Members: 1
Visitors: 101
Total: 102
 Members:
01: JWHracing > Home
39: Event Calendar
43: Pictures
45: Event Calendar
95: Pictures
100: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Just picked up a 1964 baja
Gabe64
Gabe64
Post Post subject: Just picked up a 1964 baja
Posted: Fri Apr 27, 2012 03:18 AM
Hey guys I just recently traded my quad for a 1964 baja bug as my first car, ive always been interested in VWs and i finally got one and had a few questions. Its a 1642 dual port with a dalarto carb and empi stinger, sounds good but it boggs out sometimes im thinking it needs a carb adjustment but a friend said it could be the spark pulgs (i replaced dist cap and rotor recently). we checked spark plugs and wires and they seem fine but the bogg bothers me. Also it does have an electronic fuel pump a spectre but im not sure if that could be a problem either. I was also told it could just be me because im not used to the car completely any suggestions would be great. I would upload piks but im still learning how to use the site ill upload some asap.
Gabe64
Gabe64
Posted: Fri Apr 27, 2012 03:27 AM
its a 1641*
Posted: Fri Apr 27, 2012 03:42 AM
The Dellorto carb doesn't like fuel pressure more than about 3-4 psi. The electric fuel pump may be producing as much as 7-10psi. You can get an inexpensive fuel pressure gauge and put it between the fuel pump and carb on a tee fitting to check pressure. There are inexpensive fuel pressure regulators available to control it if it has too much pressure. I have one of the cheap ones on my car. It works fine, but the numbers on top do not produce the same pressure according to the gauge. So I set the regulator by the gauge. Then I put a dab of weatherstrip glue on the edge of the knob to keep it from turning and took the gauge out.
Gabe64
Gabe64
Posted: Fri Apr 27, 2012 03:47 AM
I think i may have one its set to 4 psi but the previous owner didnt block off the stock fuel pump right could that be an issue as well? thanks for the response
Posted: Fri Apr 27, 2012 04:52 AM
You could leave the stock pump in place with the hoses bypassing it to the carb. That would work fine.
Or if you remove the stock pump from the block, you need to take out the pump push rod and the bakelite pump rod guide, then install a blockoff plate on the studs.
One of the folks on here had a stock fuel pump fail, so he went to a parts store and bought a pump like yours and a blockoff plate. He didn't know the push rod and bakelite needed to come out. After a while, the push rod hammered it's way through the blockoff plate.
Posted: Fri Apr 27, 2012 05:00 AM
With my regulator set at '2', it made nearly 5psi. So it's set below '1' and makes about 2.5psi. Works nice that way for my Kadrons.
Although I ran the same carbs set up the same on the 1641 in my 67 Bug for over 100K miles with no regulator and no issues. Don't know why on my Baja they need regulators.
Gabe64
Gabe64
Posted: Fri Apr 27, 2012 05:02 AM
Yea i was planning to do that this weekend along with a breather box. By the way i checked out the socal baja site im in Ontario and realy interested in the meetings and what not any info on them would be appreciated!
Gabe64
Gabe64
Posted: Fri Apr 27, 2012 05:08 AM
Do you think mine set at 4 is making to much and causing it to bogg?
4 Admin_AzBaja 5213 Baja Bugs on Wiki need...
1567 mufasavnvmc 855094 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 209253 Re: Baja sightings
Off-road event
1 wideopenmotorsports 362 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3306 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
