Visitors: 149
Total: 149
15: Event Calendar
40: Event Calendar
49: Pictures
51: Event Calendar
54: Event Calendar
72: Event Calendar
83: Pictures
84: Pictures
115: Event Calendar
136: Event Calendar
147: My Account
1 2 3 ... 76 77 78 ... 103 104 105
Posted: Wed Feb 15, 2012 05:28 AM
Started building Biblethumpens motor, short block is together and pistons & cylinders are on.
Posted: Wed Feb 15, 2012 08:05 PM
1600 or are you going to bump it a few ccs?
Posted: Wed Feb 15, 2012 10:45 PM
Stock single port 1600, new bearings, crank polished, new rods, new rings, cylinders howned out with cross hatch pattern, rebuilt heads including new valve guides, seats and valves. High flow oil pump. Just going to build a nice stock motor for now.
DutchBug
DutchBug
Posted: Thu Feb 16, 2012 06:57 PM
Today I walked passed it...
Haven't been working on it for over a year. No money, no time.
I hope to move the body (it is already lifted from the bottom) this month and start to clean up some stuff.
Posted: Thu Feb 16, 2012 09:16 PM
I have a few will work for VW parts franchises still available. Smile
Posted: Sat Feb 18, 2012 03:49 AM
Worked on the Bugpack stinger exhaust last Sunday. Had to weld it together which sucked. I'm so out of practice welding. Took nearly the whole afternoon and still grinding/welding. No! No! No! No!!!!
I did get my High Lift jack and accessories this week. Woo-hoo! Cool
Posted: Sun Feb 19, 2012 03:52 AM
I degreased the tin and doghouse shroud and painted everything tonight. I'll drop the bug and painted tins off at Dirtjunkie's house tomorrow.
Posted: Sun Feb 19, 2012 04:08 AM
Replaced a generator that was going out, replaced a bent crank pulley, and put another exhaust on.
Posted: Sun Feb 19, 2012 04:46 AM
Just changed a broken clutch cable in Ted's Hot Dogs parking lot.
Posted: Mon Feb 20, 2012 07:12 AM
I returned an EMPI exhaust and just ordereda Tri-Mil Euro 2 tip exhaust and some rocker shaft shims.
Posted: Tue Feb 21, 2012 03:28 PM
Dirtjunkie's been busy. Its getting closer...
Posted: Wed Feb 22, 2012 11:21 AM
The las feww weeks I have been playing with Krylon Blue Spray Paint. Have been redoing the wiring in the Baja. Solder ends etc.
Kreed
Kreed
Posted: Wed Feb 22, 2012 04:49 PM
Discovered a brake line leak somewhere in the tunnel going to the rear wheels. Hitting the brakes and nothing... that is exciting!! Why couldn't the break be somewhere easy to see and fix.
Posted: Sat Feb 25, 2012 07:29 AM
Got the rail back on 4 wheels for the first time in a year.
Posted: Sat Feb 25, 2012 07:52 AM
I dropped off the last parts needed for Dirtjunkie to complete my engine this weekend. I'm excited. It looked clean and classy!
4 Admin_AzBaja 6177 Baja Bugs on Wiki need...
285 MusicManiac 229622 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 393 Re: Had to go play in ...
0 Northmountainauto 988 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2876 Baja hiding in Chandle...
