Visitors: 139
Total: 139
12: Pictures
26: Event Calendar
29: Event Calendar
39: Event Calendar
79: Event Calendar
80: Event Calendar
93: Pictures
99: Event Calendar
100: Contact Admin
104: Event Calendar
112: Event Calendar
117: Event Calendar
124: Event Calendar
128: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- One Step Closer.....
Jimmyjack
Jimmyjack
Post Post subject: One Step Closer.....
Posted: Sat Nov 18, 2006 04:42 PM
To glory or kicking this thing out to the curb Confused I got it to run after replacing the distributor, coil and plugs and wires. I haven't touched the carb but I need to replace the fuel pump before I can tell how it's working.
I replaced the MC and bled it so now the two front brake lines are weeping, and I broke off all of the bleed screws so I'm replacing them next. Rolling Eyes
After that I'm buying tires and then I'll get to drive it. It fired right up once I figured out the timing issue. It smoked for a few seconds but gee whiz, it's been sitting for almost ten years!
So please tell me to keep up the good job cos I'm losing really bad lately and I'm about to throw under a car cover.
Jimmyjack
Jimmyjack
Post Post subject: Re: One Step Closer.....
Posted: Sat Nov 18, 2006 07:51 PM
It's lives! Installed the fuel pump, reset the timing (AGAIN). The rotor wasn't turning. I discovered it wasn't seated all the way down so the engine turned but the rotor just sat. Anyway it fired right up and I'm feeling better now. Still gotta do the brakes and tires.......
Posted: Sat Nov 18, 2006 08:02 PM
Jimmyjack-
nice work man Very Happy
it may be the hard way to start with vw's, but you learn a lot! Cool
No new posts VW Volkswagen & Baja Bug General Discussion Hopefully getting closer! 5 az350x 1767 Re: Hopefully getting ...
 Tue Jan 01, 2008 09:40 PM
Kev_n_AZ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion first step 5 pocketchange 2100 Re: first step
 Fri Jun 29, 2007 06:45 PM
DONT View latest post
