Latest: jor_dang420
Overall: 3597
Visitors: 118
Total: 118
05: Garage
15: Home
23: Event Calendar
33: My Account
44: Contact Admin
48: Event Calendar
64: Event Calendar
72: Home
81: Event Calendar
91: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- reductiong gear box ?
baja63
baja63
Post Post subject: reductiong gear box ?
Posted: Wed Mar 07, 2012 07:13 PM
I need to find gears for my reduction box for more speed. my stub axle is a 25 tooth small nut 55 to 63. where can I find new gears for better speed. and oh yea its in a 63 bug baja
thanks for any help
baja63
Posted: Thu Mar 08, 2012 09:30 AM
IIRC - that's it. There were so-called "Alpine Gears" for the bus, but I believe that was a different ring and pinion ratio. NOT reduction gears. You could change the ring and pinion to change the final drive ratio. One of the reasons to install a reduction box setup is the lower gears for lower offroad speed. You can keep your cake or you can eat it. Can't have both. You could also take the reduction box setup out of the car and switch to a conventional swingaxle.
Post Post subject: Re: reductiong gear box ?
Posted: Thu Mar 08, 2012 04:45 PM
There are a few different gears, but VERY hard to find. I have a RGB setup in my baja, and it tops out at 55 MPH with 33" tires on it. Best bet is to do what mojaveracer said and change the ring and pinion and possibly a higher 4 gear. Contact Dons Bus Box www.donsbusbox.com and he can tell you what it would run.
Posted: Thu Mar 08, 2012 07:46 PM
Welcome to AZ Bajas from the Mojave Desert.
I have a Baja Bug friend in Ridgecrest and I'm not too far away...south of Edwards AFB. And I know another Baja guy who lives in North Edwards who goes by the user ID of 63Baja on SoCal Bajas and HiDesert Bajas. His 63 doesn't have reduction boxes though and is IRS. Since you're in SoCal, I suggest Jeff Fields Transaxle Engineering in the San Fernando Valley.
I'll send you a PM.
baja63
baja63
Posted: Thu Mar 08, 2012 11:24 PM
thanks every one. I dont want to do 80 mpg just like to do a little faster then 45 top speed. I like the reduction box. I have 25 tooth stubs on mine and I have found a set of 21 tooth stubs and matching 15 tooth axle gear but I need one more axle gear. thanks for any help I get.
baja63
ps Ive tryed to join socalbaja but dont know how or were to sign up at ?
Posted: Fri Mar 09, 2012 10:59 PM
Check with Bob Kinnan who has a part-time VW shop in Ridgecrest. I'm not comfortable handing out someone else's personal contact info, so if you PM your info to me, I can forward it to Bob. He's a SoCal member who will host a run out of his shop in about a month.
SoCal Bajas: from the text box near the header on the home page of the Forum...
"If you are interested in becoming an official member, or just have questions, feel free to send a Private Message from this board to 57baja for details on how to get involved. "
1st step is to join yuku.
If you still have trouble, PM through this site.
baja63
baja63
Posted: Tue Mar 13, 2012 07:50 AM
I have meet bob and have goten some stuff from him. as soon as i can get ahold of him again I will talk to him som more about the reduction box
thank for your help Cool
No new posts VW Volkswagen & Baja Bug General Discussion Need wheels to fit my baja gear reduction boxes
wheels
6 dustinddm 5218 Re: Need wheels to fit...
 Sat Nov 07, 2009 08:14 AM
dustinddm View latest post
No new posts VW Volkswagen & Baja Bug General Discussion gear ratio's 3 1FASTHOE 2296 Re: gear ratio's
 Thu May 17, 2007 09:24 PM
Billy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Top Gear - Bugatti Veyron Speed Test 2 vwbill 2566 Re: Top Gear - Bugatti...
 Sat Feb 10, 2007 12:24 AM
1FASTHOE View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Pre Order Your AzBaja T-Shirts and Gear 7 AzBaja 3464 Re: Pre Order Your AzB...
 Thu Oct 12, 2006 06:47 AM
Arizonateacher View latest post
