Latest: jamlip
Overall: 3581
Visitors: 239
Total: 239
30: My Account
35: My Account
58: Pictures
68: Pictures
100: Pictures
103: Event Calendar
104: Pictures
123: Event Calendar
133: Event Calendar
136: Event Calendar
150: Baja Forums
155: My Account
157: Baja Forums
158: Baja Forums
162: Baja Forums
166: Baja Forums
170: Baja Forums
171: Baja Forums
176: Baja Forums
178: Baja Forums
181: Baja Forums
183: Baja Forums
191: Baja Forums
197: Baja Forums
198: My Account
202: AMAZON.com
203: Pictures
204: AMAZON.com
205: Event Calendar
206: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
212: AMAZON.com
213: Baja Forums
214: AMAZON.com
216: Baja Forums
218: Baja Forums
219: Baja Forums
220: AMAZON.com
221: AMAZON.com
222: Baja Forums
225: AMAZON.com
226: Baja Forums
227: Baja Forums
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
232: Baja Forums
233: Baja Forums
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- reductiong gear box ?
baja63
baja63
Post Post subject: reductiong gear box ?
Posted: Wed Mar 07, 2012 06:13 PM
I need to find gears for my reduction box for more speed. my stub axle is a 25 tooth small nut 55 to 63. where can I find new gears for better speed. and oh yea its in a 63 bug baja
thanks for any help
baja63
Posted: Thu Mar 08, 2012 08:30 AM
IIRC - that's it. There were so-called "Alpine Gears" for the bus, but I believe that was a different ring and pinion ratio. NOT reduction gears. You could change the ring and pinion to change the final drive ratio. One of the reasons to install a reduction box setup is the lower gears for lower offroad speed. You can keep your cake or you can eat it. Can't have both. You could also take the reduction box setup out of the car and switch to a conventional swingaxle.
Post Post subject: Re: reductiong gear box ?
Posted: Thu Mar 08, 2012 03:45 PM
There are a few different gears, but VERY hard to find. I have a RGB setup in my baja, and it tops out at 55 MPH with 33" tires on it. Best bet is to do what mojaveracer said and change the ring and pinion and possibly a higher 4 gear. Contact Dons Bus Box www.donsbusbox.com and he can tell you what it would run.
Posted: Thu Mar 08, 2012 06:46 PM
Welcome to AZ Bajas from the Mojave Desert.
I have a Baja Bug friend in Ridgecrest and I'm not too far away...south of Edwards AFB. And I know another Baja guy who lives in North Edwards who goes by the user ID of 63Baja on SoCal Bajas and HiDesert Bajas. His 63 doesn't have reduction boxes though and is IRS. Since you're in SoCal, I suggest Jeff Fields Transaxle Engineering in the San Fernando Valley.
I'll send you a PM.
baja63
baja63
Posted: Thu Mar 08, 2012 10:24 PM
thanks every one. I dont want to do 80 mpg just like to do a little faster then 45 top speed. I like the reduction box. I have 25 tooth stubs on mine and I have found a set of 21 tooth stubs and matching 15 tooth axle gear but I need one more axle gear. thanks for any help I get.
baja63
ps Ive tryed to join socalbaja but dont know how or were to sign up at ?
Posted: Fri Mar 09, 2012 09:59 PM
Check with Bob Kinnan who has a part-time VW shop in Ridgecrest. I'm not comfortable handing out someone else's personal contact info, so if you PM your info to me, I can forward it to Bob. He's a SoCal member who will host a run out of his shop in about a month.
SoCal Bajas: from the text box near the header on the home page of the Forum...
"If you are interested in becoming an official member, or just have questions, feel free to send a Private Message from this board to 57baja for details on how to get involved. "
1st step is to join yuku.
If you still have trouble, PM through this site.
baja63
baja63
Posted: Tue Mar 13, 2012 07:50 AM
I have meet bob and have goten some stuff from him. as soon as i can get ahold of him again I will talk to him som more about the reduction box
thank for your help Cool
No new posts VW Volkswagen & Baja Bug General Discussion Need wheels to fit my baja gear reduction boxes
wheels
6 dustinddm 4843 Re: Need wheels to fit...
 Sat Nov 07, 2009 07:14 AM
dustinddm View latest post
No new posts VW Volkswagen & Baja Bug General Discussion gear ratio's 3 1FASTHOE 2112 Re: gear ratio's
 Thu May 17, 2007 09:24 PM
Billy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Top Gear - Bugatti Veyron Speed Test 2 vwbill 2403 Re: Top Gear - Bugatti...
 Fri Feb 09, 2007 11:24 PM
1FASTHOE View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Pre Order Your AzBaja T-Shirts and Gear 7 AzBaja 3246 Re: Pre Order Your AzB...
 Thu Oct 12, 2006 06:47 AM
Arizonateacher View latest post
