Visitors: 106
Total: 106
39: Event Calendar
62: Event Calendar
1 2 3 ... 82 83 84 ... 103 104 105
ChinookFE
ChinookFE
Posted: Mon Jun 04, 2012 04:38 AM
Got the carb torn down to start a rebuild. Got the parts soaking in carb cleaner overnight.
Hyperwrx
Hyperwrx
Posted: Thu Jun 14, 2012 04:34 AM
Got engine rebuilt and ready to be bolted up tomorrow. Thanks goes out to Jeremy for his help and insight. Mild turbo motor to last me while we get after a 2180cc.
Engine specs-
1776cc
-7.6:1 compression
-Garret Air Research T28 .42/.48 turbo- powder coated cold
side/high temp paint hot side.
-Apexii BOV
-Lightened flywheel
-1.25:1 Rocker arms on solid shafts
-Total Seal rings
-Engle 110 cam- .392" Lift And 284 Duration And 108 Lobe Centers
-Magna Spark II Distributor
-MSD coil
-MSD 6AL-2
-MSD BTM
-Stock heads with 42cc chambers
-Innovative Motorsports MTX-L air/fuel gauge
-Weber 40 IDF- turbo prepped
-Ceramic coated T3 header
-E200 electric fuel pump
-Boost sensitive fuel pump
1-1 x 11 Mesa 98 pass oil cooler w. electric fan
-Kush Lock Clutch and 1700# stage 1 pressure plate
-Stock magnesium case- AH 1973/74 1600cc - 8mm head studs with
case savers,sand seal, and full flowed
-Heavy duty 32mm oil pump taped for full flow
-Chromoly push rods
-Balanced stock rods
Posted: Thu Jun 14, 2012 08:30 AM
looks sweet. nice to see another turbo baja. how many psi boost? that stage 1 pressure plate might not last. i had to step up to a stage 2 with 5psi on a 1915cc
Hyperwrx
Hyperwrx
Posted: Thu Jun 14, 2012 10:03 PM
10 psi
Ejbbal21
Ejbbal21
Posted: Fri Jun 15, 2012 08:10 AM
Ok yesterday I pulled the rear cage, motor and Trans. By the way no easy feat. When you go turbo it takes twice as long to pull with all the extra hoses wires ect. Anyways so the reason for pulling everything is my nose cone on my 091 came loose and needed to be resealed. I replaced all i mean all the bolts in the trans with studs and lock nuts. While I was at it I swapped the bell housing with a diffrent one. My old one had a extra hole from a past loose bolt. I put in a new input shaft seal on the new bell housing. While I had the Trans out I replace the inner pivots with poly ones. They looked a worn. I got the arms, Trans and CV's all put back in. I'm going camping with my 2 boys Friday night so Saturday afternoon the motor will go back in. I built the rear cage last year and I'm finally going to clean up the welds and paint it. Same for the front bumper. I will post some pics on saturday. By the way thanks Scott for the props on your turbo motor post.
Ejbbal21
Ejbbal21
Posted: Fri Jun 15, 2012 08:18 AM
In my opinion the stage one is enough. With the setup in my car (2332) with twice the motor and 3 times the boost (15psi) the stage one is enough. Besides you can't run a stage 2 with a stock clutch peddle. You will pull/break off the hook. Not say he's wrong just my opinion. There's more then one way to skin a cat so to speak.
Posted: Fri Jun 15, 2012 08:37 AM
been running the stock pedal assembly since i've owned the car (3+ years). Been running the stage 2 pp for about 2, and have had the same pedals and same clutch cable for those last 2. has yet to be a problem. just saying.
Ejbbal21
Ejbbal21
Posted: Fri Jun 15, 2012 06:41 PM
Posted: Sun Jun 17, 2012 07:11 PM
Road around Wilkesboro in it then washed it.
Ejbbal21
Ejbbal21
Posted: Sun Jun 17, 2012 07:33 PM
I installed my motor and rear cage last night then drove my baja over to Scott's "hyperwrx" house to help him get his motor installed. He's getting closer to have a drivable car again. It looks like we will be wiring up his msd 6al this week so he can be on his way.
Posted: Mon Jun 18, 2012 04:44 PM
Took some parts to BugZ's to have work done on them. New Car Alarm put into the car. New MSD Box (Did the Street Fighter this time over the 6A Off Road). Put in the wires for the Under Dash and rear deck lights aka Dome Lights. Did wiring for the the starter and electric fan.
Hooked up power to the car for 1st time in about 2 years. Fuel pump came on and pumped some real bad smelling stuff onto the drive way.
Note to Self: Need to hook up new fuel line and filters tomarrow.
Posted: Mon Jun 18, 2012 06:20 PM
Yes progress. i like it!!!!!!!
Hyperwrx
Hyperwrx
Posted: Wed Jun 20, 2012 05:05 AM
Worked for a few hours on wiring in the MSD 6AL-2 and MSD BTM.
Purchased the following today-
Red Sway-A-Way 2.0 Coilover 12" shocks with reservoirs
3x3 trailing arm (boxed)
brakes (drums)
axles
micro stubs
inner, outer 930 cvs
mounting heims
bushings
1450bug
1450bug
Posted: Thu Jun 21, 2012 06:45 PM
Ordered dual pivot 5x5's
Posted: Fri Jun 22, 2012 04:39 PM
Hooked up the fuel line and filter, New throttal cable and reworked cable pull mount. Pulled pedles out and adjusted clutch cable. Repainted rear eingine cage and engine mount Krylon Blue. (Welders and grinders are not nice to Krylon Blue spray paint) Most internal electrical work is done in the rear seat area of the car. (Every thing lives here that runs most of the car). Painted (Rust-Oleum Black) most of non driver side floor pans and battery area. Need to paint the cage Krylon Blue again
Need to install bake half of cage with tail lights and rewire the engine and rear end of the car next. Also need to hook up the raditor and electric fan at this time.
Brakes are not working...Need to bleed them would be my guess from the time the 930 stub axles were put into the car. Will put new rear pads on the car at the same time too.
Front end needs to come apart and get blue paint over the welder burns, grinder spots and new metal.
Need to come up with some sort of battery hold down strap. Battery lives in one of the plastic boxs in the back seat area.
Tan 2x4 Jeep Cherokee needs to have brakes checked and replaced front and rear.
Red Van needs to have rear pads replaced. Front pads and disc were done a month or so ago.
285 MusicManiac 209691 Re: Baja sightings
Off-road event
1 wideopenmotorsports 394 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3325 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What is my Baja really worth? 1 Treeposter 959 What is my Baja really...
 Sat Jun 17, 2017 04:06 PM
