Visitors: 110
Total: 110
07: Event Calendar
27: Event Calendar
37: Event Calendar
59: Event Calendar
63: Pictures
79: Event Calendar
108: Event Calendar
109: Event Calendar
FABINC 5-1600 Build
1 2 3 4 5 6 7 8 9
Posted: Sun Feb 12, 2012 05:07 AM
Pm sent
Posted: Mon Feb 13, 2012 02:21 AM
Car is up and running, but with a note. Big oil leak and motor noise prompted Dirtjunkie to stop by. After a little run time we determined #3 cylinder had a rod knock.
With that said it is time for a rebuild. Project will be on hold for a short time.
I was soooooo close to being done. Updates when available.
Posted: Sun Apr 15, 2012 02:15 AM
Project is back on track. Have new 1600dp with 8:5 to 1 compression, full flowed etc . . . ready to put in.
I did upgrade to the doghouse cooler so I am in the process of modifying and painting the new shroud before assembly.
Posted: Sun Apr 15, 2012 05:13 AM
Looking good!
Posted: Sun Apr 29, 2012 06:41 AM
New engine is in, but missing the fittings for the full flow system. Hopefully it will ready for testing next weekend.
Posted: Sun Apr 29, 2012 06:52 AM
Excellent! Hopefully it will be ready for Friday!
Posted: Mon May 14, 2012 06:16 AM
I think this car is possessed! Everything together and ready to go and not the engine will not turn. Something not right when I put it in. Will have to pull it out and see what the problem is.
It is a Charlie Brown day!
Posted: Mon May 14, 2012 05:10 PM
Let me know if you need any help.
Posted: Mon May 14, 2012 09:06 PM
Greatly appreciated.
Posted: Tue May 15, 2012 05:35 AM
Progress made. Oil pump bolts were too long. When I tightened down the aluminum crank pulley it locked the engine. A little filing and it spun freely. Finally! Tomorrow it is game on!
Posted: Sun May 20, 2012 12:56 AM
A friend got the chance at grabbing all the used aluminum signage that was going to be discarded and passed along a few for me to use in fabrication.
Needed a footrest for the passenger side of the car and this was the perfect ticket.
Old sign before and after.
A little drilling and bending and I had a footrest.
Drill a few holes and install. I think it will work nicely.
Seats are going in tonight!
Posted: Sun Jun 17, 2012 06:01 PM
After having a fellow VW enthusiast look at my car, he noticed my rear brake lines were too high. So this weekend I re-bent all the brake line for the rear trailing arms. Engine should go in this week.
Posted: Sat Jun 30, 2012 04:56 PM
Got new motor back and installed this morning. Started up on the first try. I will need to do a few other little things before the rear cage goes on and final assembly begins.
I will keep the updates coming as I progress. Thanks to everyone who helped get the car this far along.
Just waiting for they new rear limiting straps an it is off to the desert to do some testing.
BearpawAZ
BearpawAZ
Posted: Sat Jun 30, 2012 05:47 PM
Awesome.... Looking good
64vwbug
64vwbug
Posted: Sat Jun 30, 2012 06:34 PM
Looks good.
1 2 3 4 5 6 7 8 9
26 1963BAJA 7360 The Socal Honda Build
 Fri Jun 23, 2017 12:15 AM
1963BAJA View latest post
Cheapskate special
26 Azdrtdog 11421 New father/son budget ...
 Fri Jun 16, 2017 10:26 PM
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5236 New Class 11 Build - P...
101 SuburbanLegend 134655 Carbon Footprint...aka...
 Thu Oct 08, 2015 08:28 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 3380 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
