Visitors: 114
Total: 114
07: Home
16: Pictures
29: Home
39: Event Calendar
46: Event Calendar
55: Event Calendar
69: Home
72: Event Calendar
99: Home
110: Pictures
112: Pictures
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- AzBaja Green Baja Bug
Post Post subject: AzBaja Green Baja Bug
Posted: Fri Jul 27, 2012 10:02 PM
Link to Photo Page
Posted: Sat Jul 28, 2012 02:47 AM
Looking good. It makes me think that mine should be green. But then the name Grape Ap would not fit very well and the wife would be mad that it was not purple
blubaron66
blubaron66
Post Post subject: Re: AzBaja Green Baja Bug
Posted: Sat Jul 28, 2012 04:24 AM
I dont know the story behind the green baja... is this your current project or one of many?
Posted: Sat Jul 28, 2012 05:08 AM
Same car I started with sometime in 1992. Just an on going project for well over 20 years now. You can see the changes over the years if you look around the web for it.
It just do for some TLC after years of use.
Posted: Sat Jan 12, 2013 10:26 PM
Baja is home
Posted: Sun Jan 13, 2013 12:45 AM
Congrats!!!
Posted: Sun Jan 13, 2013 05:12 AM
Your very busy so I volunteer to take it and trail run it to make sure it is ready for the Hassayampa run. Smile
Posted: Sun Jan 13, 2013 07:40 AM
I do have some projects. Time to spread the work around some. I do have some welding work that needs to be done. Now that it's to cold to do some of my other projects. Have to make sure every one gets a turn if your game for it.
Posted: Mon Mar 04, 2013 08:55 PM
The Gren Baja is making progress. I'm relocating one of the cage bars where it interferes with the tie rods. To get clear access to cut and weld a door was made in the body.
One thing to consider when building a frame is allowing for upgrades in the future. Having more distance between the lower and upper tubes to allow for a longer travel suspension would of negated the need to compromise by spreading the tubing apart. Ten minutues of welding plus a good twenty times that to remove the old tube(s), get access and make a new tube. I still have to weld the body back in.
One of the other bars had to be removed in the process while I would of liked to replace this tube it is an odd size 1 1/4". Rather than buying 20 ftof it I sleeved the cut. Due to the tight fit it was an external sleeve. Not very cute looking but it will be under the fuel tank.
Posted: Wed Mar 06, 2013 05:39 AM
Eric had a piece of expanded metal he wanted to turn into an underhood storage compartment. The frame doubles as the stock fuel tank retainer while the wire sides give plenty of places to attach bungee cords.
I also welded the window I had cut out of the body.
Posted: Thu Mar 07, 2013 02:17 PM
Eric also wanted to keep his jack from bouncing around under the passenger seat. Left loose it is heavy enough to cause pain.
I think it will stay put. There are fender washers on the bottom to spread the load out on the floor pan, lock tite on the bolts and a hair pin clip if the retainer nut ever trys to loosens up it can not turn far.
Posted: Fri Mar 08, 2013 01:09 AM
perri!
WOW you do great work! I did not know you did Fab work out of the shop.
Posted: Fri Mar 08, 2013 07:38 AM
How do you think his rail got that pretty? It did not do it on its own Smile
Posted: Sat Mar 16, 2013 04:57 PM
After stopping in Friday. I was thinking about the mount for the fuel neck. We could run a mount from the top rear corner of the basket and the bottom rear corner of the besket to hold the neck in place. in a vertical fashion. Then mount the brakect to the neck from behind.
Just an idea.
Posted: Sun Sep 15, 2013 05:06 AM
Ok some updates...Have the Green Baja at home.
Steering is done with New U-Joints and rag joint...it is nice.
Reinstalling all the fuel lines and system this week. I have only a few days next week, but once I get the fuel tanks cleaned out and checked. I should be able to fire it up and drive it.
I still have to wire the front for lights and hook up the brake switch on the master so I get brake lights but it will be drivable.
Once I get to that step I need to pull the front coil overs off and get them looked at. The N2 fitting on the shock hits the shock tower. might need some sort of 45' or 90' fitting to clear it.
Inside wires might not get done for now. goal is to get it running.
Roof rack needs to be done and lights added and put back on the car.
Rear shocks still need to be put back on the car too
Once it is running I can do the little BS clean up projects and get them knocked out with one or 2 a week.
That bad news....The hood will no longer fit on the Baja. The basket hit the hood so I can not clamp the hood onto the car with the basket in place. I have an idea for a fix but for now the basket will sit next to the Duster. Sad
4 Admin_AzBaja 5226 Baja Bugs on Wiki need...
29 AzBaja 27042 Re: "AzBaja Supporting...
 Mon Mar 09, 2009 07:32 PM
cyberjaw4 View latest post
1568 mufasavnvmc 856511 Re: what did you do to...
285 MusicManiac 209570 Re: Baja sightings
32 AzBaja 28982 Get the www.AzBaja.com...
 Fri Feb 03, 2012 10:36 PM
1966baja View latest post
