Latest: thelataviayoung
Overall: 3584
Visitors: 117
Total: 117
16: My Account
23: Home
31: Event Calendar
45: Home
66: Home
67: Event Calendar
93: My Account
95: Event Calendar
Psuedo Class 11
1 2 3 ... 9 10 11 12 13 14
Posted: Sun Jan 29, 2012 07:20 AM
Ive never been a big pict fan.....but then again ive always run 1600 or larger and always thrown on 40 Dells.
There will be a pict person come around....as for being not vented....im thinking thats not the issue unless the cap is SUPER SEALed.
What can one DO......
Posted: Tue Jan 31, 2012 12:21 AM
biblethumpncop wrote:
... My tank doesn't have a vent, ... I'm curious where to start?
Thanks,
John
The filler neck should have a vent. There should be a small (1/4") tube in the top right rear corner of the tank next to the filler neck. I really don't know any reason for installing an alternator to affect it as you describe.
Posted: Wed Feb 01, 2012 05:22 AM
Thanks,
John
I have the vent as you described. A new question...
I am looking for a moderate increase in power from my 1385. This led me to these questions... HELP
1. What type of performance increase will I see if I put dual carbs on it?
2. Will my upgrade be similar to running a stock, single carb 1500 or 1600?
3. Since my p&c are 83mm, can I bolt on a set of 1500 heads as its my understanding they are 83mm compared to stock 1300 which are 77mm? Then mount dual carbs?
4. Buy another 40hp manifold had have them customized for dual carbs.
5. Sell the engine and buy an unknown used 1500 or 1600 based on my budget?
Thanks in advance.
Posted: Wed Feb 01, 2012 09:17 PM
I say the easiest route is just selling the 1385 and upgrading to a 1600. Even if you buy a used one it can be freshened up for less than $1000 and there are so many more things you can do and a lot more bolt on goodies for a larger motor.
Posted: Thu Feb 02, 2012 02:28 PM
Earthquake is sending me a 40hp manifold that is chopped up. I will use it and mount dual carbs on my 1385. I hope to have it completed this month.
Posted: Mon Feb 06, 2012 05:03 AM
Well, I sold my engine today so I can go bigger. I have a lead on a 1600.
gman3850
Colonel
Colonel
gman3850
Posted: Mon Feb 06, 2012 05:08 AM
posing for a pict
couldnt make it up the hill so we had to walk up
washing it after the run
Posted: Tue Feb 07, 2012 02:48 AM
Glad to see you out there. You missed the ride back lots of scenery and nice solid forestry roads.
Posted: Tue Feb 07, 2012 03:28 AM
Those are some good lookin' tires!
Posted: Tue Feb 07, 2012 05:39 AM
The engine was pulled tonight and cash was exchanged for it-full price! Dirtjunkie and I are headed tomorrow to check on a 1600. I hope to learn how to build an engine by watching/helping Eric. He's good people.
Posted: Tue Feb 07, 2012 08:56 AM
What are we throwing in the psuedo besides the dimensions???? If your rebuilding......Any ideas to bump??
Carb???
Cam???
Rock???
Really curious???
Ya seemed so set on those CCs.
Posted: Tue Feb 07, 2012 02:27 PM
Budget dictates the build. It is primarily a street bug that ocasionally sees dirt. I need it to pass emissions and have decent gas mileage. I prefer dependability over anything else. I would like it to last 60,000 miles. Thats 10 years of driving for me in this rig.
Posted: Tue Feb 07, 2012 04:21 PM
Buy the Eagle (not engle) Cheater Cam. You wont regret it! Available from CB performance.
Posted: Tue Feb 07, 2012 05:16 PM
The CB cheater is a nice cam. Weber used to make a cheater cam noticable increase in power , smooth idle and passed emissions like a stock cam. While your at it build it to a 78x85.5 or a 1776, thick wall 1835. It will only add about $300 to the cost and will motivate that heavy class 11. You can keep the 34 pict carb.
Posted: Wed Feb 08, 2012 04:00 AM
I hit the jackpot tonight! Dirtjunkie helped me out by inspecting the engine I just bought. He'll chime in, but we were both astonished. Needless to say, I got lots of stuff. The pictures will be up shortly.
25 Kreed 25585 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts Projects and Builds New Class 11 Build - PepeBlanco 4 pepeazul 5056 New Class 11 Build - P...
60 wideopenmotorsports 46294 CLASS 5 Resurrection!
 Mon Feb 22, 2016 05:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion 5-1600 vs Class 11 Version 3 2 wideopenmotorsports 3264 5-1600 vs Class 11 Ver...
 Thu Oct 08, 2015 08:12 PM
No new posts Projects and Builds Class 11 PepeAzul 3 pepeazul 5418 Class 11 PepeAzul
 Fri Jul 17, 2015 02:29 PM
