Visitors: 109
Total: 109
03: Home
11: Event Calendar
28: Event Calendar
41: Event Calendar
45: Event Calendar
87: Event Calendar
95: Event Calendar
100: Event Calendar
106: Event Calendar
Psuedo Class 11
1 2 3 ... 12 13 14
Posted: Tue Mar 20, 2012 04:17 PM
MojaveRacer208 wrote:
Good job!
x2 Now your going to need better shocks.
Posted: Sat Mar 24, 2012 05:35 AM
I found my carb was giving me fits. A local guy had 2 new Brosol 30/31 carbs that were still in the box. I picked one up. Although its never been used, I bet it was 15+ years old.
I mounted the carb and it ran much better. I advanced the timing a few degrees as well. I also installed the rubber seal/fire hose at the front of the engine. I have a tapping noise still that sure sounds like it is coming from the right side. I'll check the valves in the morning.
Posted: Mon Mar 26, 2012 05:54 AM
I readjusted the valves and retimed the car again. It is really running good. The valve noise is much quieter.
I took it to the bugarama today and met some great people. I bet 60+ people rubbed the paint on my car and had positive comments. I had the only bedliner car there.
TINMAN
TINMAN
Posted: Tue Mar 27, 2012 01:11 AM
I know you caught me rubbing at least once. I love avacado and i was hungry.
TRUMP 2020
Posted: Wed Mar 28, 2012 05:44 AM
The alternator bearing is already squealing at me. Less than 1 month old. You got to love Chinese quality.
Posted: Wed Mar 28, 2012 06:26 AM
Might be too much belt tension.
Might be a slipping belt.
Posted: Wed Mar 28, 2012 08:26 AM
Shim it....nice call Richard
What can one DO......
Posted: Wed Mar 28, 2012 02:39 PM
The belt was very loose because it was the wrong size. Plus it started making a gravel type noise. I put a new belt on and had the tension with about a 1/2" deflection and the noise developed. I adjusted tension so it has 1" deflection, and it is still there. The pulley is hot to the touch. I disconnected the belt and ran it for a minute- no noise. I'll pull it this week and exchange it under warranty.
Posted: Mon Apr 02, 2012 06:23 AM
Eric did a good job on my engine. I like the power this engine has. My gearing and tire size works out well and I'm averaging 23.5 MPG. The new carb works great and I quieted the valve train for the most part. I put deck lid stand offs on today. That seems to make a big difference in the engine compartment heat level. I don't have my CHT gauge set up yet, but the heat seems less when I touch items in the compartment.
I had taken the bug to the Bug-a-rama last weekend and spoke to a lot of people. Some had seen it online and thought it was cool. I had the only bedlinered bug there! Go figure...
I stiffened the front beam by moving the adjuster. It leveled it out. The new alternator's bearing is still making noise. I'll change it in the future. Good thing the Chinese alternator has a lifetime warranty.
Posted: Sat Apr 14, 2012 07:51 AM
I had listed it for sale briefly, but pulled the ad. The guys from this club were too much fun to hang out with. They broke me like a rented mule. The bug now has 215/75r15 AP type tires on it. I prefer the size, but the General Grabber's tread looks better.
Posted: Sat Apr 14, 2012 04:31 PM
Let me know when you want to order a set.
Posted: Fri Apr 20, 2012 11:52 PM
I've not done much to the bug lately, but took it for a spin today. Sounds like the rear brakes are chirping. I am still not satisfied in the tire department.
When I built the bug, I put 225/70r15 on the 4" wide VW sport rims. I couldn't go too big because I had the little 1385cc engine. Although I have IRS and it was geared with 4.37 r/p, the little engine couldn't move the bug in 4th gear because 4th was .82. So, I bought new 205/75r15. That helped some, but as you know, I eventually sold that little engine and have a fresh 1600 SP now. That reallg made a difference. I went from the 205/75r15 Grabbers to 215/75r15 less aggressive tires a friend gave me. No rubbing, but I want to go bigger!
So, now I am in this quantry... what size? My steering stops were adjusted early on because of contact with the 225/70r15's. I have a 3" body lift AND adjusters in the front. But, my rim is only 4" wide. The 7.00x15 look cool but might be pretty rough on all 4 corners. A 235/75r15 is an option, but seems wide for my rim. The 225's seemed to bulge pretty good when they were mounted.
Posted: Sun May 06, 2012 11:38 PM
Here is Paul, the bug's new owner. He and his father now have baja's and will become members. I am on the prowl for a new project now.
Posted: Mon May 07, 2012 12:26 AM
NOOOOOOOOOO!!!!!! Well everything comes & goes in the baja world. Guess you will have to take the rally soul on the run. Smile
Posted: Mon May 07, 2012 01:57 AM
That was fast. Now what???
Keep us up to date on what you end up with.
1 2 3 ... 12 13 14
25 Kreed 26287 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5255 New Class 11 Build - P...
60 wideopenmotorsports 47448 CLASS 5 Resurrection!
 Mon Feb 22, 2016 05:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 3397 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
No new posts Projects and Builds Class 11 PepeAzul 3 pepeazul 5551 Class 11 PepeAzul
 Fri Jul 17, 2015 02:29 PM
