Latest: Smokey4
Overall: 3593
Visitors: 114
Total: 114
19: Pictures
24: Pictures
67: Event Calendar
88: My Account
110: Home
1 2 3 ... 79 80 81 ... 103 104 105
Posted: Sat Apr 21, 2012 05:24 PM
Nothing today but gonna pull the engine on project II and disassemble it for a rebuild, hope to have it done by th 12th for the Castle Run.
Posted: Sat Apr 21, 2012 06:50 PM
Do you need any of my spare parts?
Posted: Sat Apr 21, 2012 07:51 PM
gotta tear it apart first i will let you know.
Hyperwrx
Hyperwrx
Posted: Sun Apr 22, 2012 06:03 AM
Bought 4 fox shocks w/ res., T28 with intake, header, BOV, CB Max 5 oil pump and lines, Weber 40 prepped for turbo, fuel reg and pump, misc lines and such.
As an afterthought purchased some grey tweed front door panels and hardware.
Going to need to finally take the baja to Bugzyla and have some fab work done. I have done all I can.
Posted: Sun Apr 22, 2012 11:30 PM
Finished lining & wants his new torsions plates and groms yesterday.
Its gotta roll in a month and some change.
What can one DO......
Posted: Tue Apr 24, 2012 03:31 AM
Pulled the motor and tore it apart, no spun bearings but #1 rod bearing looks suspicious, has a strange wear pattern on it. Gonna have the crank resurfaced, replace all the bearings, get a new set of 87mm pistons & liners, clean up the heads, and hopefully have it back together by the 12th for the run
Posted: Tue Apr 24, 2012 05:01 AM
Sounds good!!!
Posted: Fri May 04, 2012 04:52 PM
Had crank checked and its still good, gonna replace the bearings, and add a set of slightly used (200 miles) 87mm mahle forged pistons and liners and a set of ratio rockers (thanks TINMAN) should be ready for the run(if I get the time to finish it)
64vwbug
64vwbug
Posted: Fri May 04, 2012 11:26 PM
new seat covers. did them a while ago but just now posting pics[img][/img]
Posted: Sat May 05, 2012 06:52 AM
Finally got my Torsions and plates fron the Latest Rage.
Splines are a touch tighter then SAW....but SAW does a better manicure on there plates.
Dove right in and notch to 16* after trimming the spring plate stops.
Mocked it up with my beefed stock arms. SWEET
Will clean up there sharp edges tomorrow and twist a degree and some change into a preload leaving about 8* on top for recommended max twist.
Still impress with the better range on the 24 inch torsions @ 29mm instead of the 21 @ 28
Posted: Mon May 07, 2012 05:59 AM
I waved goodbye at it. Time for a new project.
Posted: Mon May 07, 2012 02:25 PM
Now that it is the next day are you missing it?
Posted: Mon May 07, 2012 08:33 PM
Kind of but they were very excited over it which makes up for it.
Posted: Tue May 08, 2012 05:11 AM
Installed the Sun Pro monster tach and most of the wiring. A few more little things and it is go time.
Posted: Tue May 08, 2012 07:08 AM
KUDOS........Thump.
Pickup a great one and run....cause i wanna watch Smile
5 Admin_AzBaja 7412 Baja Bugs on Wiki need...
285 MusicManiac 246869 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 512 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1658 Re: Had to go play in ...
0 Northmountainauto 1805 Shop Baja
