Latest: neal18
Overall: 3585
Visitors: 297
Total: 297
38: My Account
39: My Account
40: My Account
59: My Account
62: My Account
65: Event Calendar
80: My Account
85: My Account
87: My Account
88: My Account
89: Pictures
92: My Account
125: Pictures
130: Pictures
133: Pictures
138: Home
162: Baja Forums
163: My Account
164: Baja Forums
167: Pictures
170: My Account
171: Baja Forums
173: My Account
177: My Account
179: My Account
180: My Account
188: Event Calendar
190: AMAZON.com
196: Baja Forums
197: Baja Forums
198: AMAZON.com
200: Baja Forums
201: Baja Forums
202: Baja Forums
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: Pictures
212: Pictures
213: Baja Forums
214: AMAZON.com
216: Pictures
217: Baja Forums
218: AMAZON.com
219: Baja Forums
220: Baja Forums
221: Baja Forums
222: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: Baja Forums
229: Baja Forums
230: Baja Forums
231: Baja Forums
232: AMAZON.com
233: Baja Forums
234: Baja Forums
235: Baja Forums
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: AMAZON.com
240: Baja Forums
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: Baja Forums
246: AMAZON.com
247: Baja Forums
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: Baja Forums
254: Baja Forums
255: Baja Forums
256: Baja Forums
257: Baja Forums
258: Baja Forums
259: Baja Forums
260: Event Calendar
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: Event Calendar
265: AMAZON.com
266: AMAZON.com
267: AMAZON.com
268: Baja Forums
269: Baja Forums
270: AMAZON.com
271: Baja Forums
272: Event Calendar
273: AMAZON.com
274: AMAZON.com
275: AMAZON.com
276: Baja Forums
277: AMAZON.com
278: Pictures
279: AMAZON.com
280: AMAZON.com
281: AMAZON.com
282: My Account
283: AMAZON.com
284: AMAZON.com
285: AMAZON.com
286: Baja Forums
287: AMAZON.com
288: AMAZON.com
289: Baja Forums
290: AMAZON.com
291: Baja Forums
292: AMAZON.com
293: AMAZON.com
294: AMAZON.com
295: My Account
296: AMAZON.com
297: AMAZON.com
1 2 3 ... 77 78 79 ... 103 104 105
MuddyPruett69
MuddyPruett69
Posted: Sat Feb 25, 2012 07:26 PM
walked out back, saw it sitting and rotting away......died a little inside
I wana sell stuff!!
Posted: Sun Mar 04, 2012 03:17 AM
FINALLY finished the stinger exhaust today. Cool Rolling Eyes Also installed new ceramic coated heat exchangers and lower tins (sleds).
Boys she sure sounds damn good!
TINMAN
TINMAN
Posted: Sun Mar 04, 2012 11:26 PM
Built a engine dolly for those days im woking solo
TRUMP 2020
Pointvirus
Pointvirus
Posted: Mon Mar 05, 2012 12:19 AM
I'm sanding the rear part of the interior today. It's looking bad..
Posted: Mon Mar 12, 2012 09:20 AM
Put on the water pump this weekend and radiator will go back in next week.
Posted: Sat Mar 17, 2012 09:11 PM
I hooked up the fresh air hoses, the heater and mounted the front KYB shocks- filled up $3.89 a gallon and will drive it like I stole it! I love this new engine!!!!
Posted: Sat Mar 17, 2012 10:17 PM
Had the old rear tires removed from the rims, so we can clean them up and paint them before the new generals get here Tuesday.
Posted: Sun Mar 18, 2012 01:34 AM
Still wiring, wiring, and wiring. I can just about see the end of it. I have all the front lights, gage lights and indicator lights wired. Had a problem with the turn signals not working but that turned out to be a defective 4 to 3 wire adapter. Toke it back to the Napa store and even after having it for 6 months they traded it for a good one.
Posted: Sun Mar 18, 2012 01:35 AM
Installed new angled/polished oil filler neck and cap since I lost the old cap (don't ask) last week put'n around town. Me likey.. Cool Also set the timing correctly and re-synced the Kad's. No more ping after she warms up. Even on 86 octane. So far.... Wink
Adjusted rear brakes a bit tighter this time. No more pumping the brakes. Cool
Tried out my plastic welder and welded up the crack on the fresh air box. Worked pretty good for my first time welding plastic. I still RTV'd the inside just in case. Now gotta cut a hole in the hood for it. Not looking forward to that. Crying or Very sad Rolling Eyes
Posted: Sun Mar 18, 2012 06:20 PM
Changed the oil and adjusted valves. I'm fabricating an engine seal extension using a firehose. I have a 3" gap because of the body lift. I figure the firehose should withstand the engine compartment temps, and be flexible enough to allow some room to change the spark plugs.
Pointvirus
Pointvirus
Posted: Fri Mar 23, 2012 03:06 AM
Found out that my trans is bad and I need a different one ):
and can't pull the pulley off of the generator to replace generators ):
Posted: Fri Mar 23, 2012 06:26 AM
Worked on my "Through the Tube" Bosses.
And cant wait to gun them.
Ran a touch heavier tubing for Ebrake cables and looked into a different handle position since i have alittle extra length. Hmmm
Its damn hard to build when you jones to roll it. lol
What can one DO......
Posted: Sat Mar 24, 2012 12:31 AM
I bought a new 30/31 carb from a local guy and installed it. I also advanced my timing and installed the firehose rubber seal near the firewall.
Posted: Sun Mar 25, 2012 01:56 AM
Finished repairing the fresh air box. Used stainless bolts/nuts to mate the top half back on in case I need to get back in there.
Also got it installed but no hole in the hood yet. Looks like I need to build up (actually down) the surface of the hood underneath to mate with the seal.
Posted: Mon Apr 02, 2012 12:15 AM
I installed decklod standoffs and stiffened my front beam's adjustors. Nasty little thoughts of posting it for sale are dancing in my head...
4 Admin_AzBaja 6710 Baja Bugs on Wiki need...
285 MusicManiac 240750 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1253 Re: Had to go play in ...
0 Northmountainauto 1493 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 4055 Baja hiding in Chandle...
