Visitors: 187
Total: 187
01: My Account
03: My Account
38: Event Calendar
52: My Account
67: My Account
68: Pictures
85: My Account
111: My Account
112: My Account
121: Event Calendar
123: Pictures
125: Pictures
127: Pictures
162: Event Calendar
163: My Account
166: Baja Forums
168: Pictures
169: My Account
170: Pictures
172: Pictures
173: My Account
177: Event Calendar
179: Event Calendar
184: Baja Forums
185: Baja Forums
1 2 3 ... 75 76 77 ... 103 104 105
Posted: Mon Feb 06, 2012 04:58 AM
I blew both front shocks on the Hassayampa run and then sold my engine.
bajacrazy
bajacrazy
Posted: Mon Feb 06, 2012 09:36 AM
dude thats shitty haha im in the middle of puting my motor back together fml long storry but funny y did u sell ur engine though
Posted: Mon Feb 06, 2012 07:25 PM
So the little 1300 would not do it out on the trail?
gman3850
Colonel
Colonel
gman3850
Posted: Mon Feb 06, 2012 11:53 PM
it made it threw but slowly, soft aresa in first gear doing like 1mile an hour pedal to the flooor, haha
Posted: Tue Feb 07, 2012 12:05 AM
But the go thing is you made it home under its own power
Posted: Tue Feb 07, 2012 12:15 AM
Yep!
Posted: Tue Feb 07, 2012 02:11 AM
I got 2 flats in one day in the same tire...
That's a record for me!
Unfortunately, neither was acquired offroad...
bajacrazy
bajacrazy
Posted: Tue Feb 07, 2012 07:51 AM
sweetness just found brand new dual port heads in and on a junk yard motor cant wait to get it back together so i can drive it again i miss driving my baja still open to any pointers you guys have about anythig baja just hit me up with some messages
69baja69
69baja69
Posted: Thu Feb 09, 2012 06:25 PM
NEW GAUGES, aluminum dash, adjusted my brakes and shifter, modified a super beetle gas tank to fit, welded up front shock towers, custom mounted my steering collumn.
Posted: Fri Feb 10, 2012 09:45 AM
you looked to be a busy man.
wish that i could say the same.
all i did was draw up some plans.
What can one DO......
Posted: Sun Feb 12, 2012 03:33 AM
Changed the oil & filter, replaced the oil lines, adjusted the valves, cleaned the carb, and replaced a broken generator pulley. Also split the case for biblethumpens new motor good thing too, too much silicone used when putting it together, even had silicone blocking an oil hole in the main bearing.
Oh and painted the trans for the rail.
Mannyr7
Mannyr7
Posted: Sun Feb 12, 2012 11:22 PM
Installed the front, rear and passenger side quarter windows. Pulled a new wire harness. Now scratching my head how to wire it all up!
Posted: Mon Feb 13, 2012 03:33 AM
Manny, To make it simple use a 63 wiring diagram.
diagram vintagebus.com/wiring/bug-62-65.jpg
key vintagebus.com/wiring/...65-key.jpg
and use an aftermarket fuse box with ATO fuses.
Mannyr7
Mannyr7
Posted: Mon Feb 13, 2012 04:01 AM
Thanks Daryll! That wiring diagram looks a little easier to follow than the one supplied in the EMPI Universal Harness I bought, PN:9466. I did swap out the supplied fuse box with the EMPI Weather-Proof GM style Fuse Box PN:9470. It uses the modern fuses and gives me 4 more circuits for accesories.
Posted: Mon Feb 13, 2012 11:23 PM
Not today but Sunday we ran the Log Corral Trail to power line trail from Bartlett to the old SR 87. Had to winch up one spot on a waterfall due to being hi centered one time and ran the last four miles with a totally collapsed and locked left front suspension. 22 miles with an average speed of 19.6 mph. No video or pictures of us but here is a link with Jeeps.
www.youtube.com/watch?v=_ZTYEISMYkY
With Zuks
www.youtube.com/watch?v=0T3FKexVA2c
When I got out of the trail I had to pull the drivers turkey legs and remove the pieces of broken torsion leaves that had locked the lower arm. I'm thinking this would be a good trail to rent AzBajas Go Pro and video tape it.
5 Admin_AzBaja 6810 Baja Bugs on Wiki need...
285 MusicManiac 241596 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 35 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1304 Re: Had to go play in ...
