Latest: Milkmanbryan
Overall: 3583
Visitors: 109
Total: 109
02: Event Calendar
20: Event Calendar
55: Home
70: Links
95: Pictures
98: Event Calendar
107: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- newbie with a project
aktalon89
aktalon89
Post Post subject: newbie with a project
Posted: Sun May 07, 2006 10:48 AM
hey im from anchorage alaska and i have ran across a 69 bug that is halfway baja.its being dropped off at my shop here in the next week or two.the plan for the build is to make it a rally/dd but not so much a dd.now the questions i have are what are the weak points with the bugs?what lift kits if any are out there and how big of a tire can i run?i live in alaska and we wheel every chance we get.so any advice on were to start would be great.i have fab skillz and have been a certified welder and all that fun stuff.ill get pics as soon as it gets to my shop man i cant wait to start lol.im lookin for a stance like the green one is the azbaja guys profile:) nice bug.
Post Post subject: Re: newbie with a project
Posted: Sun May 07, 2006 07:03 PM
Balljoints are the only weak point that I can think of. I run a ball joint front end I have never had any problems, but I replaced all of them as soon as I got it.
As far as tires go, if you have a stock suspension:
I would recomend that you go with 235/75/15 for the rear. Youcan put 31/10.50/15 put they sometimes hit the fenders (unless you're running raceing fenders), plus 235s cost less. For fronts there is not mush that you can do without hitting the pan and giving up turning radius.
If you put 3X3s and wider front tubes:
You can basicly fun what ever you want. It makes the car wider and more stable, but costs an arm and a leg and makes your car wider (cant shoot though those small little openings- be it freeway or trail) Twisted Evil
Make sur that all of your rubber is good, mounts, boots and bushings.
Other than that, go throgh the car and make shure everything is safe (POs have a way of really F'ing up a car) Rolling Eyes
Have fun! And welcome to the Darkside!
aktalon89
aktalon89
Posted: Mon May 08, 2006 12:58 AM
well i just found out that its coming with like 3 sets of fenders and 2 hoods wich one is a single peice that mounts to the front bumper and it folds up as one piece.any know a good site to get transaxle parts? it only has 1,2 and reverse.so there is no way to get a bigger tire up front??? so its time for a custom suspension lol
Posted: Mon May 08, 2006 04:25 AM
Well, I just found out the 205/75/15 will fit but you may need offset wheels. Laughing
Posted: Mon May 08, 2006 04:36 AM
If you want to run tall tires on the front, you will need to widen the beam to keep the tires form rubbing. I have the 7.00-15s (29 inches tall) on the front of mine with a 6 inch wider beam. You could probably get away with a 4 inch wider beam and not rub.
aktalon89
aktalon89
Posted: Tue May 09, 2006 02:19 AM
ok well i just found out i heard wrong its a 1963! not a 69 what the diff if any.and does anyone know the bolt pattern for the wheels?
Say10
Say10
Posted: Tue May 09, 2006 02:25 AM
Swing axel instead of IRS, front end set up different. Is it 6 12 volt.
Posted: Tue May 09, 2006 02:55 AM
The bolt pattern in 5 on 205mm, AKA wide 5.
Say10
Say10
Posted: Tue May 09, 2006 03:07 AM
But they make adaptors to go to Ford and Chevy 5 bolt patterns...
Posted: Tue May 09, 2006 03:53 AM
I just happen to have a full set of wide 5 to chevy 5 on 4 3/4 adapters too if anyone needs a set Cool Cheap.
aktalon89
aktalon89
Posted: Tue May 09, 2006 04:00 AM
sweet u guys know where to get the adapters online? and what a normal price for a 69 bug and a 73 superbeetle one has motor no tranny and other one is missing drive train.and both have mild rust just wnat to know before i sell them
Say10
Say10
Posted: Tue May 09, 2006 05:47 AM
Try this place www.cip1.com......as far as the bugs, just depends? Down here people are getting SSTTTuuppiiidd price for junk.
aktalon89
aktalon89
Posted: Tue May 09, 2006 09:43 AM
hey i just thought i would make sure but will a transaxle outta a 73ish work with a 63?
1199 Dalton 329393 My 69 project
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3016 Project Purple People ...
88 Dirtjunkie 61178 Project II
65 PaDan 55845 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 8119 Re: new project
