Visitors: 132
Total: 132
29: Home
46: Pictures
103: Event Calendar
104: Event Calendar
111: Event Calendar
1 2 3 ... 77 78 79 ... 103 104 105
MuddyPruett69
MuddyPruett69
Posted: Sat Feb 25, 2012 07:26 PM
walked out back, saw it sitting and rotting away......died a little inside
I wana sell stuff!!
Posted: Sun Mar 04, 2012 03:17 AM
FINALLY finished the stinger exhaust today. Cool Rolling Eyes Also installed new ceramic coated heat exchangers and lower tins (sleds).
Boys she sure sounds damn good!
TINMAN
TINMAN
Posted: Sun Mar 04, 2012 11:26 PM
Built a engine dolly for those days im woking solo
TRUMP 2020
Pointvirus
Pointvirus
Posted: Mon Mar 05, 2012 12:19 AM
I'm sanding the rear part of the interior today. It's looking bad..
Posted: Mon Mar 12, 2012 09:20 AM
Put on the water pump this weekend and radiator will go back in next week.
Posted: Sat Mar 17, 2012 09:11 PM
I hooked up the fresh air hoses, the heater and mounted the front KYB shocks- filled up $3.89 a gallon and will drive it like I stole it! I love this new engine!!!!
Posted: Sat Mar 17, 2012 10:17 PM
Had the old rear tires removed from the rims, so we can clean them up and paint them before the new generals get here Tuesday.
Posted: Sun Mar 18, 2012 01:34 AM
Still wiring, wiring, and wiring. I can just about see the end of it. I have all the front lights, gage lights and indicator lights wired. Had a problem with the turn signals not working but that turned out to be a defective 4 to 3 wire adapter. Toke it back to the Napa store and even after having it for 6 months they traded it for a good one.
Posted: Sun Mar 18, 2012 01:35 AM
Installed new angled/polished oil filler neck and cap since I lost the old cap (don't ask) last week put'n around town. Me likey.. Cool Also set the timing correctly and re-synced the Kad's. No more ping after she warms up. Even on 86 octane. So far.... Wink
Adjusted rear brakes a bit tighter this time. No more pumping the brakes. Cool
Tried out my plastic welder and welded up the crack on the fresh air box. Worked pretty good for my first time welding plastic. I still RTV'd the inside just in case. Now gotta cut a hole in the hood for it. Not looking forward to that. Crying or Very sad Rolling Eyes
Posted: Sun Mar 18, 2012 06:20 PM
Changed the oil and adjusted valves. I'm fabricating an engine seal extension using a firehose. I have a 3" gap because of the body lift. I figure the firehose should withstand the engine compartment temps, and be flexible enough to allow some room to change the spark plugs.
Pointvirus
Pointvirus
Posted: Fri Mar 23, 2012 03:06 AM
Found out that my trans is bad and I need a different one ):
and can't pull the pulley off of the generator to replace generators ):
Posted: Fri Mar 23, 2012 06:26 AM
Worked on my "Through the Tube" Bosses.
And cant wait to gun them.
Ran a touch heavier tubing for Ebrake cables and looked into a different handle position since i have alittle extra length. Hmmm
Its damn hard to build when you jones to roll it. lol
What can one DO......
Posted: Sat Mar 24, 2012 12:31 AM
I bought a new 30/31 carb from a local guy and installed it. I also advanced my timing and installed the firehose rubber seal near the firewall.
Posted: Sun Mar 25, 2012 01:56 AM
Finished repairing the fresh air box. Used stainless bolts/nuts to mate the top half back on in case I need to get back in there.
Also got it installed but no hole in the hood yet. Looks like I need to build up (actually down) the surface of the hood underneath to mate with the seal.
Posted: Mon Apr 02, 2012 12:15 AM
I installed decklod standoffs and stiffened my front beam's adjustors. Nasty little thoughts of posting it for sale are dancing in my head...
5 Admin_AzBaja 6789 Baja Bugs on Wiki need...
285 MusicManiac 241452 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 22 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1287 Re: Had to go play in ...
