Latest: Curtis
Overall: 3613
Visitors: 201
Total: 201
05: Event Calendar
11: Garage
65: Event Calendar
99: Event Calendar
122: Event Calendar
154: Event Calendar
157: Baja Forums
162: Baja Forums
172: Baja Forums
173: Event Calendar
179: Baja Forums
183: Baja Forums
185: Baja Forums
187: Baja Forums
190: AMAZON.com
197: AMAZON.com
198: Baja Forums
Psuedo Class 11
1 2 3 ... 11 12 13 14
Posted: Wed Feb 29, 2012 04:05 PM
Looks good. That little green bug will scoot now. Time to upgrade those blown out front shocks.
Posted: Wed Feb 29, 2012 06:14 PM
It is amazing the difference Fox shocks made on JWHs Baja.
Posted: Mon Mar 05, 2012 08:45 PM
She runs, but has a tapping noise under load. Replaced the push rods, rocker arm and adjusted the timing again and it does not go away. Looks like I need to pull it apart again to see whats going on.
Posted: Tue Mar 06, 2012 02:43 AM
That stinks, hope it turns out okay
Posted: Thu Mar 08, 2012 07:07 PM
Rods were over torqued and bearing showed a lot of wear for being only run for 30 minutes. Gonna replace the rod bearings, add double thrust cam bearings, triple check everything else, and put it pack together tomorrow.
Posted: Fri Mar 09, 2012 02:45 AM
YEEEEEEEEHHHHHHHHAAAAAAAAWWWWWWWWW!!!!!!!!!!!!!!!
Posted: Sat Mar 10, 2012 09:11 PM
Cant wait to see that bad boy running with a 1600. Gonna be a lot of fun offroad.
Hope the KYB GR-2 shocks work for you up front.
Posted: Sun Mar 11, 2012 07:52 PM
There were a few set backs, but I hope it will be back on yhe road today. I picked up some KYB shocks for the front as my last outing blew the front shocks and ripped the ball joint boots. I'll need to do something aboit those later.
I have been contemplating how to seal the engine since I have a 3" body lift. I saw Earthquake cut his metal seal groove off and welded on a 3" extension. I wonder if I could find 3" of rubber and somehow affix it to the factory style seal? Maybe a roll of 3" flexible fender flare that I attach to the tin, upwards and run the engine seal from the body to meet it? I like this idea but wonder how they would withstand heat from the engine compartment. www.jcwhitney.com/rubb...ilterid=j1
Another thought I have is forgoing the seal and looking for another method of preventing heat from building in my engine. Perhaps keeping the decklid off? Using decklid standoffs? Modifying my stock decklid so that much of the sheet metal is replaced with expanded metal like my running boards?
Posted: Tue Mar 13, 2012 03:47 PM
She's alive! Smooth and 50% more power than the little 1385. What a difference in power. Imagine addind 15-20 hp on your engine. Thats what I did by switching engines. The Tri Mill muffler has a deep, throaty sound.
Posted: Tue Mar 13, 2012 07:40 PM
Congrats on getting her back on the road! now put a turbo on it and enjoy the power gains even more Very Happy
Staff Officers
Posted: Sun Mar 18, 2012 09:24 AM
Do not make a monster out of him. Mr. Hopper
Posted: Sun Mar 18, 2012 07:15 PM
I had the chance to drive this car yesterday. Way more power and with the gearing it can cruise down the hwy without a wimper. Really fun to drive.
Posted: Tue Mar 20, 2012 04:54 AM
I used the inner liner to a fire hose and attached it with nut and bolt to the engine seal to fill in the gap made by the 3" body lift. I then attached the fire hose to the tin with nut and bolt as well. This should allow me to change spark plugs without interference.
I need to do the same to the seal at the firewall. I may also use an adhesive in between the bolts holding the 2 rubbers together to help prevent hot air from bypassing.
Posted: Tue Mar 20, 2012 08:09 AM
Good job!
Posted: Tue Mar 20, 2012 03:20 PM
Looking good
25 Kreed 34098 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 6983 New Class 11 Build - P...
60 wideopenmotorsports 57366 CLASS 5 Resurrection!
 Mon Feb 22, 2016 06:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 4471 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
No new posts Projects and Builds Class 11 PepeAzul 3 pepeazul 6735 Class 11 PepeAzul
 Fri Jul 17, 2015 02:29 PM
