Visitors: 188
Total: 188
78: Event Calendar
124: Event Calendar
127: Pictures
150: Baja Forums
154: Event Calendar
166: Baja Forums
171: Baja Forums
176: Baja Forums
177: Event Calendar
179: Baja Forums
181: Baja Forums
182: Baja Forums
183: Baja Forums
184: Baja Forums
185: Baja Forums
Bill's Baja project
1 2 3 4 5 6 7 8 9
allisontech
allisontech
Posted: Thu Jun 07, 2012 01:06 AM
Well body is at the painters, got a little more progress to share
Heading to Sylva NC for a little vacation, body should be in paint when I get back. Talk to you in a couple weeks!
Posted: Thu Jun 07, 2012 02:38 AM
The bug is looking good have fun on your vacation
Posted: Mon Jun 11, 2012 07:45 PM
What color?
allisontech
allisontech
Posted: Mon Jun 18, 2012 01:40 PM
Lime green,,, FJ5 I think is the color code "Lime squeezin green from Eastwood"
Posted: Mon Jun 18, 2012 04:52 PM
Not another Lime Green Baja, "There can be only one!"
Why do you think I picked such and odd color 20 years ago? So I could find my car in the parking lot with all the other Red, Yellow, Yellow, Blue and White Bajas.
Smile
allisontech
allisontech
Posted: Mon Jun 18, 2012 08:29 PM
This one will be in Florida so unless you come to visit we should be good to go! LOL
allisontech
allisontech
Posted: Tue Jun 19, 2012 01:54 AM
Ok I have the engine apart and the previous owner said this was a 2074 stroked engine. Looks like the crank has weights welded on and it has 8 dowels at the flywheel. The cam is way to big it says Engle 130 I think I should step down to a 120 or 110. I'm going to post some pics if anyone can give me some insight to what I have the comments would be greatly appreciated.
What the hell are these little jets for looks like oil is in them?
Pictures of the crank
Here are some pictures of the heads
The block
Please let me know what I have here Question
dave46
dave46
Posted: Tue Jun 19, 2012 12:19 PM
I believe the brass jets are oil squirters. Behind the jets they probably drilled through into the main bearing oil passages. They are to spray a metered amount of oil into the bottom of the piston cavity. This should help to cool the underside of the piston. Theoretically then you can run more ignition timing and / or more boost on a blown or turbo motor without detonation. You cannot spray too much oil or you run the risk of overwhelming the rings and pushing oil past the piston into the combustion chamber.
This is cool as I have never seen this done on a VW engine. I may have to try this on my next motor.
allisontech
allisontech
Posted: Tue Jun 19, 2012 09:52 PM
Well that's good news for once, "no signs of oil fouled plugs so the amount must be close". Any ideas about the crankshaft,is a welded counter balanced type acceptable and what is the chance the stroke has been increased?
Posted: Tue Jun 19, 2012 11:21 PM
Those are piston oils. Any picture of the intake port. While it might be an illusion those look like stock valves. Do you have a picture of the intake port. For the Baja a w 100 or W 110 style cam would be the smart choice.
allisontech
allisontech
Posted: Wed Jun 20, 2012 12:34 AM
No but I have to agree the heads look like the least modified parts other than the rocker shafts and elephant foot adjusters and the double springs, the heads do have bronze guides though. I think the PO may have had high dollar heads on the engine and removed them when he sold me the car.
allisontech
allisontech
Posted: Fri Jun 22, 2012 01:24 AM
Well taking very crude measurements with a caliper seems like stroke is 69mm so it looks like the crank has just been counter weighted not off set ground. So looks like a 1915 is what I really have here.
allisontech
allisontech
Posted: Sat Jun 23, 2012 03:33 AM
Ok I got good news and bad news today at the machine shop, the crank and case are both good to go just clean um up. 25mm rods and mains, case is standard and has not been cut. Bad news is the 041 heads,they installed 40 mm intakes but they cut the bejeezus out of the chambers "There only 30 CC measured without the .040 copper gaskets. Doing the math I will need a .090 barrel shim, and will need to stack a .060 and .030 copper head shim to get me in the 8.5 comp ratio range. The engine will be a 1914/15 is this going to be acceptable? I hate to buy another set of heads I'm not looking to build a race engine here. The 10 + comp ratio just isn't going to work in the Florida heat. A penny for your thoughts Rolling Eyes
allisontech
allisontech
Posted: Fri Jul 13, 2012 10:36 AM
Engine is almost complete, ended up being a 8.3 compression ratio. Heads are 41 type with 40 intakes and a very mild port matching job. Going with a single 40 carb ,to keep the tires from throwing water up at dual carbs. Could have made allot more power with duals but I'm not looking for max power here.
Still no body yet from the painter,so next will be making the E brake cables work with the aftermarket trailing arms.
Posted: Sat Jul 14, 2012 04:30 AM
Looks real good. Keep up the good work.
1 2 3 4 5 6 7 8 9
4 Admin_AzBaja 5208 Baja Bugs on Wiki need...
1567 mufasavnvmc 854327 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 209093 Re: Baja sightings
Off-road event
1 wideopenmotorsports 353 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
1170 Dalton 260156 My 69 project
 Wed Dec 06, 2017 01:38 AM
