Visitors: 103
Total: 103
16: Event Calendar
24: Event Calendar
27: Event Calendar
28: Links
34: Contact Admin
48: Event Calendar
86: Event Calendar
101: Event Calendar
103: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wheel travel stock vs. 3x3
ghettodish
ghettodish
Post Post subject: Wheel travel stock vs. 3x3
Posted: Fri Jun 10, 2011 06:25 PM
Can someone help me out with this? How much wheel travel does a stock IRS suspension have? And how much travel can I get by adding 3x3 arms?
How much travel do stock Link Pin and Ball Joint front ends have?
Thanks!
Posted: Sun Jun 12, 2011 04:10 AM
Stock IRS provides around 6" of travel.
3x3 has the potential of nearly 20". That will get me a lot of argument, but if a 5-1600 Baja or 1-2/1600 buggy with +1 x +0 arms, micro stub hubs and 930 CVs can get 17" of travel, there's no excuse for someone with 3x3s and VW hubs and 930s not to be able to get a bit more. The micro stubs do not move the CV flange out 3" from stock, and the longer swing length should help too.
Stock ball joint front ends allow about 5-1/2" and link pin front ends allow about 6". Ball joints are limited to that unless the arms are lengthened, although I can't say I've ever seen longer ball joint arms. And link pins can push 15-17" with +4 arms.
ghettodish
ghettodish
Posted: Tue Jun 14, 2011 08:59 PM
Thanks for the help. Good info.
hucklebuck
hucklebuck
Post Post subject: Re: Wheel travel stock vs. 3x3
Posted: Fri Jan 27, 2012 06:29 PM
[quote="MojaveRacer208"]Stock IRS provides around 6" of travel.
Stock ball joint front ends allow about 5-1/2" and link pin front ends allow about 6". Ball joints are limited to that unless the arms are lengthened, although I can't say I've ever seen longer ball joint arms. And link pins can push 15-17" with +4 arms.[/quote
Are these specs taken from the wheel centerline or the shock mount location? I assume they are for positive stop compression to positive stop total droop.
-Denial and Error.
T_Town_Baja
T_Town_Baja
Posted: Fri Jan 27, 2012 10:37 PM
These are usually quoted pertaining to the wheel itself. Shock mount location will not give you accurate travel numbers, no two are mounted the same. Hence a 10" stroke shock on the front, with +4 arms can give you upwards of 17" of travel.
The shock mount location DOES impact your shock travel, spring rate and dampening.
Posted: Sun Jan 29, 2012 04:41 AM
If you go for 20" your going to spend a lot of time setting up the suspension as it won't be bolt on. The micro stubs reffered to move the Cvs apart. The wider you go the less severe the angle on the axle vs travel gained so you get more travel with the same with arms.
Posted: Tue Jan 31, 2012 02:57 AM
Yeah. The guys got it right.
"Wheel travel" is measured AT the wheel, and in relation to a fixed point on the car. Or if the car is sitting still on a level floor, then it can be measured form the floor.
On various offroad forums I run across all sorts of BS about weird ways to measure wheel travel. Guys get into measuring the arc of travel and all sorts of stuff.
Bottom line is how much the wheel moves up and down compared to the body/chassis of the vehicle.
1 suburbangorilla 3963 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
No new posts New Members Newbie from "florduh" here. Mid travel build. 9 shawn813 5011 Newbie from "florduh"...
 Thu Apr 18, 2013 11:13 PM
shawn813 View latest post
75 T_Town_Baja 102115 Re: Mid Travel Manx - ...
 Sat Dec 01, 2012 09:19 PM
jmert View latest post
No new posts VW Volkswagen & Baja Bug General Discussion wheel offset question? 0 billyjoejimbob33 2976 wheel offset question?
 Mon Oct 22, 2012 12:31 AM
billyjoejimbob33 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Does any one local to Chandler AZ stock 7x15 tires? 3 tobiism 9193 Does any one local to ...
 Wed Dec 14, 2011 02:46 AM
