Visitors: 118
Total: 118
37: Home
47: Event Calendar
68: Pictures
80: My Account
85: Event Calendar
96: Event Calendar
99: Event Calendar
111: My Account
112: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- tubing notcher recommendations
chrispy56
chrispy56
Post Post subject: tubing notcher recommendations
Posted: Fri Feb 10, 2012 02:48 AM
I am looking to purchase a tubing notcher, and I am looking for suggestions. I dont want the harbor freight one and I dont want to spend $500. Does anyone know of a decent notcher in the $100-$200 range? I plan on using it mainly on 1.5" and 2.0" tubing. Thanks.
Post Post subject: Re: tubing notcher recommendations
Posted: Fri Feb 10, 2012 02:53 AM
Mine came from Williams Low Buck Tools. most of the time I end up using a chop saw and die grinder.
chrispy56
chrispy56
Posted: Fri Feb 10, 2012 03:49 AM
are you happy with it?
T_Town_Baja
T_Town_Baja
Posted: Fri Feb 10, 2012 05:59 AM
I had a lowbuck notcher and a harbor freight notcher. Both worked fine, the hole saw was the key to it. The HF notcher is very soft metal though (i used in a drillpress, mounted to the base). Both worked ok, but in the end I stopped using them. Like perrib said, I now just use the chopsaw and anglegrinder/bench grinder.
I have one of those tools that slides over the tube, has fingers that you push in to mock what the notch needs to be. I just trace that onto the tube and throw it into the chopsaw - much faster when doing a full cage.
Just my 2c
T_Town_Baja
T_Town_Baja
Posted: Fri Feb 10, 2012 06:08 AM
Also, this has come in handy as well:
metalgeek.com/static/cope.pcgi
Just enter your info, the angle of intersection, print, wrap cut, done...
Essentially, I use these:
vansantent.com/pipemas...ndividuals
Pretty much does what that printout does on the fly
Posted: Fri Feb 10, 2012 08:08 AM
I tried the harnor freight notchers, and they wear out pretty fast. I bought the williams notcher about 4 years ago, and its still going strong. Worth the money, and works in seconds.
TINMAN
TINMAN
Posted: Sat Feb 11, 2012 12:58 AM
I use a JD2 tn 100 its pretty stout made in the US and about $200
TRUMP 2020
Posted: Sat Feb 11, 2012 01:02 AM
Mine is 20 years old
Posted: Sat Feb 11, 2012 08:37 AM
Jig and hole saw.
I love to sculpt with the suicide wheel on the die.
Its a personal problem of mine.
What can one DO......
chrispy56
chrispy56
Posted: Sat Feb 11, 2012 05:37 PM
After a little research, I think I have decided to get the tn-100. They make a nice bender too that I might have to get also!
Posted: Thu Feb 16, 2012 07:51 AM
Enjoy the ART
Prayinmantis
Prayinmantis
Posted: Sat Mar 24, 2012 08:34 PM
I use the one from harbour freight. Is great if u use a drill press. With a reg drill the bits get torn up
ghettodish
ghettodish
Posted: Sun Mar 25, 2012 06:28 AM
Just my 2c
Who makes that tool? Where can I get one? Got a photo of it? -Thanks
brokenparts
brokenparts
Posted: Tue Apr 03, 2012 06:31 PM
I used a jd2 notchmaster which was pretty good. I used some ugrades from a company called swag offroad which helped out but in the end I sold it and bought this:
Really really really nice and it has the ability to notch on bends because of the way it clamps onto the tube.
No new posts VW Volkswagen & Baja Bug General Discussion tuning recommendations help! 10 Neander 4462 tuning recommendations...
 Thu Oct 29, 2009 09:08 PM
Neander View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Tubing Bender Information 2 catchbats 1986 Re: Tubing Bender Info...
 Mon May 25, 2009 12:14 AM
catchbats View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Welding Tip For Complex Tubing Angles 5 57baja 3109 Re: Welding Tip For Co...
 Tue Jul 08, 2008 08:22 AM
No new posts VW Volkswagen & Baja Bug General Discussion New Tubing Bender
17 57baja 9161 Re: New Tubing Bender
 Wed Mar 26, 2008 02:21 AM
kcnaz View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Roll Cage Tubing Caps 5 57baja 2989 Re: Roll Cage Tubing C...
 Sat Feb 02, 2008 04:31 PM
MOCRAWLER417 View latest post
