Latest: BlackIrish05009
Overall: 3574
Visitors: 249
Total: 249
31: Pictures
51: Event Calendar
52: Groups
59: Event Calendar
82: Pictures
83: Pictures
85: Event Calendar
126: Pictures
130: Event Calendar
137: Pictures
141: Event Calendar
152: Event Calendar
158: Baja Forums
164: Baja Forums
166: Baja Forums
168: Baja Forums
171: Baja Forums
173: Baja Forums
176: Baja Forums
177: Baja Forums
178: Baja Forums
180: Baja Forums
181: Baja Forums
182: Baja Forums
183: Baja Forums
184: Baja Forums
185: Baja Forums
187: Baja Forums
189: Baja Forums
191: Baja Forums
193: Baja Forums
194: Baja Forums
196: Baja Forums
197: AMAZON.com
198: AMAZON.com
200: Baja Forums
202: Baja Forums
203: Baja Forums
204: Baja Forums
205: AMAZON.com
206: Baja Forums
207: AMAZON.com
208: Baja Forums
209: AMAZON.com
210: Baja Forums
211: Baja Forums
212: Baja Forums
213: Baja Forums
214: Baja Forums
215: Baja Forums
216: Baja Forums
217: Baja Forums
218: Baja Forums
219: Baja Forums
220: Baja Forums
221: AMAZON.com
223: Baja Forums
224: Baja Forums
225: Baja Forums
226: AMAZON.com
227: Baja Forums
228: Event Calendar
229: Baja Forums
230: AMAZON.com
231: Baja Forums
232: AMAZON.com
233: Baja Forums
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: Baja Forums
238: Pictures
239: AMAZON.com
240: Baja Forums
241: AMAZON.com
242: Baja Forums
243: Baja Forums
244: AMAZON.com
245: Baja Forums
246: AMAZON.com
247: AMAZON.com
248: Baja Forums
249: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Stretched pan and body
mkingaz
mkingaz
Post Post subject: Stretched pan and body
Posted: Wed Apr 18, 2012 10:10 PM
Anyone have any advise on stretching a pan and body? I'm working on a baja build and seriously thinking about cutting the top off and stretching the pan and shell 6 to 12 inches to allow more leg room for a rear seat. My thought was remove the top for more head room and ease of getting into the baja in the rear. Then I started thinking about stretching it 6 to 12 inches and making the cut about 3 inches behind the doors and moving it back. I think I could make the pan very solid with the new roll cage and tie everything in. The roof would be gone so just build a solid cage with rack on top and then use sheet metal or a donar bug to fill the 6-12 inch stretch side panels. I'm also going to make it mid to long travel front and back with 3x3 or 3x5 rear arms and an a arm front suspension. Any advice would be great. I live in north phx 55th ave and pinnalce peak area and have most all tools, cutters, benders, tig and mig welders, etc.
Thanks,
1450bug
1450bug
Posted: Wed Apr 18, 2012 11:13 PM
Sounds like you have it all figured out. The hardest part will be cutting it in half. let me know if you need an extra hand. I am not to far away (new river).
Posted: Fri Apr 20, 2012 08:03 AM
Seems it would make more sense and probably be less $$ to buy fiberglass VA convertible body panels like for a Class 5 race Baja to do a stretch Baja. Crumco and Kartek have them.
Post Post subject: Re: Stretched pan and body
Posted: Mon May 14, 2012 06:24 PM
You come up with any ideas. I have seen a couple of 4 door Bajas with just a soft top over the cage.
mkingaz
mkingaz
Posted: Mon May 14, 2012 08:49 PM
I've build a jig for the past week to keep the pan square and help me with measuring points when also build the front long travel. I'm going to cut the pan and body about 5 inches behind the door seal. I really want the rear of the body to stay in tack and use the fire wall already on. I already cut the top off. I have my eye on another body at the minute and thinking about buying to fill the side panels in with steel. My main goal here is to get about to 5 to 8 inches of leg room for the rear seats. The roof is going to be a custom roll cage with a soft top or floor type storage are (ie. tire, etc up top). I'm kind of stuck until I can pick up a transaxle. I'm trying to find a cheap 002 for the V6 Honda motor that I have. I need the transaxle to help line the new roll cage up, going from front to back all tied in. I have decided not to widen the bug, just to much work. Thanks guys.
25 Kreed 23030 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts VW Volkswagen & Baja Bug General Discussion BODY REMOVAL '66 BAJA (HELP!) 5 ClassZero 3865 BODY REMOVAL '66 BAJA ...
 Sat Sep 07, 2013 05:08 PM
ClassZero View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Body Lifts 2 Darn_Near 2333 Re: Body Lifts
 Sun May 12, 2013 08:24 AM
No new posts VW Volkswagen & Baja Bug General Discussion body lift 2 elryano 2174 Re: body lift
 Thu Apr 12, 2012 09:58 PM
elryano View latest post
No new posts VW Volkswagen & Baja Bug General Discussion body lift 1 elryano 1873 Re: body lift
 Thu Apr 12, 2012 02:21 AM
