Visitors: 91
Total: 91
29: Event Calendar
63: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Completely Lost
Completely Lost
ktakeshi
ktakeshi
Post Post subject: Completely Lost
Posted: Thu Aug 02, 2012 12:31 PM
So i am new to VW beetles and am completely lost on what i have. I bought the beetle parts off a friend who is moving out of state and was going to build a 54 manx, so the chassis and pans were chopped 14 inches.
photos
s203.photobucket.com/a...%20Beetle/
transmition/ axle
113.301.2110
4755650
113.301.2110
front axle
311.415.131
engine
113.101.101B 29
5886778
113.101.102B 11
chassis/pans
1952371
thanks for the help
Posted: Fri Aug 03, 2012 03:31 AM
You have a 54 pan. The front axle, trans and engine are 61-65 parts. The engine is a 1200cc rated at 40hp. I don't see much to improve that rating. The trans will not bolt into the pan at the front unless either the front shifter housing on the trans has been swapped for an early 60s bus piece, or the mount welded on the frame has been replaced with a later piece. I''m not too sure where you found the "311" part number for the front axle. That would indicate a Type 3 front axle, which the one you have is most clearly NOT. Was it maybe "113"?
ktakeshi
ktakeshi
Post Post subject: Re: Completely Lost
Posted: Fri Aug 03, 2012 05:41 AM
i was told the front end is a type 3 front beam but the person wasnt sure. the 311 was on the sterring box on the front end i just checked again. the pan is a 54 but the chassis itself isnt a 54, also what i was told along with the entire chassis/pan was chopped 14" since it was going to be a manx.
Posted: Tue Aug 07, 2012 09:54 AM
The number on the steering box does not speak for the entire beam assembly. Note that where I said before
"You have a 54 pan. The front axle, trans and engine are 61-65 parts. The engine is a 1200cc rated at 40hp."
I was referring to parts from that vintage of Bug. VW's old parts numbering system really made a lot of sense. Parts for Type 1 cars the part number started with "111" or "113". "111" indicates a "Standard" Beetle. "113" indicates a "Deluxe" Beetle. All VW Beetles sold in the US from the beginning through 1978 were at least "Deluxe" models. From 1971 on, Super Beetles were added. Base model Bugs had no "chrome" trim on the sides or around the windows, painted bumpers, and other details that varied from the Bugs sold in the US.
Parts for Type 2 Bus the number starts with "211"; Type 3 fastback/squareback/notchback, the number starts with "311"; and for Type 4 fastback and squareback, the numbers start with "411". Parts for Rabbits/Golfs, Jettas, New Beetles etc. are different.
No new posts VW Volkswagen & Baja Bug General Discussion Almost lost a car AND a kid
19 57baja 9966 Re: Almost lost a car ...
 Sun Jul 19, 2009 10:45 PM
Preston View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Help- I've lost almost all ambition for baja... 12 Billy 14362 Re: Help- I've lost al...
 Fri Jun 05, 2009 06:11 AM
No new posts VW Volkswagen & Baja Bug General Discussion Indiana Jones and the lost Bug! 5 DutchBug 2965 Re: Indiana Jones and ...
 Fri Jul 11, 2008 01:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Helloooooo, did Mykul get lost at science camp????? 6 bajawarrior 2121 Re: Helloooooo, did My...
 Sun Nov 04, 2007 05:22 PM
az350x View latest post
