Latest: hulkbaja
Overall: 3594
Visitors: 109
Total: 109
01: Links
04: Links
06: Links
07: My Account
10: Links
11: Links
12: Links
13: Links
14: Links
17: Pictures
23: Links
31: Links
32: Links
33: Links
44: Pictures
46: Links
47: Links
48: Links
49: Links
50: Links
51: Links
53: Links
54: Pictures
56: Links
66: Pictures
76: Pictures
85: Event Calendar
86: Links
87: Links
93: My Account
99: Links
101: Pictures
103: My Account
105: Links
109: Links
1 2 3 ... 73 74 75 ... 103 104 105
Posted: Sat Jan 21, 2012 07:49 AM
I pulled my engine tonight in preparation for replacing the main seal and fixing an oil strainer stud tomorrow. While the engne is out, I cleaned up engine grime and used bedliner in the engine compartment and rear wheel wells. I had my new 205/75r15 General Grabber tires mounted today. I also removed the header and quietpack (with rust holes) and will have it welded up.
I had help today from Dirtjunkie. I replaced the main seal, although it still looked good. However there was no o ring for the flywheel, just some material of some sort in the groove. I cleaned that out and put a new o ring in. I tightened all my bolts I could get to, and used degreaser on the engine. I also repaired a oil strainer stud. When I had changed the oil last time, I found one was loose and had something in the threads similar to JB Weld. I had put a 1/4"x20 stud in at the time to hold it, but repaired it properly today by drilling and tapping it for a 8mm to 6mm step stud. Went nice and slow and used grease in the bit and tap. Plugged the large hole where the strainer went with paper towels and my son held a vacuum next to the bit while I drilled (Good advice Dirtjunkie!!!). Used blue locktight on the stud and buttoned everything up. Mounted the original exhaust back on and mounted my new Grabber tires. We'll see if it has a big leak in the morning...
Posted: Sun Jan 22, 2012 08:06 AM
Well thumper.....hope all goes well.
By the sounds of it youre gettin her right on track!!!
Lets see how that little 1200cc does now.
ME
I ran a pipe bending and cutting class.
Im thinking this will be a pretty cool WEB once done.
Even though i under bent my upright and i over bent my runners at least my angles are in hand now.
Im thinking on trying a drop in fit instead of a piece by piece...we'll see.
What can one DO......
Posted: Sun Jan 22, 2012 07:54 PM
Installed a new tach and speedo cable on Project II, had the old tires dismounted to strip and repaint the rims, in preperation for the new tires(thanks Biblethumpincop). Rebuilt the pedal set for the rail project and picked up a bunch of different nut & bolts needed to start putting everything together.
Posted: Mon Jan 23, 2012 04:10 AM
I found some inexpensive foam floar covering at Big Lots that I installed for a headliner. It use to be a sunroof so making something work around the framework required material with a little stiffness. I hope it works out.
Posted: Mon Jan 23, 2012 05:10 AM
Took engine apart and spent the day sanding and painting and sanding and painting. . .
69baja69
69baja69
Posted: Fri Jan 27, 2012 10:17 PM
finished (hopefully) tuning and jetting my hpmx 40, hit the dirt road for a 30 mph pass, lol, insulated my aluminum door panels to stop their rattling, cutting out an aluminum speed limit sign for my dash, waiting for my new GAUGES!!!! ill finally know my oil temp and pressure!
Posted: Sat Jan 28, 2012 06:40 AM
Form fitting the halves after shipping......and a touch of mod.
Posted: Sat Jan 28, 2012 09:40 AM
took my baja out to firebird and ran it. ran an 18.55 @ 72.4 mph!
Posted: Sat Jan 28, 2012 06:29 PM
Pretty good for how heavy that car has to be, and with the big tires.
Posted: Sat Jan 28, 2012 06:41 PM
yeah i was happy. and i had fun, and drove it home under its own power. haha
Posted: Sat Jan 28, 2012 08:39 PM
Put some stock tire on it and see if you can beat TINMANs time of 18.00 and 74mph
Posted: Sat Jan 28, 2012 09:50 PM
probably just taking the spare parts, tools, floor jack, spare tire, and roof rack off i could make it into the 17s. i'll ditch my passenger too. haha
TINMAN
TINMAN
Posted: Sat Jan 28, 2012 10:16 PM
You were close I ran 18.08 at 73.69 but i,m sure I can get into the 16.00 range I went easy on that run to make sure it would run strait. shure felt a lot faster than it was.
TRUMP 2020
Posted: Sun Jan 29, 2012 08:26 AM
Kept working on a perfect fit.
And took a few measurements.
5 Admin_AzBaja 7841 Baja Bugs on Wiki need...
285 MusicManiac 249150 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 852 FREE VW BAJA'S
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1796 Re: Had to go play in ...
0 Northmountainauto 1967 Shop Baja
