Rolling Eyes
73square
73square
Posted: Thu Aug 23, 2012 02:42 PM
Biblethump- Well? How did that Thing look?
That's done - Next!
Posted: Fri Aug 24, 2012 12:23 AM
Man was it torn apart. It didn't follow me home... booohoooo, sob, sob.
73square
73square
Posted: Fri Aug 24, 2012 04:06 AM
Sorry man.. I'll keep my eyes open for ya-!
I'm still trying to get Type-3 hubs that work; I orderd a set on-line and Perry was putting it together for me, but the stuff is so cheap (Chinese I assume) it keeps stripping out -its like cast iron.
That's done - Next!
Posted: Sat Aug 25, 2012 06:09 PM
It has been three weeks since I drove it due to surgery and this morning it started on second try. Cant drive it for at least another month and at that it will only be on the streets, but it is nice to know it still runs.
Posted: Sun Aug 26, 2012 01:38 AM
Had to tear both window regulators out. They were get'n stuck. Not good with t-storms brewing at any time season. I'm hoping I can turn the cable to an area that's not used and reuse these. Wink
Posted: Wed Aug 29, 2012 01:38 PM
Replaced trhe master cylinder, still working on getting all the air out of the system.
TrailRail2110
TrailRail2110
Posted: Fri Aug 31, 2012 04:41 PM
I have the rail stripped of the all heavy weight i could remove, its sparkling clean and i will be at the dunes tearing it up with the paddle tires for the Labor Day Holiday.
Posted: Tue Sep 04, 2012 04:10 PM
Finally got the brakes sorted out and drove it to work today.
Posted: Tue Sep 04, 2012 04:20 PM
Hopefully they'll be working for your trip back home. I had my brakes go out and had to use curbs to stop (No e-brake), fortunately I was able to take small side streets all the way from downtown PHX to 83rd and Ind Sch Rd. and hit most of the lights green.
Memories... Smile
Posted: Tue Sep 04, 2012 04:23 PM
Its all good plenty of stopping power, replaced the master, got all corners bleed and adjusted the pushrod. Now she stops great.
5 Admin_AzBaja 7347 Baja Bugs on Wiki need...
285 MusicManiac 246430 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 474 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1627 Re: Had to go play in ...
0 Northmountainauto 1780 Shop Baja
