Visitors: 267
Total: 267
44: Event Calendar
84: Pictures
85: Pictures
96: Pictures
97: Pictures
107: News Letter
116: Event Calendar
121: Event Calendar
124: My Account
157: Baja Forums
167: My Account
171: Drivers
181: Baja Forums
183: Baja Forums
188: Baja Forums
189: Baja Forums
191: Baja Forums
192: Baja Forums
193: Baja Forums
197: AMAZON.com
198: AMAZON.com
199: Event Calendar
202: Baja Forums
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
211: Baja Forums
212: AMAZON.com
213: Event Calendar
214: AMAZON.com
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
228: Baja Forums
229: Baja Forums
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: Baja Forums
247: My Account
248: AMAZON.com
249: Baja Forums
250: AMAZON.com
251: Baja Forums
252: Baja Forums
253: AMAZON.com
254: Baja Forums
255: Pictures
256: AMAZON.com
257: Baja Forums
258: AMAZON.com
259: AMAZON.com
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: AMAZON.com
266: AMAZON.com
267: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Just picked up a 1964 baja
Gabe64
Gabe64
Post Post subject: Just picked up a 1964 baja
Posted: Fri Apr 27, 2012 03:18 AM
Hey guys I just recently traded my quad for a 1964 baja bug as my first car, ive always been interested in VWs and i finally got one and had a few questions. Its a 1642 dual port with a dalarto carb and empi stinger, sounds good but it boggs out sometimes im thinking it needs a carb adjustment but a friend said it could be the spark pulgs (i replaced dist cap and rotor recently). we checked spark plugs and wires and they seem fine but the bogg bothers me. Also it does have an electronic fuel pump a spectre but im not sure if that could be a problem either. I was also told it could just be me because im not used to the car completely any suggestions would be great. I would upload piks but im still learning how to use the site ill upload some asap.
Gabe64
Gabe64
Posted: Fri Apr 27, 2012 03:27 AM
its a 1641*
Posted: Fri Apr 27, 2012 03:42 AM
The Dellorto carb doesn't like fuel pressure more than about 3-4 psi. The electric fuel pump may be producing as much as 7-10psi. You can get an inexpensive fuel pressure gauge and put it between the fuel pump and carb on a tee fitting to check pressure. There are inexpensive fuel pressure regulators available to control it if it has too much pressure. I have one of the cheap ones on my car. It works fine, but the numbers on top do not produce the same pressure according to the gauge. So I set the regulator by the gauge. Then I put a dab of weatherstrip glue on the edge of the knob to keep it from turning and took the gauge out.
Gabe64
Gabe64
Posted: Fri Apr 27, 2012 03:47 AM
I think i may have one its set to 4 psi but the previous owner didnt block off the stock fuel pump right could that be an issue as well? thanks for the response
Posted: Fri Apr 27, 2012 04:52 AM
You could leave the stock pump in place with the hoses bypassing it to the carb. That would work fine.
Or if you remove the stock pump from the block, you need to take out the pump push rod and the bakelite pump rod guide, then install a blockoff plate on the studs.
One of the folks on here had a stock fuel pump fail, so he went to a parts store and bought a pump like yours and a blockoff plate. He didn't know the push rod and bakelite needed to come out. After a while, the push rod hammered it's way through the blockoff plate.
Posted: Fri Apr 27, 2012 05:00 AM
With my regulator set at '2', it made nearly 5psi. So it's set below '1' and makes about 2.5psi. Works nice that way for my Kadrons.
Although I ran the same carbs set up the same on the 1641 in my 67 Bug for over 100K miles with no regulator and no issues. Don't know why on my Baja they need regulators.
Gabe64
Gabe64
Posted: Fri Apr 27, 2012 05:02 AM
Yea i was planning to do that this weekend along with a breather box. By the way i checked out the socal baja site im in Ontario and realy interested in the meetings and what not any info on them would be appreciated!
Gabe64
Gabe64
Posted: Fri Apr 27, 2012 05:08 AM
Do you think mine set at 4 is making to much and causing it to bogg?
5 Admin_AzBaja 6776 Baja Bugs on Wiki need...
1568 mufasavnvmc 999016 Re: what did you do to...
285 MusicManiac 241281 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 15 FREE VW BAJA'S
