Visitors: 139
Total: 139
02: Home
25: Pictures
27: Event Calendar
35: Pictures
64: Home
103: Home
129: Event Calendar
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- 73 baja squareback
73 baja squareback
73square
73square
Post Post subject: 73 baja squareback
Posted: Sun Feb 19, 2012 09:17 PM
been wanting to build one of these for a while -followed a few build strings on-line for guidance and the previous owner had another project to start and made me a great offer- I knew I would need to upgrade some things to make it more off-road worthy. But nothing too rad; its to be a trail cruzer - a VW Family Truckster- The first trip out at Needle Rock, AZ
That's done - Next!
73square
73square
Posted: Sun Feb 19, 2012 10:13 PM
The previous owner did a lot to clean it up. repaint, new window door and body seals. I've cleaned up some wiring, lights, horn, wipers, stereo, etc... What I know about it- was built by a now-closed shop in Seattle area. Cut & boxed wheel wells, disc brakes all around, supposed to be a bus transaxel, dont know gearing. Has a 1776 engine, lightned & balanced flywheel, paper work with it says a V2-15 279X478 cam and dual Empi carbs. 31X10.50 tire all around.
[IMG]
That's done - Next!
73square
73square
Posted: Sun Feb 19, 2012 10:17 PM
Been working on getting thorugh emmissions - worked on it with a neighbor, running better, but he does not think it will make it. I'll have someone else take a look and need to upgrade the tie rods; bent one out at Hassyampa. more on plans later.
That's done - Next!
Posted: Mon Feb 20, 2012 03:55 AM
Steve at Performance VW got my bug to pass emissions.
Post Post subject: Re: 73 baja squareback
Posted: Wed Feb 22, 2012 03:45 AM
Your valves have to be adjusted, timing and dwell set properly and co set at idle and cruise to pass. With vehicles that have large tires and stock gearing I install stock size tires so the enine rpms match what rpms vs mph VW planned on for emissions testing. Also VW went to EFI because most of the time because of the short intakes with dual carbs on a T-3 cylinders #1 and 3 don't work well at idle making the HC high on those two cylinders.
Posted: Wed Feb 22, 2012 10:34 AM
Nice little car.
73square
73square
Posted: Thu Feb 23, 2012 04:16 AM
Thanks for the feed-back. Yeah thats exactly what it looks like: two cylinders are not firing properly @ idle but do so @ higher RPM. -I'll try working on it more here, but I can see who knows way more about this than I...
That's done - Next!
73square
73square
Posted: Thu Feb 23, 2012 06:14 AM
Assuming that I can get it passed emissions... (hope) and looking to the tie rod problem. What would you reccomend reinforcing the existing (if I cn get it straight) or getting a set of new up-grades? Looks like $70 - 80 bucks a pop I can land after-marked t-rods... whats the best route?
That's done - Next!
Posted: Thu Feb 23, 2012 03:43 PM
Just sleeve the tie rods with 1 inch .120 wall tubing. Its an inexpensive and strong fix.
Posted: Thu Feb 23, 2012 05:00 PM
X 2 tubing is a few bucks a foot.
Then there is always swapping a stock beetle engine in for emissions.
73square
73square
Posted: Fri Feb 24, 2012 03:34 AM
Thanks for the tip on the tie rod - swap out a bug engine- Brillinat!! had not thought of that.. I had thought about registering it at my parents house in Yavapai County... not that I condone thwarting the law... Rolling Eyes
That's done - Next!
73square
73square
Posted: Fri Feb 24, 2012 03:43 AM
Wow - lots going on this weekend-! bummed I'm tied up with my Wife's Birthday and tonight finishing up the race car- final paint, setting tire track, check in, and race tomorrow... OK it's a Cub Scout pinewood derby car- but still- in the mind of an 8-year old a big deal... vroom-vroom! Cool
That's done - Next!
Posted: Fri Feb 24, 2012 04:11 AM
My Pinewood Derby days are still a high point over 40 years later. I still have the car less the wheels.
Posted: Fri Feb 24, 2012 11:07 PM
Still have my Pinewood cars. I know I have 3 of them and still might have the 4th and 5th car. 2 cars that I might not have are not the best looking blocks of pine in the world, More than likly lost too time or the trashcan.
73square
73square
Posted: Sun Feb 26, 2012 12:00 AM
Both of my boys finished just outside of the top 3 in each of their dens and both had best times well within the top 10 of the pack -so are happy with a couple wins even though they didn't get top place. I made the mistake of showing them some of my old cars and the 1st place trophy I won one year, and they have been after me ever since to get them 1st place-!
That's done - Next!
5 Admin_AzBaja 6768 Baja Bugs on Wiki need...
1568 mufasavnvmc 998631 Re: what did you do to...
285 MusicManiac 241179 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 5 FREE VW BAJA'S
0 Northmountainauto 1519 Shop Baja
