Visitors: 96
Total: 96
50: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- SuperBeetle to Baja
SuperBeetle to Baja
desertbaja
desertbaja
Post Post subject: SuperBeetle to Baja
Posted: Tue Jun 26, 2012 03:09 AM
What are the downsides of converting a super beetle to a Baja? Would one be better off converting a standard bug to a Baja?
Post Post subject: Re: SuperBeetle to Baja
Posted: Tue Jun 26, 2012 03:44 AM
Go standard and leave the sb for the road guys. The headache you avoid will well worth it.
Posted: Sat Jun 30, 2012 01:35 AM
If you go full cage etc. You will replace the front anyway if not go with a normal Bug.
Posted: Wed Jul 11, 2012 12:48 AM
I agree with the others. You CAN offroad a SB, but not very much and not very hard. You COULD offroad a Honda Civic...
The McPherson Strut front suspension on a Super just isn't well suited to it. But if you build a full on tube framed Baja and cut the front of the frame off and install a beam setup supported on the tube framework, or weld on the whole front end of the pan for a beam Bug, then OK.
There is another Forum which has a whole section of forum set up to tell newbs all about why not to build a Baja out of a Super.
5 Admin_AzBaja 7386 Baja Bugs on Wiki need...
1568 mufasavnvmc 1021692 Re: what did you do to...
285 MusicManiac 246688 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 498 FREE VW BAJA'S
0 Northmountainauto 1794 Shop Baja
