Latest: strike77
Overall: 3575
Visitors: 95
Total: 95
09: Home
16: Event Calendar
30: Pictures
31: Event Calendar
47: Event Calendar
59: Event Calendar
65: Event Calendar
Psuedo Class 11
1 2 3 ... 10 11 12 13 14
Posted: Wed Feb 08, 2012 05:29 AM
Excellent purchase. That will get the little class 11 moving.
Posted: Wed Feb 08, 2012 06:14 AM
Just picked up a CLEAN 1600cc assembled shortblock that had new connecting rods and bearings, polished stock crank and align bored .020. It also came with rebuilt SP heads, and lots of parts... 2 new clutches, 2 pressure plates, 3 009 distributors (1 was a Bosch with Petronix), old 019 distributor, 3 DP heads w/o valves, Engel 110 cam not installed, resurfaced flywheel in celophane still, accordian heater tubes, 3 pulleys, SP intake, new front and rear tin, gen stand, voltage reg, new throttle and clutch cables, several sets of seatbelts, new starter, 2 oil pumps, 2 different stykes of pushrod tubes (adj and non-adj), various new seals and gaskets, external oil cooler and filter setup. All heads and case were beadblasted and super clean. Spent just over $500. The case is a dual relief and I forgot it came with 3 coils. I will need to get a carb, exhaust, heater boxes and doghouse cooler tin and cooler, plus a few tin pieces and the alternator. I think I will go with the SP heads since they are sooooo pretty, and I have the manifold. I will trade or sell off parts to get parts and keep in my budget. Dirtjunkie is building it for me and I'll rely on his opinion for alot of it. I may have the Engle 110 installed if that makes sense. He'll split the case and give me an honest opinion on things. I'm pretty stoked!
Posted: Wed Feb 08, 2012 06:39 AM
If you go with the engle 110, advance the camshaft a couple of degrees to get the power down to the bottom of the RPM range. 110 cams dont like to run well at less than 1800 to 2000 RPM unless the cam timing is adnanced.
Posted: Fri Feb 10, 2012 05:39 AM
That is some good-looking stuff. Are you planning on running straight cut cam gears? That and a cam upgrade will get that class 11 moving really well.
Posted: Fri Feb 10, 2012 10:40 AM
Nice!!! Geat step up.
Plush Score.
Wouldnt mind building up those DP heads right with new stems and such...and a FRESH CUT.
Zylas point is right with me for that lower offroad end.
I love my stock and w100 all the way around....Porsche designed it right!!!!
Build it tight with Dual releif and a mellow cam.....counterweighted be nice but not necessary....get and post the thrust on the rear main after you split that case.
Those DP head might just be your ticket with a DELL.
Just saying...dont want to control just help out.
oooowwww and if you do up the DP head step up the stems you'll be glad and proud you did in times of high REV.
What can one DO......
Posted: Sat Feb 18, 2012 11:11 PM
Copernicus wrote:
have you got the headliner in yet? If so, I would love to see it. I shared a picture of your bug on my local vw forum because we were talking about bed liner, and one of the guys is now building a class 11 Laughing truly inspiring.
I also picked up the remaining pieces needed today. I'll clean the tin and shroud, then paint them. I went with a 30pict1 carb, 019, stock cam, polished stock crank, new bearings, mexican stock style header / 2 tip muffler, new alternator, 85.5mm cylinders honed with cross hatched pattern, new rings, new connecting rods, rebuilt single port heads including new valve guides, seats and valves. High flow oil pump. I hope all goes well.
Posted: Sun Feb 19, 2012 03:53 AM
I degreased the tin and doghouse shroud and painted everything tonight. I'll drop the bug and painted tins off at Dirtjunkie's house tomorrow.
Posted: Mon Feb 20, 2012 07:13 AM
I returned an EMPI exhaust and just ordereda Tri-Mil Euro 2 tip exhaust and some rocker shaft shims.
Posted: Tue Feb 21, 2012 06:59 AM
Its getting closer...
gman3850
Colonel
Colonel
gman3850
Posted: Tue Feb 21, 2012 07:33 AM
drool haha
Posted: Tue Feb 21, 2012 04:57 PM
Look all the pieces are fitting together to make a motor
That should make it move better Razz
TINMAN
TINMAN
Posted: Tue Feb 21, 2012 06:57 PM
I have the same Tri Mill exhaust on my 66 bug it should work great on your car it,s short and tucked up there like a stock pea shooter, they sound nice too.
TRUMP 2020
Posted: Wed Feb 29, 2012 12:07 AM
If all goes well I should have the motor completed today, and in the car.
Posted: Wed Feb 29, 2012 01:08 AM
Good thing you went with the stock cam even advanced I you were not going to like a W 110 cam in a 1600. If you check Baja57's stock 1600 dyno post you'll see where 1.4 rockers on the stock cam gives a big boost in torque.
Posted: Wed Feb 29, 2012 06:07 AM
Looking good Eric!
25 Kreed 23483 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 4498 New Class 11 Build - P...
60 wideopenmotorsports 43102 CLASS 5 Resurrection!
 Mon Feb 22, 2016 06:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 2968 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
No new posts Projects and Builds Class 11 PepeAzul 3 pepeazul 5057 Class 11 PepeAzul
 Fri Jul 17, 2015 02:29 PM
