Author |
Message |
The following users give thanks for this topic |
texasmetal - Wed Mar 03, 2010 07:27 AM, perrib - Mon Apr 19, 2010 04:37 AM |
+5
Post subject: what did you do to your buggy/baja today?
Posted: Mon Feb 06, 2012 05:58 AM
I blew both front shocks on the Hassayampa run and then sold my engine.
_________________ If you blame others when you fail, give them credit when you succeed!
bajacrazy
Posted: Mon Feb 06, 2012 10:36 AM
dude thats shitty haha im in the middle of puting my motor back together fml long storry but funny y did u sell ur engine though
+2
Posted: Mon Feb 06, 2012 08:25 PM
So the little 1300 would not do it out on the trail?
gman3850
Colonel
Post subject: Re: what did you do to your buggy/baja today?
Posted: Tue Feb 07, 2012 12:53 AM
PaDan wrote: |
So the little 1300 would not do it out on the trail? |
it made it threw but slowly, soft aresa in first gear doing like 1mile an hour pedal to the flooor, haha
+2
Posted: Tue Feb 07, 2012 01:05 AM
But the go thing is you made it home under its own power
+5
Posted: Tue Feb 07, 2012 01:15 AM
Yep!
+9
bajacrazy
Posted: Tue Feb 07, 2012 08:51 AM
sweetness just found brand new dual port heads in and on a junk yard motor cant wait to get it back together so i can drive it again i miss driving my baja still open to any pointers you guys have about anythig baja just hit me up with some messages
69baja69
Post subject: what did you do to your buggy/baja/Thing/Sandrail today?
Posted: Thu Feb 09, 2012 07:25 PM
NEW GAUGES, aluminum dash, adjusted my brakes and shifter, modified a super beetle gas tank to fit, welded up front shock towers, custom mounted my steering collumn.
+3
Post subject: Re: what did you do to your buggy/baja/Thing/Sandrail today?
Posted: Fri Feb 10, 2012 10:45 AM
69
you looked to be a busy man.
wish that i could say the same.
all i did was draw up some plans.
_________________ What can one DO......
+13
Posted: Sun Feb 12, 2012 04:33 AM
Changed the oil & filter, replaced the oil lines, adjusted the valves, cleaned the carb, and replaced a broken generator pulley. Also split the case for biblethumpens new motor good thing too, too much silicone used when putting it together, even had silicone blocking an oil hole in the main bearing.
Oh and painted the trans for the rail.
_________________ Current AZBaja"El Presidente"
Mannyr7
Posted: Mon Feb 13, 2012 12:22 AM
+35
Mannyr7
Posted: Mon Feb 13, 2012 05:01 AM
Thanks Daryll! That wiring diagram looks a little easier to follow than the one supplied in the EMPI Universal Harness I bought, PN:9466. I did swap out the supplied fuse box with the EMPI Weather-Proof GM style Fuse Box PN:9470. It uses the modern fuses and gives me 4 more circuits for accesories.
+51
Posted: Tue Feb 14, 2012 12:23 AM
Not today but Sunday we ran the Log Corral Trail to power line trail from Bartlett to the old SR 87. Had to winch up one spot on a waterfall due to being hi centered one time and ran the last four miles with a totally collapsed and locked left front suspension. 22 miles with an average speed of 19.6 mph. No video or pictures of us but here is a link with Jeeps.
www.youtube.com/watch?v=_ZTYEISMYkY
With Zuks
www.youtube.com/watch?v=0T3FKexVA2c
When I got out of the trail I had to pull the drivers turkey legs and remove the pieces of broken torsion leaves that had locked the lower arm. I'm thinking this would be a good trail to rent AzBajas Go Pro and video tape it.
